700 Water Pump Issue ... Overheating  Icon_minitimeThu Dec 14, 2017 4:54 pm by WV Hot Rod Rhino
700 Water Pump Issue ... Overheating  Icon_minitimeThu Dec 14, 2017 1:28 am by WV Hot Rod Rhino
700 Water Pump Issue ... Overheating  Icon_minitimeThu Dec 14, 2017 1:24 am by WV Hot Rod Rhino
700 Water Pump Issue ... Overheating  Icon_minitimeThu Dec 14, 2017 12:35 am by WV Hot Rod Rhino
700 Water Pump Issue ... Overheating  Icon_minitimeFri Dec 13, 2013 11:01 am by WV Hot Rod Rhino
700 Water Pump Issue ... Overheating  Icon_minitimeFri Dec 13, 2013 10:59 am by WV Hot Rod Rhino
700 Water Pump Issue ... Overheating  Icon_minitimeFri Dec 13, 2013 9:33 am by Tacoclaw
700 Water Pump Issue ... Overheating  Icon_minitimeFri Dec 13, 2013 7:50 am by chuddly
700 Water Pump Issue ... Overheating  Icon_minitimeFri Dec 13, 2013 7:47 am by chuddly
700 Water Pump Issue ... Overheating  Vote_lcap700 Water Pump Issue ... Overheating  Voting_bar700 Water Pump Issue ... Overheating  Vote_rcap
Share
700 Water Pump Issue ... Overheating  Empty
PostSubject: 700 Water Pump Issue ... Overheating    700 Water Pump Issue ... Overheating  Icon_minitimeMon Mar 11, 2013 6:29 pm
On our last ride we started overheating for the 3rd time in 9000 miles (1st time the radiator was clogged & the 2nd was a spark plug issue) It got so hot it warped the thermostat & ruined the spring on the radiator cap. After that I had to run my fan over ride the whole time to keep the temp below 140 so it wouldn't build enough pressure to push it out the overflow.The less the RPM's were the more it overheat. It would overheat super quick at an idle. Wanted to share ... here's a pic.
700 Water Pump Issue ... Overheating  DSC01982
» Another water pump seal gone bad
» ThunderCat Water Pump Recall
» Highbanker + water pump legal?
» RZR Water Pump Seal Leaking
» Water pump seal
