In total there are 7 users online :: 0 Registered, 0 Hidden and 7 Guests :: 2 Bots
Go to page : Previous  1, 2, 3, 4, 5, 6, 7, 8, 9, 10  Next
PostSubject: Re: ALBA 734 Big Bore for 2011 Rhino 700   Thu Mar 21, 2013 9:55 pm
cant wait to see it in action!!!
2009 Yamaha Rhino 787
jamesbodyshop@hotmail.com
PostSubject: Re: ALBA 734 Big Bore for 2011 Rhino 700   Fri Mar 22, 2013 5:20 am
Just a quick update:
I got the correct rings from Alba
Got everything together
I just fired it up for a couple of minutes in my garage. The motor popped right off when I hit the starter. I didn't hear any weird noises on the initial startup. I have a few odds and ends I need to get tied up, but I hope this is a good sign. Time will tell. It's way too early in the game to do a victory dance!
I have to give a shout out to James of JBS. He talked me through the piston and cylinder instal. I didn't even buy this kit from James and he gave me 20 minutes of his time to answer my dumb questions. Ha! Thanks James!
Now that this motor is brand new fresh on the top end, what steps to I need to take to make sure everything is broken in and seated properly? What to I need to keep an eye on. I don't trust this thing yet... LoL
2011 Rhino 734 Sport
2014 Teryx4 800 LE
4500lb Warn
PostSubject: Re: ALBA 734 Big Bore for 2011 Rhino 700   Fri Mar 22, 2013 9:07 am
no syn oil for 600 miles.....we also pull the spark plug on a fresh rebuild and loosen the oil line on top and turn the motor over till we have oil up there then fire it up....forgot to tell you about that...but now its here to stay for people to read.....
PostSubject: Re: ALBA 734 Big Bore for 2011 Rhino 700   Fri Mar 22, 2013 10:27 am
I did cycle the starter without the spark plug before actually trying to start the motor. Good tip about the oil line though.
And by the way, your advice on putting the piston in the cylinder and then connecting the piston to the rod worked like a champ!
2014 Teryx4 800 LE
4500lb Warn
PostSubject: Re: ALBA 734 Big Bore for 2011 Rhino 700   Fri Mar 22, 2013 10:48 am
run it through a few heat/cool down cycles to seat the rings.
(let it warm up and then shut it down and let it cool for couple of hours)
after you get it on the trail, don't over-rev it, but keep the revs moving up and down and don't lug the engine. (don't put a lot of stress on it at low revs).
congrats for getin' er done! that's a big accomplishment! bounce
JBS
PostSubject: Re: ALBA 734 Big Bore for 2011 Rhino 700   Fri Mar 22, 2013 11:24 am
You guys aren't going to believe what just came in the mail today...
I just don't know what to say....
2014 Teryx4 800 LE
4500lb Warn
PostSubject: Re: ALBA 734 Big Bore for 2011 Rhino 700   Fri Mar 22, 2013 11:27 am
that sux!!!.........let me know if there is anything i can do
PostSubject: Re: ALBA 734 Big Bore for 2011 Rhino 700   Fri Mar 22, 2013 11:28 am
Is it too early to have a drink?
2014 Teryx4 800 LE
4500lb Warn
PostSubject: Re: ALBA 734 Big Bore for 2011 Rhino 700   Fri Mar 22, 2013 11:39 am
sounds like you might get some money back to me.
JBS
PostSubject: Re: ALBA 734 Big Bore for 2011 Rhino 700   Fri Mar 22, 2013 12:14 pm
WOW...that sucks big time
2006 Rhino 660
HID conversion
Quick detach snow plow
extended roll cage
4 point harnesses
Hunterworks CDI
700 belt
JBS sheave
14g weights
Purple spring
Mods in progress -
PostSubject: Re: ALBA 734 Big Bore for 2011 Rhino 700   Fri Mar 22, 2013 1:22 pm
What should I do?
I have run the motor, not much like a few minutes tops, but the motor has run been run with the wrong oil rings.
What about my gaskets and Weller head and cylinder studs; can those be reused when I go back into the motor?
I'm a very patient man. But even this has got me frustrated. My faith in CP is not real strong. I'm hoping that Alba can make help this right.
2014 Teryx4 800 LE
4500lb Warn
PostSubject: Re: ALBA 734 Big Bore for 2011 Rhino 700   Fri Mar 22, 2013 1:45 pm
gaskets should be replaced...studs would be fine. At this point I dont think any of our faith in them is real strong. Im even questioning if they know if they sent you the wrong ring????
2006 Rhino 660
HID conversion
extended roll cage
4 point harnesses
Hunterworks CDI
700 belt
JBS sheave
14g weights
Purple spring
Mods in progress -
PostSubject: Re: ALBA 734 Big Bore for 2011 Rhino 700   Fri Mar 22, 2013 1:46 pm
I would think the head studs should be fine and see if CP or who ever sent the wrong rings should reimburse you for the gaskets atleast.
Just think your going to be a pro at this by the time your done. Can I bring my motor over Laughing
Owner of
www.trailbrightled.com
Moto Alliance dealer
Pro Armor dealer
Rocky Mountain ATV dealer
PostSubject: Re: ALBA 734 Big Bore for 2011 Rhino 700   Fri Mar 22, 2013 2:32 pm
I called Alba this morning at 9a Pacific Time.
Nate could not believe this fiasco. Alba has never charged me for any of the rings I've received nor for any of the shipping. Remember, I was the one who broke a ring on installation resulting in all this mess.
I wonder if my original rings were even correct???
CP is supposed to be better than this, right? Why didn't they call me when they realized they sent the wrong rings overnight... I mean they had to have figured it out because they then early morning overnight shipped this latest package of oil rings.
2014 Teryx4 800 LE
4500lb Warn
PostSubject: Re: ALBA 734 Big Bore for 2011 Rhino 700   Fri Mar 22, 2013 2:40 pm
Do you still have the first one you put in ? What color was the dot on it ?
Alba has proven themselves as a great co.
and yeah I think the first thing CP should have done is give you a call. I'm guessing they had your # too
Owner of
Pro Armor dealer
mnormand
PostSubject: Re: ALBA 734 Big Bore for 2011 Rhino 700   Fri Mar 22, 2013 4:59 pm
PostSubject: Re: ALBA 734 Big Bore for 2011 Rhino 700   Fri Mar 22, 2013 5:38 pm
...alba is great to deal with but shit happens sometimes that cant be controlled....sux when it does..and like they say when it rains it pours!!
PostSubject: Re: ALBA 734 Big Bore for 2011 Rhino 700   Fri Mar 22, 2013 7:16 pm
Dang Chris,sounds like some of my luck...Cant believe it!!
PostSubject: Re: ALBA 734 Big Bore for 2011 Rhino 700   Fri Mar 22, 2013 9:02 pm
Nate from Alba got back in touch with me about this piston oil ring fiasco.
In short: he told me that I had the correct rings in my motor. He called CP and their shipping thought they sent me the wrong rings and then sent me another set of oil rings (which showed up at my house). Alba assured me that I had the right rings in my motor. This is the craziest story I've heard about parts and shipping.
Another thing I figured out - my original set of oil rings were incorrect. I don't know if that was what was causing my problems with installation that lead to a broken ring or what... I'll never know.
CP has got to get their stuff together! Alba has really stepped up and taken care of me and covered for a lot of CP's mistakes. If Alba had not have been so good to me, I would have been very displeased.
I have an oil leak I'm trying to address near the cylinder base gasket area. It's dripping down the timing chain side on to the area where the oil lines connect to the block. I'm guessing the new base gasket isn't sealing correctly.
Thanks, guys, for all your help and support.
2014 Teryx4 800 LE
4500lb Warn
PostSubject: Re: ALBA 734 Big Bore for 2011 Rhino 700   Fri Mar 22, 2013 9:09 pm
Dang..good news,then bad news..hope you get it fixed!!
PostSubject: Re: ALBA 734 Big Bore for 2011 Rhino 700   Fri Mar 22, 2013 9:16 pm
When i put mine together,i put a drop of oil on each of the cylinder studs,torqued to 45ft lbs each..let it sit for about 15 miniutes then re torqued all 4 cylinder studs again..then put the head on and did the same on it,forgot to mention that i sprayed copper coat on both sides of my base gasket before i put it on because i have had problems with oil seeping by it in the past,but since my last rebuild with the copper coat...no problems!! hope this helps....
PostSubject: Re: ALBA 734 Big Bore for 2011 Rhino 700   Fri Mar 22, 2013 9:24 pm
When I installed the gaskets, I installed them dry. Was this a mistake?
I did the bolt tightening similar to you. I put oil on the threads and tightened to 25lb-ft in a criss-cross patern. Then tightened to 45lb-ft in a cross pattern.
So I guess I gotta take this thing apart again anyway, huh? The oil is dripping a drop every minute, it seems, when the motor is running.
So close but so far...
LoL
2014 Teryx4 800 LE
4500lb Warn
PostSubject: Re: ALBA 734 Big Bore for 2011 Rhino 700   Fri Mar 22, 2013 9:40 pm
When I did mine I put pematex tack & seal on the base gasket to keep it place and make sure it would seal.
Has anyone else used it ?
Owner of
Pro Armor dealer
PostSubject: Re: ALBA 734 Big Bore for 2011 Rhino 700   Fri Mar 22, 2013 9:42 pm
If you are dripping oil like that from your base gasket now..its not gonna get better..i would tear it back down and make sure everything is super clean,use cometic gaskets and use the copper coat gasket sealer on the base gasket only..spray both sides and wait till it gets tacky,then reassemble,but i would talk to james first..to see what all you need to do,but i am a firm believer in double checking your torque on the studs when u put it together!
PostSubject: Re: ALBA 734 Big Bore for 2011 Rhino 700   Fri Mar 22, 2013 9:47 pm
I do the 25 then 45lb then i go back over them 15 miniutes later with 45lbs as they do settle a little...i like to double check everything..obsesive!!!if thats spelled right..lol
Page 2 of 10Go to page : Previous  1, 2, 3, 4, 5, 6, 7, 8, 9, 10  Next
» Rhino Vs. Commander 1000
» Rhino 700 kicks Commander 1000's ass on short course..
» Help Please, Rhino 700i, clutch/speed issue
» 2011 Rhino
» polaris deluxe brushguard will NOT fit 2011
