In total there are 9 users online :: 0 Registered, 0 Hidden and 9 Guests :: 2 Bots
Go to page : Previous  1, 2, 3, 4, 5, 6, 7  Next
Bumpers
PostSubject: Re: BUMPERS rhino.... evergoing build thread   Wed Apr 17, 2013 12:30 am
I havent touched anything but the main and pilot jet and the a/f screw. Its close now I just need to get a few areas cleaned up alittle. From what I was told thats the only three things I needed to mess with. And im not to carb savy..
06 660 money pit.... 720 stroker, long travel, and abunch of other junk
UnderDawg
PostSubject: Re: BUMPERS rhino.... evergoing build thread   Wed Apr 17, 2013 12:49 am
if pull the top of the carb off and move the c-clip up one notch on the needle it should lean it out just a tad.
09 camo 450
PostSubject: Re: BUMPERS rhino.... evergoing build thread   Wed Apr 17, 2013 1:12 am
Bumpers wrote:
I will get some once i get the tune better... right now it goes rich when i nail it (like enough to smoke alittle) then goes back in the 12ish range.. i need to lean it out a hair..
does the idle air screw richen it up the more turns out?
Bumpers, If your talking about a/f screw on the bottom of the carb it will richen it up as it's turned out. I 've just went through tuning my carb and it was a learn experience for me. Best advice I was told is dial in the main and work down to idle being the last adjustment. That's also what seem to work the best on my bike. I also was using James's a/f meter for the tuning. Like a Star @ heaven
08/700 SE;Stocker
Bumpers
PostSubject: Re: BUMPERS rhino.... evergoing build thread   Wed Apr 17, 2013 1:20 am
I will look into this .. I havent had time yet but im goin to read over some threads and see what I can come up with
PostSubject: Re: BUMPERS rhino.... evergoing build thread   Wed Apr 17, 2013 1:37 am
I read articles that said start with the idle and work up, read one that said first thing start with the needle jet. I finally went back and started all over with the main and worked down and thing fell into place. I spent a good day where I felt I wasn't making any headway, that's when I said chit and started all over with the main. Good luck, it was a great learn experience for me and I now feel comfortable with it. One thing about a carb, you can't really mess it up, you can always go back to step one and start over.
08/700 SE;Stocker
Bumpers
PostSubject: Re: BUMPERS rhino.... evergoing build thread   Wed Apr 17, 2013 1:45 am
Yea I know what you mean on the main jet. Having that dialed in is key.. thats where you dont want to be lean or have issues. Ive got it pretty close I may step down to the next size and it should be spot on then I will fiddle with the idle and part throttle stuff and see if I can get it more stable. Right now at some points it dumps enough fuel where you can see a good puff of smoke but as soon as you get in the gas it leans up some and runs good. When I see the puffs of smoke the wideband is reading low 11s into the 10s. Its hard to see really but I know its goin way rich and I know at part throttle its gunna jump all over the place . But the little blips of the throttle is where it seems to richen up a lot
Bumpers
PostSubject: Re: BUMPERS rhino.... evergoing build thread   Wed Apr 17, 2013 10:44 pm
Think I found my tuning issue .. I had some trash in my gas tank and there was some stuck in the pickup tube. Got it out and hopfully I got all the rest out of the tank I couldnt see anymore with the limited amount of veiw. I will see tomorrow if thats the problem.
The afr was different just about every time I made a pass due to not picking up enough fuel I suppose.. you can only make so many wot passes by a church on a wendsday night so I will continue more tomorrow
Bumpers
PostSubject: Re: BUMPERS rhino.... evergoing build thread   Thu Apr 18, 2013 6:58 pm
all buttoned back up and ready to ride alittle still needs alittle tuning i think but i will get it down eventually... it just goes rich at part throttle blips.. like in the 10s and smoke rich but wot is 12.6-13 so we are good there and most of the driving stays in the 13s.. right now im running a 152.5 mikuni main and 50 pilot with 1.5 turns out on the a/f screw.
new special edition shifter and guage pod i made and sticker bombed
flimmys got me another light bar coming for the bumper then we should be set. its suppost to be here tomorrow
[IMG]
[URL=http://illiweb.com/fa/pbucket.gif]
also fresh painted the cage and plastics so hopefully with just alittle more tuning we will be good to go for the summer
PostSubject: Re: BUMPERS rhino.... evergoing build thread   Thu Apr 18, 2013 9:32 pm
That thing looks awesome Bumpers!
2006 660 Special Edition
NGK Iridium Plug
JBS Sheave, 14 ods, Orange Spring, Anti-friction Washers
Weller Racing High Volume Fuel Pump Kit
"If you carry a gun, people will call you paranoid. That's ridiculous. If I've got a gun, what in the hell do I have to be paranoid about?" - Clint Smith
PostSubject: Re: BUMPERS rhino.... evergoing build thread   Thu Apr 18, 2013 9:52 pm
X-2 awesome looking ride brotha!!..love the long travel!!
PostSubject: Re: BUMPERS rhino.... evergoing build thread   Thu Apr 18, 2013 10:04 pm
Super nice Garrett. You're going to have fun this summer. Hell it all ready looks like summer there to me. Enjoy!!!! Let-Em Buck!!!!Like a Star @ heaven
08/700 SE;Stocker
PostSubject: Re: BUMPERS rhino.... evergoing build thread   Fri Apr 19, 2013 6:45 am
looking nice....now get out and run the thing.
2006 Rhino 660
HID conversion
Quick detach snow plow
extended roll cage
4 point harnesses
Hunterworks CDI
700 belt
JBS sheave
14g weights
Purple spring
Mods in progress -
Bumpers
PostSubject: Re: BUMPERS rhino.... evergoing build thread   Fri Apr 19, 2013 9:45 am
Thanks guys. Shes goin ou for her maiden voyage this weekend. Im ready to see how it does I havent got to ride it in foever
PostSubject: Re: BUMPERS rhino.... evergoing build thread   Fri Apr 19, 2013 4:54 pm
really looks sweet lets us know how she does
Bumpers
PostSubject: Re: BUMPERS rhino.... evergoing build thread   Sun Apr 21, 2013 12:31 am
New engine is great.. once I get the jetting dialed in it will be sweet. I cant wait to see how it runs once the fuel is dialed in.. it has way more power than it ever did before even running wayyy rich.. oh and I broke the driverside inner rear cv within 20 minutes of unloading lol
Bumpers
PostSubject: Re: BUMPERS rhino.... evergoing build thread   Mon Apr 22, 2013 10:31 pm
she aint scared to get dirty... see if you can guess wich side the cv was snapped on:afro:
PostSubject: Re: BUMPERS rhino.... evergoing build thread   Mon Apr 22, 2013 10:37 pm
Drivers side lol Looks good!
NGK Iridium Plug
PostSubject: Re: BUMPERS rhino.... evergoing build thread   Mon Apr 22, 2013 10:38 pm
Dude, It looks like you were having way to much fun!!! Are you breaking that new build in right???? Twisted Evil
08/700 SE;Stocker
Bumpers
PostSubject: Re: BUMPERS rhino.... evergoing build thread   Mon Apr 22, 2013 11:07 pm
I cant wait to get the fuel dialed in and ride it...... its alot stouter than it was before.
PostSubject: Re: BUMPERS rhino.... evergoing build thread   Tue Apr 23, 2013 7:51 am
Looks like you for the light installed.
Owner of
www.trailbrightled.com
Moto Alliance dealer
Pro Armor dealer
Rocky Mountain ATV dealer
PostSubject: Re: BUMPERS rhino.... evergoing build thread   Tue Apr 23, 2013 7:52 am
How wide is your rhino ? If love to have a long arm kit but i think it would be too wide for the trails i ride
Owner of
Pro Armor dealer
PostSubject: Re: BUMPERS rhino.... evergoing build thread   Tue Apr 23, 2013 8:17 am
looks like fun!!
2009 Yamaha Rhino 787
jamesbodyshop@hotmail.com
Bumpers
PostSubject: Re: BUMPERS rhino.... evergoing build thread   Wed Apr 24, 2013 12:53 pm
Its just pronly 3-4" shy of 6ft wide like it sits. thats a 6ft wide trailer that its on. Yea i got the light thanks
EddieMc
PostSubject: Re: BUMPERS rhino.... evergoing build thread   Wed Apr 24, 2013 4:42 pm
haha love your rhino man very badass combo of black and white
2008 yamaha rhino 4 seater-racerz edge +2 full race port and polish head *alba racing 734 big bore with 11:1 piston*wellerracing crank (stock stroke) pinned and welded*dragon fire racing custom bored throttle body*power commander V (auto tune) *Dynatek ignition box*Muzzy's full dual exhaust*Autometer oil temp gauge *Autometer water temp gauge*Autometer Air to Fuel Ratio gauge Just put new crank, rod, piston, and all bearing and seals purple spring jbs sheave with 14g ods +6 lonestar long travel with bilstein shocks
EddieMc
PostSubject: Re: BUMPERS rhino.... evergoing build thread   Wed Apr 24, 2013 4:43 pm
haha awesome pics we need more mud in vegas lol, now if it would just rain lol
Page 4 of 7Go to page : Previous  1, 2, 3, 4, 5, 6, 7  Next
» Custom Chassis Build Thread
» Rhino Revamped build!
» WOT4 XL Build
» Can you Guess what it is yet?
» GLOBALRC
HOTRODRHINOFORUMS.COM :: Members :: Members Rides-
