In total there are 8 users online :: 0 Registered, 0 Hidden and 8 Guests :: 1 Bot
 Who is running skinnies all around?
PostSubject: Who is running skinnies all around?   Fri May 17, 2013 7:18 am
Who here is running skinny tires (9's or what ever) on all 4 corners? I have thought about it to save some weight. Are there any benefits running skinnies? Im probably gonna order some tires soon and i just wanted to see what everyone was running and the benefits and drawbacks
2006 Rhino 660
HID conversion
Quick detach snow plow
extended roll cage
4 point harnesses
Hunterworks CDI
700 belt
JBS sheave
14g weights
Purple spring
Mods in progress -
sls666
PostSubject: Re: Who is running skinnies all around?   Fri May 17, 2013 7:53 am
I have all skinny 30s. I think i like the handling of the machine better. Ill keep you posted going in the heavy mud this weekend
09 700 JBS super sheave/15g sliders
K&N filter     Msd(3D)   full alba
Stage2 hotcam
2"rubberdowncustoms lift
30"silverbacks s/s on 212s
26 terra crosses on 108s
Trakker 4000
Alpine/jl audio
snorkels
Scratched Blue flame body kit
PostSubject: Re: Who is running skinnies all around?   Fri May 17, 2013 7:57 am
I have 9's all the way around. Handles just fine and I haven't noticed anything bad. It saves you a few $$ and you can swap the tires to front or rear.
Owner of
www.trailbrightled.com
Moto Alliance dealer
Pro Armor dealer
Rocky Mountain ATV dealer
PostSubject: Re: Who is running skinnies all around?   Fri May 17, 2013 8:53 am
Im looking at staying at 26" tires with 9's and the thing that im really wondering about is will the back end have no traction? I want it to spin up some but i dont want to loose so much traction that its just a nightmare and it always has to be in 4wd.
2006 Rhino 660
HID conversion
extended roll cage
4 point harnesses
Hunterworks CDI
700 belt
JBS sheave
14g weights
Purple spring
Mods in progress -
PostSubject: Re: Who is running skinnies all around?   Fri May 17, 2013 10:31 am
I have 28" 9 wide mtc's all the way around. No issues. Little less traction but if you not heavy mud riding, I'd stay with skinnys. I do see where the wides help in deep mud. They will pull harder. But if you comfortable with skinnys and like to power slide, have fun.
2009 Rhino SE Red  SOLD SOLD
jmp30
PostSubject: Re: Who is running skinnies all around?   Sat May 18, 2013 11:10 am
I ran skinnies on my RZR and when I buy new tires that will be the setup I go with. As mentioned, you can slide easier if thats your thing but for normal trail riding, rocks, hills, water and all that I noticed no drawbacks. What tires are you looking at?
2013 Realtree Rhino
Bumpers
PostSubject: Re: Who is running skinnies all around?   Sat May 18, 2013 11:26 am
skinnys on the back of the rhino will probly help with handling and make cornering better since the rear diff is full time locked.. I should have bought 9s all the way around on mine... If i ever buy another set for the rhino thats what i will do
06 660 money pit.... 720 stroker, long travel, and abunch of other junk
PostSubject: Re: Who is running skinnies all around?   Sat May 18, 2013 4:47 pm
I have 26x9x12 Bighorn OG on my Rhino. I like it. It's fun. Coming from stock tires, it'll be way more traction than you are used to, even with all "skinny" tires. The stock tires are incredibly tiny. The rear 25x10 are no fatter than an aftermarket 9" tire.
Sometimes I regret doing the all skinny tires, like when I did my motor build. Once I got some good power, it's more challenging to hook up. If I race, I gotta race in 4WD High because it just spins too much out of the hole.
But for trail riding, the 26x9 is a hard combo to beat. It handles well, it even can do almost any mud on a normal trail ride (unless you go to ATV mud parks, lol). But even still, I ride a lot in the sandy river with few problems, even in 2WD.
I recommend the all skinny combo.
2011 Rhino 734 Sport
2014 Teryx4 800 LE
4500lb Warn
PostSubject: Re: Who is running skinnies all around?   Sat May 18, 2013 5:55 pm
I tried the 9x26 pizza cutters on all fours, hated it.
9 in the front and 11 in the rear works very well for me.
Dirt flies when you're having fun!
PostSubject: Re: Who is running skinnies all around?   Sat Jul 06, 2013 11:28 pm
I know this is a older thread but something I'm thanking about doing just wondering if anybody had anymore input.
JBS built 787
JBS sheave
Ported head +2 valves
Power steering
Tilt wheel
Suspinsion seats
Muzzy dual exshaust
Stage 4 elka shocks
Pit bull 26.5 Rockers
Bored throttle body
PostSubject: Re: Who is running skinnies all around?   Sat Jul 06, 2013 11:33 pm
T, that is not gonna make up for your +3 or +6 kit..lol..did u see LSR had 30% off all kits on the 4th. I wanted to buy just cus it was such a deal
PostSubject: Re: Who is running skinnies all around?   Sun Jul 07, 2013 12:02 am
Ohh hell no I didn't. But you nailed it you knew just were I was headed though.
JBS built 787
JBS sheave
Power steering
Tilt wheel
Suspinsion seats
Muzzy dual exshaust
Stage 4 elka shocks
Bored throttle body
