Who is online? | In total there are 42 users online :: 0 Registered, 0 Hidden and 42 Guests None Most users ever online was 207 on Tue Jun 11, 2013 11:13 pm |
| | Engine Swap on Rhino 450 to 660 | |
| Subject: Engine Swap on Rhino 450 to 660 Tue Sep 24, 2013 9:07 pm | |
| | | Hump
| Subject: Re: Engine Swap on Rhino 450 to 660 Wed Sep 25, 2013 3:33 am | |
| From what I understand the gear diference is in the trans gears not the front and rear diffs. Don't know if they will change out or not. As for swapping in the 660, it seems to me that it couldn't be to bad. I thought about all of that when I had my 450. After riding it for 4 yrs and getting offered 5k trade in, I had to let her go. I still wonder how good a 450 can run with some port work, cam, piston, and bigger carb. | |
| | | Kenny G
| Subject: Re: Engine Swap on Rhino 450 to 660 Wed Sep 25, 2013 8:19 pm | |
| Any motor builders out there that have any ideas. Whatzz you say James? | |
| | | Big Dog Daddy
Posts : 152 Join date : 2013-03-11 Age : 65 Location : Kentucky
| Subject: Re: Engine Swap on Rhino 450 to 660 Wed Sep 25, 2013 8:23 pm | |
| - Kenny G wrote:
- Any motor builders out there that have any ideas. Whatzz you say James?
X2 | |
| | | Kenny G
| Subject: Re: Engine Swap on Rhino 450 to 660 Wed Sep 25, 2013 10:14 pm | |
| I'm starting to think if the 660 engine basically could be dropped into the 450 geared chassis you'd still not get the lower geared 450 with bigger displacement. Because the lowered gearing is in the 450's engine anyway, so all you'd end up with is a 660 engine in a 450 chassis, and it'd respond the same as a 660, nothing magic about that. Whatzz ya say?????? | |
| | | UnderDawg
| Subject: Re: Engine Swap on Rhino 450 to 660 Thu Sep 26, 2013 12:07 am | |
| Kenny,I believe your assessment to be correct... I also think my Kodiak is geared lower than my Rhino. | |
| | | rhino727
| Subject: Re: Engine Swap on Rhino 450 to 660 Thu Sep 26, 2013 10:47 am | |
| the big question is if the 450 transfer gears will fit the 660 ? if so I see more bottom end back for the ones running the bigger heaver tires . the only thing is if your not doing a case split already what a job just to change the gears | |
| Subject: Re: Engine Swap on Rhino 450 to 660 | |
