| brake caliper rear | |
jaydog13
| Subject: brake caliper rear Fri May 24, 2013 9:09 pm | |
| Does the rear brake caliper cyclinder go all the way i like a car or stick out about 1 " .I'm changeong rear brake pads and I can't get yge cyclinder all the way in | |
| Subject: Re: brake caliper rear Fri May 24, 2013 9:15 pm | |
| just done mine last week the floater pin on one side was froze up took a while working at it to get apart then cleaned an greased worked great then, may check yours | |
Wingman
| Subject: Re: brake caliper rear Fri May 24, 2013 9:31 pm | |
| You are screwing it in and not trying to press it in!! | |
| Subject: Re: brake caliper rear Fri May 24, 2013 9:38 pm | |
| skip what I said missed the caliper cylinder part so probably not the pins on yours , wing man right about it screwing in | |
jaydog13
| Subject: Re: brake caliper rear Fri May 24, 2013 9:55 pm | |
| Yes screwing it and it just wont go no future | |
| Subject: Re: brake caliper rear Sat May 25, 2013 6:29 pm | |
| is the caliper free to move on the pins | |
| Subject: Re: brake caliper rear Sat May 25, 2013 6:49 pm | |
| The piston screws all the way in flush with the housing. | |
| Subject: Re: brake caliper rear Sat May 25, 2013 8:14 pm | |
| may be dirty behind piston on the treads , have to keep working it to get free | |
| Subject: Re: brake caliper rear Sat May 25, 2013 11:06 pm | |
| Remove the screw if you can inspect the o ring for damage and make sure its clean and lubed.When the caliper and pad are installed adjust the screw so the rotor will not turn then just back off till the rotor turns, and tighten the locknut
Last edited by 123.bert0621 on Mon May 27, 2013 8:50 am; edited 1 time in total (Reason for editing : SORRY THIS IS THE PARKING BRAKE.) | |
inyourneck2004
Posts : 1 Join date : 2013-05-27
| Subject: Re: brake caliper rear Mon May 27, 2013 1:20 am | |
| how in the world do ya free up the slider pin that has the allen screw on to it? | |
| Subject: Re: brake caliper rear Mon May 27, 2013 1:40 am | |
| I had to keep working mine back an forth using wd-40 over an over then got brass drift an hammer to convince it to move, the clean shit out of it | |
| Subject: Re: brake caliper rear | |
