| Just added CDI | |
| Subject: Just added CDI Mon May 06, 2013 1:17 pm | |
| Dynatek DFS7-13. Installed and I noticed it seemed to start quicker, may just be mental? Anything I need to look for or do with this mod? Also what speed should I reach? Running 25" knock off bighorn non radials. I think my belt may be worn, when I serviced sheave, it did not ride to the top of primary when I revved engine? I forgot to measure specs on belt, but I gather this may be an indication. Would this allow belt to ride higher with the higher rpms or I am mistaken? Still learning the CVT thing. | |
chalkminer
| Subject: Re: Just added CDI Mon May 06, 2013 1:33 pm | |
| Do you still run the stock sheave? I would not expect the CDI to allow you more travel on the belt. I have not run the Dynatek but I expect it should get you into the 50's for top speed. If you have not already done so I strongly suggest going with the JBS sheave and OD weights. | |
| Subject: Re: Just added CDI Mon May 06, 2013 1:39 pm | |
| Thanks and yea still stock for now. A JBS sheave is on my wish list, just saving my funds. I just wondered what you could get with stock clutching, it is raining like cats and dogs here, but I may get wet just to try it out! | |
chalkminer
| Subject: Re: Just added CDI Mon May 06, 2013 1:51 pm | |
| I am stuck in the office, would much rather be riding in the rain. Be careful though. According to the warning sticker you should never run your rhino in water deeper than 13 inches LOL! Anyway, I think you will be happy with the speed but may be really reving it up to get there. Let us know how it turns out for you. If you are just looking for top speed I think you can install overdrive weights and upgrade the sheave later. | |
| Subject: Re: Just added CDI Mon May 06, 2013 2:06 pm | |
| Well, I have sick one, so I just grabbed my laptop and "working from home" today . Worked out that the cdi just happen to get here today too. I am not really into speed but would like to have it available if needed. From what I have read and would like, is to cruise around at lower rpms, so it won't be so loud in the cab. Really just want good overall performance from it. | |
| Subject: Re: Just added CDI Mon May 06, 2013 5:07 pm | |
| Well, rain quit. So I took it down paved county road and I'll be damned if a deputy meets me, clocked me at 50. Speedo said 49. Po Po are never on my road, LOL. Told him I was looking for my dog and I lived right up the road, he let me go. The trainee or ride along asked me if I could just ride in the yards/shoulder, I told him no it was too wet. I know it will at least run 50... | |
| Subject: Re: Just added CDI Tue May 07, 2013 1:01 am | |
| where you hitting rev limiter , an got lucky with po po | |
| Subject: Re: Just added CDI Wed May 08, 2013 11:36 am | |
| MSD 4243 on setting number 6,will go 55 mph without hitting a rev limiter, chickend out before a rev limiter.
Last edited by 123.bert0621 on Wed May 08, 2013 11:36 am; edited 1 time in total (Reason for editing : stock sheave) | |
| Subject: Re: Just added CDI Wed May 08, 2013 11:49 am | |
| what is the rev limiter set at? | |
| Subject: Re: Just added CDI Wed May 08, 2013 12:21 pm | |
| Man I have no idea on rev limiter. How could I tell? I would like to know, if there is a way. I don't have a tach yet. I am happy with 50, think I could get more, cause I wasn't into limiter. I am loving this machine, but will love it better with the right sheave setup and new belt. | |
| Subject: Re: Just added CDI Wed May 08, 2013 1:46 pm | |
| MINE IS AT 8500RPM +4DEGREES OF TIMING. | |
| Subject: Re: Just added CDI Wed May 08, 2013 4:22 pm | |
| Mine with the Dynatek cdi would hit the rev limiter at 53, now with the jbs sheave it will hit it at 61. | |
| Subject: Wed May 08, 2013 10:31 pm | |
| - thekevin wrote:
- Mine with the Dynatek cdi would hit the rev limiter at 53, now with the jbs sheave it will hit it at 61.
Thats cool, I'm for a similar result,61 is fast. I am going to turn mine down to 8000 RPM. | |
| Subject: Re: Just added CDI Wed May 08, 2013 10:57 pm | |
| Subject: Re: Just added CDI Wed May 08, 2013 11:05 pm | |
| MSD has a dial on the side,and you can change settings on your PC. | |
| Subject: Re: Just added CDI Thu May 09, 2013 7:17 pm | |
| I guess Dynatek doesn't have an adjustment? | |
| Subject: Re: Just added CDI Thu May 09, 2013 7:49 pm | |
| 8000 is what i set them unless they have a good rod then 8500 | |
| Subject: Re: Just added CDI Thu May 09, 2013 8:06 pm | |
| I bought it used and I have no idea where/how to check what it is set at. I got about 2700ish miles on the rhino and it was taken care of ( well I think so anyway). I fo sure don't want to over rev it. Any trick on how to tell what the rev limiter is set at? | |
| Subject: Re: Just added CDI | |
| Just added CDI | |
