 Water temp sender
deerhunter
PostSubject: Water temp sender   Thu Aug 29, 2013 3:33 pm
I'm trying to put an inline adapter for my water temp sender on the driver's side coolant line. Does anyone have an example of one they made or where can I order one that doesn't occlude the coolant flow?
PostSubject: Re: Water temp sender   Thu Aug 29, 2013 6:35 pm
Ebay has all kinds of choises, 3/4"-19 mm
PostSubject: Re: Water temp sender   Thu Aug 29, 2013 7:00 pm
bought mine from summit havn't had any issuses with over heating, check in installing gauges in the elec. section
PostSubject: Re: Water temp sender   Sun Sep 01, 2013 10:58 am
What year rhino???
Here is a link for the best temp sensor adapter, no blockage. My old BRP had a 40% blockage.
http://www.ultimaterhinos.com/ulrhwateoufo.html
Dirt flies when you're having fun!
CamoRhino660
CamoRhino660
PostSubject: Re: Water temp sender   Thu Nov 28, 2013 1:42 pm
Anyone have any info on joe at ultimate rhinos?  I ordered this temp housing 3 weeks ago and nothing..... Called and sent multiple emails and messages and I have got no response....  Anyone no what gives?
PostSubject: Re: Water temp sender   Thu Nov 28, 2013 1:47 pm
i bought a cheap sunpro gauge at vip an the sender fit in the stock location in the head i didnt have to cut the coolant hoses
CamoRhino660
CamoRhino660
PostSubject: Re: Water temp sender   Thu Nov 28, 2013 2:20 pm
The one I ordered you don't cut the hose either. It bolts to where the thermostat would be and the sender goes in it.
PostSubject: Re: Water temp sender   Fri Nov 29, 2013 10:58 am
I sure hope you make contact with Joe. He is really a cool guy and has awesome products! I'm running his adapter with no issues for years now. It's the only adapter I've seen thats worth it!
PostSubject: Re: Water temp sender   Fri Nov 29, 2013 11:48 am
I talked to him earlier in the summer...he was helping out at his families place ; and ,  wasn't at his shop...told me not to order till I talked to him again.   Been tryin to reach him for the past couple months...really wanting his oil filter relocate kit !!  bounce bounce
Water temp sender
» Water Temp Gauge
» Capernwray 3rd February
» Perris water temp?
» Hzj75 toyota ute water temps
» Temp light keeps coming on
