In total there are 6 users online :: 0 Registered, 0 Hidden and 6 Guests :: 2 Bots
 Question about tire size I can fit.
PostSubject: Question about tire size I can fit.   Tue May 21, 2013 12:45 pm
I have 26x9-14 and 26x11-14 Big Horns now and I am thinking about going to 28x10-14's all the way around and my question is can I run those on my Rhino without any other suspension work or will they rub.
27" EFX Motoclaws
JE 11:1 102mm
Warn Pro Vantage 3500lb.
Ricochet a-arm skids
PRM bash plate
Unisteer Rackzilla
PostSubject: Re: Question about tire size I can fit.   Tue May 21, 2013 12:48 pm
depemds on what 28s your looking at. some 28s run 27 some 28s run closer to 29. either way 28s should clear on a stock rhino. the bigger ones may rub every now and then. i ran 28x11 titan 589s stock and never hit anything but the titans run short.
PostSubject: Re: Question about tire size I can fit.   Tue May 21, 2013 12:54 pm
I don't think I would try the 28's without a 2 in lift. With the 26 in You have on it right now, turn Your front wheels all the way left or right and see how much clearance You have between tire and floorboard.
2014 RZR 800 S Indy Red
SOLD
PostSubject: Re: Question about tire size I can fit.   Tue May 21, 2013 3:14 pm
I'm looking at the 28" GBC Mongrels. I haven't done much looking into lifting my Rhino, how is that going to affect stability. Will it feel more top heavy.
27" EFX Motoclaws
JE 11:1 102mm
PRM bash plate
Unisteer Rackzilla
PostSubject: Re: Question about tire size I can fit.   Tue May 21, 2013 4:07 pm
My 28's rub when I turned hard with my 2" lift. But they did measure almost 29"s. measure the tires after inflated. If they 28"s then you will only rub when you turn and hit bumps. If they over they will rub harder. Look on ebay and order the 2" lift for around $50. Cheap, easy and saves everything plus no strain on the axles.
2009 Rhino SE Red  SOLD SOLD
Workhorserhino
PostSubject: Re: Question about tire size I can fit.   Tue May 21, 2013 9:37 pm
I just put a rubberdowncustoms.com 2" lift on mine about a month ago. theres a topic on here with pics of the install, with 27" ultracross on it. The front should be be fine, the rear is close. I haven't noticed it to be more top heavy or tippy than before. I went with the RDC lift for stability reasons. I liked the way the front installed versus the cheaper lift.
JBS sheave w/16g weights -- Pwr steering -- am/fm radio -- 2nd Batt under hood -- Warn 3.5 winch -- homemade winch mount -- Progressive 425 shocks -- homemade frt skidplate -- frt & rear diff supports -- frt &rear a-arm supports -- homemade plow mount -- SS108 w/bajacross tires -- SS212 15" w/ 27" ultracross tires --  RDC 2" lift kit--        WOW this thing is expensive!!!
Posting by now talking to my new Galaxy S  active cell phone.
PostSubject: Re: Question about tire size I can fit.   Tue May 21, 2013 9:43 pm
I run 27" mudlites with 2" lift and have lots of room for more
PostSubject: Re: Question about tire size I can fit.   Fri May 24, 2013 12:05 pm
always been afraid of going any bigger because of the middle gear issues they have
bricemcpheeters
PostSubject: Re: Question about tire size I can fit.   Fri May 24, 2013 1:01 pm
28 10 14 may be close. I had 27" mudlites without a lift and when tweaked it came real close to rubbing. You can probably run them but it may rub in certain off camber situations.
Obviously a 28" Outlaw would be different than a 28" oem though lol
Get the 2" lift. I was worried as well, never any issues since. You can clear 30's
corylmack
PostSubject: Re: Question about tire size I can fit.   Mon Jun 24, 2013 11:57 pm
my 28'' outlaw 2's were rubbing even with my 2'' lift. this was my solution a little cutting here and there.
before cutting with my 27'' STI Roctane xd
after cutting with my 28'' outlaw 2
here is a pic of the inside
2008 Rhino 700, JBS Sheave, purple spring and 18g weights, progressive 425 shocks, 2'' lift, custom bed delete, rzr seats, 28" Outlaw 2s, 27" STI Roctane XD
Guenther
PostSubject: Re: Question about tire size I can fit.   Tue Jun 25, 2013 10:08 am
That's a pretty good idea, and neatly done. Nice job.  I have a 2" lift and I do not find it top heavy by any means.  Still has a quite stable ride and feel as well.  There is also a 3" lift out there.  I amy be going to change over to, still deciding on that.  You can get a 2" lift for quite a reasonable price and they're relatively simple to install.
2008 Yamaha Rhino 700, Moose Roof, folding windshield, 4k# Warn Winch, Full Warn Skids, Dynatech Ignition, Machined Sheave, 2" lift, 12 DWT Diablo Bead locks,26 GBC Grim Reapers. Dancing Banana
PostSubject: Re: Question about tire size I can fit.   Tue Jun 25, 2013 11:27 am
I don't want to do any cutting and I am going to swap to some 28" Mongrels as soon as I finish off my 26" Big Horns so it looks like a 2" lift for me.
27" EFX Motoclaws
JE 11:1 102mm
PRM bash plate
Unisteer Rackzilla
