In total there are 12 users online :: 0 Registered, 0 Hidden and 12 Guests :: 2 Bots
 dynatek 660 cdi
nealmos
PostSubject: dynatek 660 cdi   Thu May 02, 2013 4:35 pm
i have a dynatek non programmable cdi for the 660 rhinos that i no longer need. make me a reasonable offer.
PostSubject: Re: dynatek 660 cdi   Thu May 02, 2013 6:26 pm
that's what I have also what did you change too
nealmos
PostSubject: Re: dynatek 660 cdi   Thu May 02, 2013 9:50 pm
I switched to a programmable MSD to help with detonation. I have a 11:1 piston.
PostSubject: Re: dynatek 660 cdi   Thu May 02, 2013 10:36 pm
pm sent
nealmos
PostSubject: Re: dynatek 660 cdi   Sun May 05, 2013 8:56 am
Replied
nealmos
PostSubject: Re: dynatek 660 cdi   Thu May 16, 2013 11:03 am
sold
PostSubject: Re: dynatek 660 cdi   Thu May 16, 2013 3:30 pm
just wondering the benefits of the programmable one just for timing issues like high compression piston
nealmos
PostSubject: Re: dynatek 660 cdi   Fri May 17, 2013 8:17 am
yes, thats the only reason i switched to the msd. needed to take some timing away for the 11:1 piston.
dynatek 660 cdi
» Dynatek ECU
» Has anyone used the Dynatek ignition mod for a fuel injection quad?
» Smith700's Rhino 700 thread
» Ignition boxes make me confused
» Single Cylinder ATV...WTT or WTS... "TRADED"
HOTRODRHINOFORUMS.COM :: Buy and Sell :: Rhino Parts-
