In total there are 16 users online :: 0 Registered, 0 Hidden and 16 Guests :: 2 Bots
 Sheave installed today..
Go to page : 1, 2  Next
PostSubject: Sheave installed today..   Thu May 02, 2013 9:54 pm
Got mine installed today but didn't have much time to test it out due to the cold ass temps and rain that moved in today. With two of us that weigh 260 I was able to do 52 on flat ground and 59 going down hill but that was on short roads and I am sure there is more there.
I have two questions. First question - What determines whether or not I need to switch out my secondary spring from factory. Second question - James are you still buying the factory sheaves that we pull out, mine has 200 miles on it.
27" EFX Motoclaws
JE 11:1 102mm
Warn Pro Vantage 3500lb.
Ricochet a-arm skids
PRM bash plate
Unisteer Rackzilla
Workhorserhino
PostSubject: Re: Sheave installed today..   Thu May 02, 2013 10:03 pm
Pretty impressive numbers, nice job on a new machine.
JBS sheave w/16g weights -- Pwr steering -- am/fm radio -- 2nd Batt under hood -- Warn 3.5 winch -- homemade winch mount -- Progressive 425 shocks -- homemade frt skidplate -- frt & rear diff supports -- frt &rear a-arm supports -- homemade plow mount -- SS108 w/bajacross tires -- SS212 15" w/ 27" ultracross tires --  RDC 2" lift kit--        WOW this thing is expensive!!!
Posting by now talking to my new Galaxy S  active cell phone.
PostSubject: Re: Sheave installed today..   Thu May 02, 2013 10:47 pm
awesme performance, the jbs sheeve is the best mod
PostSubject: Re: Sheave installed today..   Thu May 02, 2013 11:35 pm
Haha joinin the club, rhino club that is:lol: One of the best mods you can do!
2006 660 Special Edition
NGK Iridium Plug
JBS Sheave, 14 ods, Orange Spring, Anti-friction Washers
Weller Racing High Volume Fuel Pump Kit
"If you carry a gun, people will call you paranoid. That's ridiculous. If I've got a gun, what in the hell do I have to be paranoid about?" - Clint Smith
PostSubject: Re: Sheave installed today..   Fri May 03, 2013 3:37 am
Sounds like great results. If you have any lag after you get back to the gas while moving, or when you get to it on a steep hill, the secondary spring will help it backshift (downshift) alot faster to get in the higher rpms so it will pull better. It also grips the belt a little more.
I think I understand this right. If not, James will straighten me out.
Stage 2 cam
Black Rhino CDI
Bazzaz fuel controller
Hot Rod sheave with 16g ODs
Purple secondary
PostSubject: Re: Sheave installed today..   Tue May 07, 2013 1:11 am
Well I finally got to go out today and push on the Rhino and man does it run sooo much better. I was able to get 61mph out of it before I hit the rev limiter. I am pretty happy with that, now its time to make it get there faster.
27" EFX Motoclaws
JE 11:1 102mm
PRM bash plate
Unisteer Rackzilla
PostSubject: Re: Sheave installed today..   Tue May 07, 2013 1:16 am
that's fast, sounds like you got it right on, now for the HP mods Twisted Evil
PostSubject: Re: Sheave installed today..   Sun May 19, 2013 9:54 pm
I hit 62mph today with me and daughter both in there and wasn't in to the rev limiter. I'm guessing it has something to do with temps, we have went from 35 degrees to almost 90 degrees today and the Rhino likes it.
27" EFX Motoclaws
JE 11:1 102mm
PRM bash plate
Unisteer Rackzilla
PostSubject: Re: Sheave installed today..   Sun May 19, 2013 10:04 pm
PostSubject: Re: Sheave installed today..   Mon May 20, 2013 1:43 am
Oh yeah!
NGK Iridium Plug
PostSubject: Re: Sheave installed today..   Tue May 21, 2013 7:30 pm
that thing is runnin great glad your happy
PostSubject: Re: Sheave installed today..   Tue May 21, 2013 8:13 pm
thats for damn sure!!!
PostSubject: Re: Sheave installed today..   Thu May 23, 2013 11:04 pm
Hit a new high speed today, 63mph downhill of course. I'm pretty sure this is all it has.
27" EFX Motoclaws
JE 11:1 102mm
PRM bash plate
Unisteer Rackzilla
PostSubject: Re: Sheave installed today..   Thu May 23, 2013 11:06 pm
Nice!!! Pull the bed off and try?lol!
NGK Iridium Plug
PostSubject: Re: Sheave installed today..   Thu May 23, 2013 11:34 pm
nice!!
2009 Yamaha Rhino 787
jamesbodyshop@hotmail.com
PostSubject: Re: Sheave installed today..   Fri May 24, 2013 12:25 am
Oh yeah! Your Rhino runs better than any other stock bore/stroke/compression I have ever seen. Really, my buddy and I have identical Rhinos we got at the same time. His was always faster and had more torque than mine. Haha!
Mine must have been made on July 5, by a bunch of hungover assembly workers... LoL
2011 Rhino 734 Sport
2014 Teryx4 800 LE
4500lb Warn
PostSubject: Re: Sheave installed today..   Fri May 24, 2013 1:47 am
Was it by a lot?
NGK Iridium Plug
wolverine34
PostSubject: Re: Sheave installed today..   Fri May 24, 2013 9:04 pm
dang the most i can get out of my 08 700 is 51 on level ground. with just me in it and i've got JB sheave, MSD, two brother dual exhaust.
Skinny Pedal Club
2008-700-Rhino
JBS Sheave
JBS Rear Skid Plate
Power Steering
STI Roctane
STI HD3
MSD
Teryx Shocks
PostSubject: Re: Sheave installed today..   Mon May 27, 2013 12:57 am
So Chris does that mean I should be happy with it Smile because I'm not Twisted Evil I am going to do a cam and fuel controller between now and the JBS ride in October and then hopefully get to ride in some really fast ones to see which way I want to go with my motor or if I am going to make the jump to a true sport sxs.
I will try and get some some comparison's tomorrow with my speedometer and my gps to make sure everything is right. With me running 26's that 63mph should be 65+ on the gps.
27" EFX Motoclaws
JE 11:1 102mm
PRM bash plate
Unisteer Rackzilla
PostSubject: Re: Sheave installed today..   Mon May 27, 2013 2:40 am
hey thekevin, for the purpose of science, I'll compare my heavy shit to yours and then you can help me understand why my top speed is 54mph with wind on a perfect day and average day is 50-51mph. Granted you never know with motors, either way I cant wait to see more video.
Comparison...
2013 Rhino 700 SE Tactical Black.....2008 hunter green 700
14" Raceline Mamba true beadlocks......12' OEM steel
26" Maxxis Big Horn's....25'x8/10" OG Bighorns
Dynatek CDI....MSD 2d
Warn Pro Vantage 3500lb.....4 seater cage
Gibson exhaust ceramic coated black....same
JBS Sheave w/ 16gr od's...same with gold spring and anti friction washers
Ricochet a-arm skids...Long travel +6
PRM bash plate...Pro-1 doors
PostSubject: Re: Sheave installed today..   Mon May 27, 2013 3:13 am
It's a sickness, bro. Once upon a time, I had a stock Rhino but I wanted more. So I got a JBS sheave. Then, I wanted more so got the cam. Then I wanted more so I got the throttle body. Then I wanted more so I got the exhaust. Then I wanted more so I got the 734 big bore. Now I want more again and I am considering doing the ported head.
I have noticed that my speedometer with 26" Bighorn OG's reads very close to accurate. With the stock tires it was a little, err, optimistic. Rolling Eyes
2014 Teryx4 800 LE
4500lb Warn
PostSubject: Re: Sheave installed today..   Mon May 27, 2013 8:14 am
PostSubject: Re: Sheave installed today..   Mon May 27, 2013 9:39 am
Dancing Banana
PostSubject: Re: Sheave installed today..   Mon May 27, 2013 10:12 am
I'm at the lake today but when I get home I will slap the gps in there and see what it says. Aspendell do you have a windshield in, I don't and I weight a light 260lbs so if we are adding up heavy shit that has to be considered Smile
Chris I am hoping to ride in a 734 and decided that I will be happy with that because if I have to up to a 787 then my wife might divorce me.
Here is what my Rhino looks like right now.
27" EFX Motoclaws
JE 11:1 102mm
PRM bash plate
Unisteer Rackzilla
PostSubject: Re: Sheave installed today..   Mon May 27, 2013 7:36 pm
I'm gonna start a new rumor that Tac Black Rhino's make 5 more hp than the other colors.
Sorry for the crappy video but this was my 9 year old daughter holding the gps and my phone to make the video. The speedo on the dash showed 62mph when it hit the rev limiter today and the gps showed 64mph.
27" EFX Motoclaws
JE 11:1 102mm
PRM bash plate
Unisteer Rackzilla
