| Brute Force Wheels on a Rhino | |
renegademxz
Posts : 20 Join date : 2013-06-07 Age : 46 Location : Saskatchewan
| Subject: Brute Force Wheels on a Rhino Fri Aug 09, 2013 12:43 am | |
| I found an awesome deal on a new take off set of factory Brute Force rims with tires. I know the bolt pattern (4 x 110mm) is the same but is the offset the same and will they fit on Rhino? What about wheel nuts? Any one know??? | |
| Subject: Re: Brute Force Wheels on a Rhino Fri Aug 09, 2013 8:42 am | |
| I think they are the same off set 5+2,Force and Rhino,5" inside towards the frame and 2" outside facing you. | |
| Subject: Re: Brute Force Wheels on a Rhino Fri Aug 09, 2013 12:28 pm | |
| bolt pattern is the same, but sure about the stock rim offset. I swapped rims and tires with my pops and he has a brute.... | |
| Subject: Re: Brute Force Wheels on a Rhino Fri Aug 09, 2013 12:30 pm | |
| [url= ] | |
| Subject: Re: Brute Force Wheels on a Rhino Fri Aug 09, 2013 1:12 pm | |
| Wow what a transformation,looks like your ready for some mud now:!: | |
| Subject: Re: Brute Force Wheels on a Rhino Fri Aug 09, 2013 5:15 pm | |
| Lol if I could get it to run right | |
| Subject: Re: Brute Force Wheels on a Rhino Fri Aug 09, 2013 5:27 pm | |
| You installed spacers? I couldn't install factory brute wheels on mine without spacers!! | |
| Subject: Re: Brute Force Wheels on a Rhino Fri Aug 09, 2013 6:37 pm | |
| - 09-rhino700 wrote:
- [url=]
Looks great!! | |
| my dad's are not stock, the ones in the pic are maxxis 4x4 rims | |
| Subject: Re: Brute Force Wheels on a Rhino Fri Aug 09, 2013 9:29 pm | |
| That makes sense why Eric could not fit the OEM wheels on his Rhino,the off set must be different than the spec I had. The off set may be stamped into the wheels. | |
| Subject: Re: Brute Force Wheels on a Rhino Mon Aug 12, 2013 2:30 pm | |
| So it's not stock brute wheels?? Got ya. I tried stock brute wheels. | |
renegademxz
| Subject: Re: Brute Force Wheels on a Rhino Wed Aug 14, 2013 1:44 am | |
| These are the cast aluminum 6 spoke black wheels I believe they are a 5+2 offset just like the stock SE Yamaha rims so I am pretty sure they will fit. | |
| Subject: Re: Brute Force Wheels on a Rhino | |
