My console in my rhino is getting very very hot but not overheating Icon_minitimeThu Dec 14, 2017 4:54 pm by WV Hot Rod Rhino
My console in my rhino is getting very very hot but not overheating Icon_minitimeThu Dec 14, 2017 1:28 am by WV Hot Rod Rhino
My console in my rhino is getting very very hot but not overheating Icon_minitimeThu Dec 14, 2017 1:24 am by WV Hot Rod Rhino
My console in my rhino is getting very very hot but not overheating Icon_minitimeThu Dec 14, 2017 12:35 am by WV Hot Rod Rhino
My console in my rhino is getting very very hot but not overheating Icon_minitimeFri Dec 13, 2013 11:01 am by WV Hot Rod Rhino
My console in my rhino is getting very very hot but not overheating Icon_minitimeFri Dec 13, 2013 10:59 am by WV Hot Rod Rhino
My console in my rhino is getting very very hot but not overheating Icon_minitimeFri Dec 13, 2013 9:33 am by Tacoclaw
My console in my rhino is getting very very hot but not overheating Icon_minitimeFri Dec 13, 2013 7:50 am by chuddly
My console in my rhino is getting very very hot but not overheating Icon_minitimeFri Dec 13, 2013 7:47 am by chuddly
My console in my rhino is getting very very hot but not overheating Vote_lcapMy console in my rhino is getting very very hot but not overheating Voting_barMy console in my rhino is getting very very hot but not overheating Vote_rcap
no neutral light, no start. no ground?
Share
WVBobby
My console in my rhino is getting very very hot but not overheating Empty
PostSubject: My console in my rhino is getting very very hot but not overheating   My console in my rhino is getting very very hot but not overheating Icon_minitimeTue May 21, 2013 11:40 am
I have a 2009 Yamaha 700 Rhino,The console gets so hot it will burn your arm if you lay it on it and it smells like burning grease,I just had a friend replace the belt and clean all out and he bled the radiator,The radiator is not overheating,and I cant seam to find anyone that knows why this is happening.
Does anybody have any ideas?
PostSubject: Re: My console in my rhino is getting very very hot but not overheating   My console in my rhino is getting very very hot but not overheating Icon_minitimeTue May 21, 2013 12:30 pm
air locked,bad thermostat or radiator looks clean and it isnt....if radiator dosent get hot its air locked or thermostat is stuck....
2009 Yamaha Rhino 787
jamesbodyshop@hotmail.com
PostSubject: Re: My console in my rhino is getting very very hot but not overheating   My console in my rhino is getting very very hot but not overheating Icon_minitimeTue May 21, 2013 12:34 pm
first welcome to site , now you should post up in general or engine , make sure it bleed completely no air in cooling system
WVBobby
PostSubject: Re: My console in my rhino is getting very very hot but not overheating   My console in my rhino is getting very very hot but not overheating Icon_minitimeTue May 21, 2013 1:38 pm
My radiator is getting hot but the red light does not come on saying its overheating,fan ran for about 20 minutes after 9 mile road ride before it kicked off,Friend bled the radiator from both the waterpump and the bolt on top of engine.Radiator is flowing and hot.Couple of weeks ago I took the oil cooler off to aid in cleaning radiator,Could that have something to do with it?
Also where is the smell of the burning grease coming from?
The guy that replaced my belt and bled the radiator is very knowledgeable factory sponsored rhino racer.
PostSubject: Re: My console in my rhino is getting very very hot but not overheating   My console in my rhino is getting very very hot but not overheating Icon_minitimeTue May 21, 2013 1:55 pm
20 minutes idling..or motor off with the key on
WVBobby
PostSubject: Re: My console in my rhino is getting very very hot but not overheating   My console in my rhino is getting very very hot but not overheating Icon_minitimeTue May 21, 2013 1:57 pm
motor off key on
PostSubject: Re: My console in my rhino is getting very very hot but not overheating   My console in my rhino is getting very very hot but not overheating Icon_minitimeTue May 21, 2013 2:28 pm
How did you clean your radiator, pressure washer?
Dirt flies when you're having fun!
WVBobby
PostSubject: Re: My console in my rhino is getting very very hot but not overheating   My console in my rhino is getting very very hot but not overheating Icon_minitimeTue May 21, 2013 2:44 pm
Finn cleaner and pressure washer
PostSubject: Re: My console in my rhino is getting very very hot but not overheating   My console in my rhino is getting very very hot but not overheating Icon_minitimeTue May 21, 2013 2:58 pm
WVBobby wrote:
motor off key on
that only cools the radiator and the censor is in the head..thats why it ran so long
PostSubject: Re: My console in my rhino is getting very very hot but not overheating   My console in my rhino is getting very very hot but not overheating Icon_minitimeTue May 21, 2013 3:03 pm
Check the fins to see if they are bent over not allowing air to pass through.
I don't recommend using a pressure washer on any radiator or oil cooler.
RhinoGT350
RhinoGT350
PostSubject: Re: My console in my rhino is getting very very hot but not overheating   My console in my rhino is getting very very hot but not overheating Icon_minitimeTue May 21, 2013 6:35 pm
if your cooling system is air locked,,, would the air pocket be forced out by the pressure of the pump pumping the water? will the air pocket just stay there?
Rhinofire13
Rhinofire13
PostSubject: Re: My console in my rhino is getting very very hot but not overheating   My console in my rhino is getting very very hot but not overheating Icon_minitimeTue May 21, 2013 6:53 pm
Welcome to the site great place to find out info with awesome talent that is on here
Roof, Windshield, Backshield, STI wheels, Tusk tires,Tr-Fire CDI and Viper Winch Smile
PostSubject: Re: My console in my rhino is getting very very hot but not overheating   My console in my rhino is getting very very hot but not overheating Icon_minitimeTue May 21, 2013 6:59 pm
welcome man lotsa great help on this site
Yotehunter66
Moderator
Yotehunter66
PostSubject: Re: My console in my rhino is getting very very hot but not overheating   My console in my rhino is getting very very hot but not overheating Icon_minitimeTue May 21, 2013 9:03 pm
Welcome.
Kawasaki Prairie 400
Suzuki Ozark 250
Suzuki 230
My console in my rhino is getting very very hot but not overheating Avatar_17434
Workhorserhino
Workhorserhino
PostSubject: Re: My console in my rhino is getting very very hot but not overheating   My console in my rhino is getting very very hot but not overheating Icon_minitimeTue May 21, 2013 9:15 pm
I suggest using an airlift on the rad. It pulls a vacuum on the cooling sys. Then you close a valve and change hoses. Open valve Fill it from a bucket of clean antifreeze. The airlift removes all air from sys. I use it on every newer Int motor at work I have apart. Never a problem. If you need to find a local garage that uses one. If they look at you funny, walk away. They have needed these for at least 10 yrs. When it vacuums down and holds you know for sure your cooling sys is full, and no air in it.
JBS sheave w/16g weights -- Pwr steering -- am/fm radio -- 2nd Batt under hood -- Warn 3.5 winch -- homemade winch mount -- Progressive 425 shocks -- homemade frt skidplate -- frt & rear diff supports -- frt &rear a-arm supports -- homemade plow mount -- SS108 w/bajacross tires -- SS212 15" w/ 27" ultracross tires --  RDC 2" lift kit--        WOW this thing is expensive!!!
Posting by now talking to my new Galaxy S  active cell phone.
Workhorserhino
Workhorserhino
PostSubject: Re: My console in my rhino is getting very very hot but not overheating   My console in my rhino is getting very very hot but not overheating Icon_minitimeTue May 21, 2013 9:19 pm
You have to make the air pocket move. You do that by keeping rad full at all times while running motor with bleed screws open. If you run it the old way to get air out you risk damage. My first guess on a Rhino would be headgasket.
RhinoGT350
RhinoGT350
PostSubject: Re: My console in my rhino is getting very very hot but not overheating   My console in my rhino is getting very very hot but not overheating Icon_minitimeWed May 22, 2013 10:35 am
thanks workhorserhino
PostSubject: Re: My console in my rhino is getting very very hot but not overheating   My console in my rhino is getting very very hot but not overheating Icon_minitimeWed May 22, 2013 10:39 am
i bleed mine engine cold and not running
Snorider
PostSubject: Re: My console in my rhino is getting very very hot but not overheating   My console in my rhino is getting very very hot but not overheating Icon_minitimeMon Jun 03, 2013 1:38 am
pulling vacuum on the system is the best way to fill any system. works great and is fast and like you said no bubbles. I have had one for several years and man they are handy. it paid for itself the first time I had one to refill a bobcat cooling system. those used to be a pain in the freaking ass.
» Yamaha Rhino Cupholders
» Smith700's Rhino 700 thread
» Rhino dead
» Rhino easy-open hood mod
» rhino is pissing me off
HOTRODRHINOFORUMS.COM :: Members :: New Members-
