In total there are 8 users online :: 0 Registered, 0 Hidden and 8 Guests :: 2 Bots
Go to page : Previous  1, 2, 3, 4 ... 20 ... 37  Next
PostSubject: Re: 1st Annual Hot Rod Rhino Forums Ride Oct 4th-6th   Mon May 13, 2013 10:54 pm
Workhorserhino wrote:
Would anybody know, can I get the trail pass at Ashland. Or get it before online.
OK never been to H/M before this trail pass need info on it also , I thought you would just have a pay box where you go into trail system ,
any body got info ??? will try to google to see whats what
PostSubject: Re: 1st Annual Hot Rod Rhino Forums Ride Oct 4th-6th   Mon May 13, 2013 11:04 pm
from what i'm reading, ashland has the necessary permits. there is also a mandatory helmet requirement on the Hatfield-McCoy trail system.
anybody know if you can get by without permits and helmets on the outlaw trails? bounce
JBS
PostSubject: Re: 1st Annual Hot Rod Rhino Forums Ride Oct 4th-6th   Tue May 14, 2013 12:09 am
at ashland if you want
2009 Yamaha Rhino 787
jamesbodyshop@hotmail.com
Mrs. Hot Rod
PostSubject: Re: 1st Annual Hot Rod Rhino Forums Ride Oct 4th-6th   Tue May 14, 2013 12:22 am
Nope ... we have been through check points where they check for helmets, permits & make sure there is no alcohol in the cooler. I'm thinking we don't really have to ride the H/M trails & that we could just ride outlaw ....
PostSubject: Re: 1st Annual Hot Rod Rhino Forums Ride Oct 4th-6th   Tue May 14, 2013 12:34 am
Outlaw trails outlaws are welcome. LOL H&M is helmets required and you can get permits at Ashland campground if we end up riding those trails.
Stage 2 cam
Black Rhino CDI
Bazzaz fuel controller
Hot Rod sheave with 16g ODs
Purple secondary
PostSubject: Re: 1st Annual Hot Rod Rhino Forums Ride Oct 4th-6th   Tue May 14, 2013 6:55 am
Im in guys! Talked to the wife last night and told her i was going. She wont be going and I doubt my kids will come either so i have room for passengers (4 seater) if someone needs a lift. Also depending on if anyone is carpooling with me depends on the truck/trailer set up i will bring. I have a trailer that will hold 2 side by sides no problem and maybe 3 (i will have to measure and check). If anyone wanted to load on and go with they are welcome. Either meeting at my place and leaving your truck or me swinging by and getting you i would be good with that. If there are no takers with that though i will just bring my small trailer that only holds my rhino. If anyone wants to do that just PM me.
2006 Rhino 660
HID conversion
Quick detach snow plow
extended roll cage
4 point harnesses
Hunterworks CDI
700 belt
JBS sheave
14g weights
Purple spring
Mods in progress -
bubba53
PostSubject: Re: 1st Annual Hot Rod Rhino Forums Ride Oct 4th-6th   Tue May 14, 2013 8:10 am
Red Solo Truck will be there...
PostSubject: Re: 1st Annual Hot Rod Rhino Forums Ride Oct 4th-6th   Tue May 14, 2013 8:49 am
how much are the h&m permits? and is it per sxs or per person? also is there a age requirement? my kids are 3 & 6.
PostSubject: Re: 1st Annual Hot Rod Rhino Forums Ride Oct 4th-6th   Tue May 14, 2013 8:57 am
not sure on out of state...its per person...if its alot we will ride the outlaw trails and not get them
PostSubject: Re: 1st Annual Hot Rod Rhino Forums Ride Oct 4th-6th   Tue May 14, 2013 9:05 am
the list!!
-wvhotrodrhino
-bayoutiger
-t-rhino
- flimmy
-08rhino450se
-chuddly
-chief1979
-t-bone
-lambfam660
-rhino727
workhorserhino
-madmax1
-rhinoruss
-hump
-pitdog
-bubba
-geterdun
-crazybilly
-bobbyd
Last edited by WV Hot Rod Rhino on Tue May 14, 2013 7:48 pm; edited 1 time in total
PostSubject: Re: 1st Annual Hot Rod Rhino Forums Ride Oct 4th-6th   Tue May 14, 2013 9:23 am
Out of state is $50 per person. Permit goes on your helmet on the right side
Owner of
www.trailbrightled.com
Moto Alliance dealer
Pro Armor dealer
Rocky Mountain ATV dealer
PostSubject: Re: 1st Annual Hot Rod Rhino Forums Ride Oct 4th-6th   Tue May 14, 2013 9:27 am
DANG! thats pretty pricey! For one person like me its not a huge deal but its still pricey. but for some of the guys who will have 4 people in their rig thats $200 and im sure for some guys that is extra money they just dont have
2006 Rhino 660
HID conversion
extended roll cage
4 point harnesses
Hunterworks CDI
700 belt
JBS sheave
14g weights
Purple spring
Mods in progress -
PostSubject: Re: 1st Annual Hot Rod Rhino Forums Ride Oct 4th-6th   Tue May 14, 2013 10:19 am
so they don't check for helmets or alcohol on the outlaw trails? can you carry weapons?
[img][/img]
JBS
PostSubject: Re: 1st Annual Hot Rod Rhino Forums Ride Oct 4th-6th   Tue May 14, 2013 10:29 am
[img][/img]
they do not...yep..i do
rhinoroger
PostSubject: Re: 1st Annual Hot Rod Rhino Forums Ride Oct 4th-6th   Tue May 14, 2013 11:54 am
james, we booked, ad13,
08' 700 Sport, 4500 Superwinch, Cab heater, uni ps., Hids, 3D MSD, Super Crank, 734bb, cam, +2ported head, JBS Sheave, gold spring, 16gr, 26''Bighorns, ITP216s, Dual Muzzy's, Pro 1 doors, Ride On dust shield, Many thanks James for your awesome JBS Build.
PostSubject: Re: 1st Annual Hot Rod Rhino Forums Ride Oct 4th-6th   Tue May 14, 2013 1:32 pm
for your 50.00 permit, is it good for....... day , week or longer
PostSubject: Re: 1st Annual Hot Rod Rhino Forums Ride Oct 4th-6th   Tue May 14, 2013 1:37 pm
IM OUT! just talked to someone at h&m 50.00 per person for permits and my kids are not allowed.
PostSubject: Re: 1st Annual Hot Rod Rhino Forums Ride Oct 4th-6th   Tue May 14, 2013 1:43 pm
what they say about kids
PostSubject: Re: 1st Annual Hot Rod Rhino Forums Ride Oct 4th-6th   Tue May 14, 2013 1:51 pm
if a kid is on a atv the kid must be of the correct size atv per mfg guidelines. as for passanger in a sxs no booster seats , no child seats and the childs back must touch the back of the seat and there feet must touch the floor. total f-in bullshit if you ask me. my kid is safer in my rhino than my damn truck. snitty little attitude wanted to reach thru the phone and slap her.
PostSubject: Re: 1st Annual Hot Rod Rhino Forums Ride Oct 4th-6th   Tue May 14, 2013 2:19 pm
They are good tool Dec 31 2013
They run Jan 1 to Dec 31
Owner of
Pro Armor dealer
PostSubject: Re: 1st Annual Hot Rod Rhino Forums Ride Oct 4th-6th   Tue May 14, 2013 3:23 pm
thought that bullshit only happened in CA..lol
PostSubject: Re: 1st Annual Hot Rod Rhino Forums Ride Oct 4th-6th   Tue May 14, 2013 3:58 pm
we dont have to ride them
Bayou Tiger
PostSubject: Re: 1st Annual Hot Rod Rhino Forums Ride Oct 4th-6th   Tue May 14, 2013 4:35 pm
Are there enough outlaw trails in the area to keep us rolling for 3 days?
2012 700SE
PostSubject: Re: 1st Annual Hot Rod Rhino Forums Ride Oct 4th-6th   Tue May 14, 2013 4:39 pm
3 weeks...lol
PostSubject: Re: 1st Annual Hot Rod Rhino Forums Ride Oct 4th-6th   Tue May 14, 2013 4:40 pm
im not gonna be the guy that keeps everyone from doing other trails. and i dont wanna drive 9 hours to ride illegal trails. im gonna have a hard enough time getting money together to make the trip. cant risk a trespassing fine.
Page 3 of 37Go to page : Previous  1, 2, 3, 4 ... 20 ... 37  Next
» The 2nd Annual Uwharrie Night Time Trail Ride
» Second Annual RZRForums.net Trails End Ride Oct 1-4
» 2nd Annual BOO-BASH and NIGHT Ride DTOR STYLE!!!!
» Clone Forums .Com
» Places to ride near Lexington?
HOTRODRHINOFORUMS.COM :: Members :: Local Rides and Events-
