Who is online? | In total there are 22 users online :: 0 Registered, 0 Hidden and 22 Guests :: 2 Bots None Most users ever online was 207 on Tue Jun 11, 2013 11:13 pm |
| | jmp30s Rhino | |
Posts : 455 Join date : 2013-06-06 Age : 37 Location : Harrison Arkansas
 | Subject: Re: jmp30s Rhino Tue Oct 08, 2013 4:40 pm | |
| Looks Awesome man I am a camo man with black wheels as well!! I am pretty sure those are the next tires I will buy myself they look sweet! _________________ 2012 Rhino 734cc Camo with JE 105.5mm 10:1 piston & Stage 2 Hotcam JBS Sheave w/ 15gr od's & Gold spring and slugged wet clutch Alba exhaust, Trailbright 30" LED bar w/10w cree bulbs 14" MSA M12 Diesel wheels & 27" ITP Blackwater Evo. Dynatek CDI & Performance coil, Bazzaz Z-FI & Z-AFM, AEM A/F gauge, Elka custom shocks, EMP rear bumper, Savant front bumper Warn 30RT winch, VDP Ipod Stereo with 200 watt amp Kolpin Over fender kit, Seizmik front rack DG Inner fender guards, Master cylinder guard, Coolant guard, & radiator guard JBS front and rear bash plates and JBS radiator shields Pro Armor 4 points and Speed Ind. harness bar
|  | | rhino727
Posts : 1317 Join date : 2013-03-25 Age : 53 Location : musella,Ga.
 | Subject: Re: jmp30s Rhino Tue Oct 08, 2013 5:41 pm | |
| _________________ 2007 Special Edition 660, Hotrods crank 4mm stroker , wiseco 2mm over 10/1 piston, new head ported +2 valves, mudbuster cam, billet middle gear support, JBS sheave 14g with purple spring an friction washers , new wet clutch + 6g lead, Gibson header&muffler,4000lbs winch,26 in mud-lites ,3in lift, snorkeled, dyna jet kit, K&N air filter with pro-flow adapter, floorboard guards, radiator guards, fender flares
|  | | jmp30
 | Subject: Re: jmp30s Rhino Wed Oct 09, 2013 4:55 pm | |
| Thanks for the compliments guys. Now that wheels, tires, winch, bumper and storage are taken care of......I'm on to a top, bumper lights, half windshield and some clutch work.
Anyone have any suggestions on bumper lights?. I want some halogens to match the factory lights and that will mount using the stock locations on my Yamaha brush bumper. I don't need to light up the world, just a little something to compliment my factory headlights and that my Rhino will power with no issues. _________________ 2013 Realtree Rhino
|  | | jmp30
 | Subject: Re: jmp30s Rhino Wed Oct 09, 2013 4:57 pm | |
| - thekevin wrote:
- Good choice on tires. You need to get a top for that bad boy.
Agreed.....probably a EMP metal roof at some point. _________________ 2013 Realtree Rhino
|  | | thePayne
 | Subject: Re: jmp30s Rhino Wed Oct 09, 2013 5:06 pm | |
| - jmp30 wrote:
- Thanks for the compliments guys. Now that wheels, tires, winch, bumper and storage are taken care of......I'm on to a top, bumper lights, half windshield and some clutch work.
I run these Warn ones and love them they blend right in with OEM headlight bulbs just add more light further out but I switched to PIA headlight bulbs and they are more white light so I may do a LED bar now. These are nice lights though and they fit in my bumper holes perfect. http://www.warn.com/atv/lights/W200XT-S_Spot_Beams.shtml[img]  [/img] _________________ 2012 Rhino 734cc Camo with JE 105.5mm 10:1 piston & Stage 2 Hotcam JBS Sheave w/ 15gr od's & Gold spring and slugged wet clutch Alba exhaust, Trailbright 30" LED bar w/10w cree bulbs 14" MSA M12 Diesel wheels & 27" ITP Blackwater Evo. Dynatek CDI & Performance coil, Bazzaz Z-FI & Z-AFM, AEM A/F gauge, Elka custom shocks, EMP rear bumper, Savant front bumper Warn 30RT winch, VDP Ipod Stereo with 200 watt amp Kolpin Over fender kit, Seizmik front rack DG Inner fender guards, Master cylinder guard, Coolant guard, & radiator guard JBS front and rear bash plates and JBS radiator shields Pro Armor 4 points and Speed Ind. harness bar
|  | | mike734
Posts : 681 Join date : 2013-04-30 Age : 40 Location : Limerick P.A.
 | Subject: Re: jmp30s Rhino Wed Oct 09, 2013 5:23 pm | |
| lookin good. get that thing muddy already! _________________ If you can`t drive over it or thru it ....JUMP IT!
07 660 , jbs sheave , 2" cfm lift , 28x11x12 ITP Mega Mayhems mounted on black MSA M17`s , warn bumper , warn rt30 , str8up motorsports family cage , emp in dash radio , full snorkles , more to come....
|  | | thePayne
 | Subject: Re: jmp30s Rhino Wed Oct 09, 2013 5:25 pm | |
| - mike734 wrote:
- lookin good. get that thing muddy already!
It is now Mike I promise........ _________________ 2012 Rhino 734cc Camo with JE 105.5mm 10:1 piston & Stage 2 Hotcam JBS Sheave w/ 15gr od's & Gold spring and slugged wet clutch Alba exhaust, Trailbright 30" LED bar w/10w cree bulbs 14" MSA M12 Diesel wheels & 27" ITP Blackwater Evo. Dynatek CDI & Performance coil, Bazzaz Z-FI & Z-AFM, AEM A/F gauge, Elka custom shocks, EMP rear bumper, Savant front bumper Warn 30RT winch, VDP Ipod Stereo with 200 watt amp Kolpin Over fender kit, Seizmik front rack DG Inner fender guards, Master cylinder guard, Coolant guard, & radiator guard JBS front and rear bash plates and JBS radiator shields Pro Armor 4 points and Speed Ind. harness bar
|  | | madmax 1
Posts : 1743 Join date : 2013-03-10 Age : 52 Location : frostburg md
 | Subject: Re: jmp30s Rhino Fri Oct 11, 2013 10:03 pm | |
| - thePayne wrote:
Anyone have any suggestions on bumper lights?. I want some halogens to match the factory lights and that will mount using the stock locations on my Yamaha brush bumper. I don't need to light up the world, just a little something to compliment my factory headlights and that my Rhino will power with no issues. I run these Warn ones and love them they blend right in with OEM headlight bulbs just add more light further out but I switched to PIA headlight bulbs and they are more white light so I may do a LED bar now. These are nice lights though and they fit in my bumper holes perfect. http://www.warn.com/atv/lights/W200XT-S_Spot_Beams.shtml
if you do ANY nite ridin , then a led bar is a must for the money and the amp draw you can't beat them my 40 double row is WOW  BRIGHT _________________ 07 camo 660, hmf pipe, k&n filter, dynatec cdi, jet kit, montana jack f&r winch mount w/warn xt40, 27" mudlites, hids, leds, 2" lift cab w/ heat, j strong half doors for summer, aux red top optima for accessories, roof rack , 5 bad ass jrt's on board, itp ss212's, jbs sheeve,14gr wts., orange spring,40" led litebar, autometer guages, equus tach, innovate afm Jensen ms30, jbl 6.5's, elka stage 1 shocks, kenwood 2way radio
|  | | Jet
Posts : 594 Join date : 2013-03-31 Age : 67 Location : Canal Winchester Ohio 43110
 | Subject: Re: jmp30s Rhino Fri Oct 11, 2013 10:31 pm | |
| Sweeeeeeet. !!!!!! _________________
Dave
(Hailey on left and Molly)2013 Tactical Black Rhino and Powered by JBS. |
|  | | 123.bert0621
Posts : 1464 Join date : 2013-03-18 Age : 58 Location : Western Quebec
 | Subject: Re: jmp30s Rhino Fri Oct 11, 2013 10:35 pm | |
| I will get a bigger light when the I can, I was impressed with my smaller one so a 40" would be crazy. _________________ 2008 Sport Edition 700,MSD fuel controller,Brink Enterprise floor guards,RMstator,Tusk rear window,1/2 windshield,hid's,on board compressor,airhorn,K&N,Traxion Grippers,Sirius XM, EBC severe duty brakes,Baja mirrors, Warn RT 30 winch,LED box lights.2"rear spacers,2"lift,no rear sway bar,fender flares, VDP Stereo,homemade rear bumper,Axia black stainless epoxy tip,JBS sheave OD-18gr,purple spring,anti-friction washers,10"LED.Hot rod rear aluminium skid plate, RZR seats. I see a lot of feathers but not much chicken !!!!!!!!
|  | | REDRHINO64
Posts : 1649 Join date : 2013-03-10 Age : 53 Location : Asheboro N.C./Mountain Top West By God Virginia
 | Subject: Re: jmp30s Rhino Fri Oct 11, 2013 10:38 pm | |
| Nice rhino! _________________ 2007 rhino,720cc,Falicon super crank,JE 10:75:1 piston,stage 1 raptor cam,Bored Fcr 43mm carb,unifilter,muzzys,Jbs sheave and 14 gram Ods,orange spring,anti friction washers,slugged clutch,Jbs roof,Jbs radiator shields,jbs sticker=10hp,full windshield,siesmik doors,Se shocks,Summit heater,5000lb winch,Power steering,tach and guages,2 way radio,mp3 to 400 watt amp,4 polk speakers,4 Hid lights,alternator,and the list goes on!!
|  | | thePayne
 | Subject: Re: jmp30s Rhino Fri Oct 11, 2013 11:06 pm | |
| Me and flimmy have already been talking about it!! _________________ 2012 Rhino 734cc Camo with JE 105.5mm 10:1 piston & Stage 2 Hotcam JBS Sheave w/ 15gr od's & Gold spring and slugged wet clutch Alba exhaust, Trailbright 30" LED bar w/10w cree bulbs 14" MSA M12 Diesel wheels & 27" ITP Blackwater Evo. Dynatek CDI & Performance coil, Bazzaz Z-FI & Z-AFM, AEM A/F gauge, Elka custom shocks, EMP rear bumper, Savant front bumper Warn 30RT winch, VDP Ipod Stereo with 200 watt amp Kolpin Over fender kit, Seizmik front rack DG Inner fender guards, Master cylinder guard, Coolant guard, & radiator guard JBS front and rear bash plates and JBS radiator shields Pro Armor 4 points and Speed Ind. harness bar
|  | | jmp30
 | Subject: Re: jmp30s Rhino Tue Dec 10, 2013 2:04 pm | |
| Just an update on my ride....I ordered some Hella 55W lights for the front and a Daystar illuminated switch to try and match my Warn switch. I then ordered some EMP mounts however dummy me I ordered 1 1/2 inch clamps instead of 1 3/4. Then I figured I would try and order something that is a little more beefy as added insurance that my lights would not rattle or bounce around on my so I ordered Tusk 1/34 inch flag mounts. They fit on the Bumper like a charm and hold the lights good but now I cannot open my hood because of how far back the lights sit from my bumper....RRRRR. Ordered some EMP 1 3/4 light mounts that I am going to modify just a tad and hope they will work.
Also I got a surprise package today from EMP that is rather large. When I know that I didn't order anything that would need to be in such a large box I ask my wife if she did. The reply I got was "Not until Christmas." Seeming as I mentioned that I wanted a roof for the Rhino I am hoping that is what is inside.
Hopefully my light mounts show up this week and I have lights by this weekend. Stay tuned.
This is the look I am going for with my lights..............
|  | | thePayne
 | Subject: Re: jmp30s Rhino Tue Dec 10, 2013 2:09 pm | |
| Keep up the good work its coming along now! _________________ 2012 Rhino 734cc Camo with JE 105.5mm 10:1 piston & Stage 2 Hotcam JBS Sheave w/ 15gr od's & Gold spring and slugged wet clutch Alba exhaust, Trailbright 30" LED bar w/10w cree bulbs 14" MSA M12 Diesel wheels & 27" ITP Blackwater Evo. Dynatek CDI & Performance coil, Bazzaz Z-FI & Z-AFM, AEM A/F gauge, Elka custom shocks, EMP rear bumper, Savant front bumper Warn 30RT winch, VDP Ipod Stereo with 200 watt amp Kolpin Over fender kit, Seizmik front rack DG Inner fender guards, Master cylinder guard, Coolant guard, & radiator guard JBS front and rear bash plates and JBS radiator shields Pro Armor 4 points and Speed Ind. harness bar
|  | | Crusty
Posts : 431 Join date : 2013-08-10 Age : 48 Location : Woods Cross Utah
 | Subject: Re: jmp30s Rhino Tue Dec 10, 2013 2:30 pm | |
| I also use the Tusk flag mounts for my lights on my bumper and have the tab facing forward and am able to open my hood but you have a different bumper.  _________________  It's not that wide but it sure is short! |
|  | | Sponsored content
 | Subject: Re: jmp30s Rhino  | |
|  | | | jmp30s Rhino | |
