| HELP!!! Where does this bolt go? | |
+5CUSTOMIZEDRHINO13 onebuilder rhino727 REDRHINO64 Chief1979 9 posters |
| Subject: Re: HELP!!! Where does this bolt go? Wed May 01, 2013 11:11 pm | |
| Glad u figured out where it went!!! | |
rhinopg
Posts : 41 Join date : 2013-03-10 Age : 64 Location : Prince George BC
| Subject: Re: HELP!!! Where does this bolt go? Fri May 03, 2013 10:54 pm | |
| When you install this ball and spring and bolt what gear does the shifter have to be in,i looked down the hole with a trouble light and it looks like the ball could fall into the middle cases which would mean haveing to split the engine apart to retrive the ball,or am i missing something any one know what to do .thanks in asvance | |
| Subject: Re: HELP!!! Where does this bolt go? Sat May 04, 2013 12:48 am | |
| I don't think it matters what gear your in. The little ball fits into indents which holds the shifter in its gear. When I did my overhaul I had the wrong size bolt ,it was out of a grizzly and would not allow it to shift ...too long! | |
| Subject: Re: HELP!!! Where does this bolt go? Sat May 04, 2013 10:22 am | |
| - rhinopg wrote:
- When you install this ball and spring and bolt what gear does the shifter have to be in,i looked down the hole with a trouble light and it looks like the ball could fall into the middle cases which would mean haveing to split the engine apart to retrive the ball,or am i missing something any one know what to do .thanks in asvance
Does it shift now? Probe the hole with a small screw driver, does it bottom out or have a seat for the ball to rest on? | |
rhinopg
| Subject: Re: HELP!!! Where does this bolt go? Sat May 04, 2013 10:58 pm | |
| I have rebuilt may motor,which has taken a few weeks,so i am just trying to make sure the ball goes into the right place i can see what i guess are detents,so you just drop the ball in then the spring and bolt and tourgue it down and i should be good to go.i can shift trans by hand and everything seems to work the motor is still on the bench, | |
Chief1979
Posts : 91 Join date : 2013-04-09 Age : 42 Location : Cookeville, TN
| Subject: Re: HELP!!! Where does this bolt go? Sun May 05, 2013 11:15 pm | |
| Yeah, just put the ball back into the hole, slide the spring in, and than install bolt and torque. Don't forget some blue loc-tite on the threads, and make sure they're clean. Than just cycle the shifter through the gears and make sure everything feels good. | |
rhinopg
| Subject: Re: HELP!!! Where does this bolt go? Mon May 06, 2013 11:36 am | |
| Thanks guys everything is good to go, moved shifter back and fourth shifts smoothly | |
| Subject: Re: HELP!!! Where does this bolt go? Mon May 06, 2013 11:45 am | |
| - rhinopg wrote:
- Thanks guys everything is good to go, moved shifter back and fourth shifts smoothly
Do you feel the detent while shifting, did you feel it before? | |
rhinopg
| Subject: Re: HELP!!! Where does this bolt go? Mon May 06, 2013 11:50 am | |
| Yes it shifted fine before the rebuild and it shifts smoothly now,and you can feel each detent as you shift. | |
Adamfigge
Posts : 3 Join date : 2013-10-12
| Subject: Re: HELP!!! Where does this bolt go? Sat Oct 12, 2013 9:00 pm | |
| I noticed oil the other day and realized I had lost a bolt as well. It is just to the right of the oil filter on my 07 660 and on the top side of where the linkage hooks up. I was told it was probably the detent bolt by the parts guy, but the shifting feels normal and feels like it's hitting the detents. There is a bolt on the front side as well, not sure if that is the detent bolt and this is just a plug? Can't seem to find anyone even at the 2 dealerships to help me with this. Also if it is the detent bolt, can the ball fall down between the case and shift cam? I can't see it or pull anything out with a magnet. | |
Adamfigge
| Subject: Re: HELP!!! Where does this bolt go? Sun Oct 13, 2013 12:13 pm | |
| bolt location if it helps | |
Adamfigge
| Subject: Re: HELP!!! Where does this bolt go? Sun Oct 13, 2013 1:13 pm | |
| ok, in the picture I posted the bolt missing is facing up, and there is another one just to the right of the of it, facing toward the front of the machine. If I am reading this right, the other one, which is still there, is the one with the detent ball and this one on top is just a plug? | |
| Subject: Re: HELP!!! Where does this bolt go? | |
