In total there are 14 users online :: 0 Registered, 0 Hidden and 14 Guests :: 1 Bot
need help machining a rod.  Icon_minitimeWed Aug 16, 2023 1:17 pm by RADICAL RAM
need help machining a rod.  Icon_minitimeThu Dec 14, 2017 4:54 pm by WV Hot Rod Rhino
need help machining a rod.  Icon_minitimeThu Dec 14, 2017 1:28 am by WV Hot Rod Rhino
need help machining a rod.  Icon_minitimeThu Dec 14, 2017 12:35 am by WV Hot Rod Rhino
need help machining a rod.  Icon_minitimeFri Dec 13, 2013 11:01 am by WV Hot Rod Rhino
need help machining a rod.  Icon_minitimeFri Dec 13, 2013 10:59 am by WV Hot Rod Rhino
need help machining a rod.  Icon_minitimeFri Dec 13, 2013 9:33 am by Tacoclaw
need help machining a rod.  Icon_minitimeFri Dec 13, 2013 7:50 am by chuddly
need help machining a rod.  Icon_minitimeFri Dec 13, 2013 7:47 am by chuddly
need help machining a rod.  Vote_lcapneed help machining a rod.  Voting_barneed help machining a rod.  Vote_rcap
4 posters
dmrhino
need help machining a rod.  Empty
PostSubject: need help machining a rod.    need help machining a rod.  Icon_minitimeWed May 08, 2013 10:17 pm
I was wondering if there is anyone out there that can help me by machining a part for me. I need a rod roughly 3/8" diameter that is 11 3/4" long and the two ends machined down and threaded to a 6.0 mm 1.0 pitch. But one end is a right hand thread and the other end is a left hand thread. I have tired machine shops around here and they don't want to do it or can't do the left hand thread. This doesn't go on my Rhino it's actually for my honda shadow for it's shift linkage. If anyone can help me out it will be greatly appreciated. Thanks
PostSubject: Re: need help machining a rod.    need help machining a rod.  Icon_minitimeThu May 09, 2013 12:48 am
I know that the 3/8=.375 I don't know what you need for the 6mm thread , what I 'm getting at is find out what you need the rod turned down to for 6mm threads have local shop turn it then you get 6mm dies one left one right an tread the rod your self an get a can cutting tool oil
kris55
kris55
PostSubject: Re: need help machining a rod.    need help machining a rod.  Icon_minitimeThu May 09, 2013 12:50 pm
If your part is similar to #14 below it will be most likely cheaper to just buy an OEM one.
http://www.motosport.com/cruiser/oem-parts/HONDA/2000/SHADOW-DELUXE-_-VT750CD/PEDAL
Brian lee Rhino450
Brian lee Rhino450
PostSubject: Re: need help machining a rod.    need help machining a rod.  Icon_minitimeTue May 21, 2013 2:48 am
I know this is an old post. If u havent got one yet, what i would do is buy a piece of 3/8 rod drill a hole in both ends. Get 2 male hiem joints then tap the holes the same size of the threads on the hiem joints. No machining required. Then run bolts thru the eyes in the hiem joints and hook them to you shifters
