Who is online? | In total there are 35 users online :: 0 Registered, 0 Hidden and 35 Guests :: 3 Bots None Most users ever online was 207 on Tue Jun 11, 2013 11:13 pm |
| | 2009 700 rhino wont start in gear | |
WVBobby
Posts : 10 Join date : 2013-05-21 Age : 61 Location : Parkersburg
| Subject: 2009 700 rhino wont start in gear Mon Aug 26, 2013 4:43 pm | |
| My rhino wont start in gear but will if I put in neutral,How do I know which switch is bad and where is it? | |
| | | Workhorserhino
| Subject: Re: 2009 700 rhino wont start in gear Mon Aug 26, 2013 4:48 pm | |
| When in gear are you stepping on the brake pedal. Then it should start. | |
| | | WVBobby
| Subject: Re: 2009 700 rhino wont start in gear Mon Aug 26, 2013 4:50 pm | |
| yes stepping on brake pedal. | |
| | | Workhorserhino
| Subject: Re: 2009 700 rhino wont start in gear Mon Aug 26, 2013 4:57 pm | |
| Check the brake switch. Right below master cyl it should make the brake lights come on also. it threads in and out to adjust it. or the switch or wiring is bad. | |
| | | WVBobby
| Subject: Re: 2009 700 rhino wont start in gear Mon Aug 26, 2013 5:02 pm | |
| So if my brake lights are working it's not that switch? | |
| | | SteveS
Posts : 430 Join date : 2013-03-10 Age : 76 Location : Portland, OR
| Subject: Re: 2009 700 rhino wont start in gear Mon Aug 26, 2013 5:41 pm | |
| - WVBobby wrote:
- So if my brake lights are working it's not that switch?
Yes, that is correct. | |
| | | WVBobby
| Subject: Re: 2009 700 rhino wont start in gear Tue Aug 27, 2013 9:12 am | |
| Thanks guys, Thank you very much,checked it out last night,found the switch and screwed it in,no help,unscrewed it, checked it out and works great. What a simple fix,but wouldn't have known if this site was not here. Thanks again. Awesome site. | |
| | | WV Hot Rod Rhino Admin
| Subject: Re: 2009 700 rhino wont start in gear Tue Aug 27, 2013 10:25 am | |
| Subject: Re: 2009 700 rhino wont start in gear | |
