In total there are 47 users online :: 0 Registered, 0 Hidden and 47 Guests :: 2 Bots
How to change or clean rear pads (with pics) Icon_minitimeWed Aug 16, 2023 1:17 pm by RADICAL RAM
How to change or clean rear pads (with pics) Icon_minitimeThu Dec 14, 2017 4:54 pm by WV Hot Rod Rhino
How to change or clean rear pads (with pics) Icon_minitimeThu Dec 14, 2017 1:28 am by WV Hot Rod Rhino
How to change or clean rear pads (with pics) Icon_minitimeThu Dec 14, 2017 12:35 am by WV Hot Rod Rhino
How to change or clean rear pads (with pics) Icon_minitimeFri Dec 13, 2013 11:01 am by WV Hot Rod Rhino
How to change or clean rear pads (with pics) Icon_minitimeFri Dec 13, 2013 10:59 am by WV Hot Rod Rhino
How to change or clean rear pads (with pics) Icon_minitimeFri Dec 13, 2013 9:33 am by Tacoclaw
How to change or clean rear pads (with pics) Icon_minitimeFri Dec 13, 2013 7:50 am by chuddly
How to change or clean rear pads (with pics) Icon_minitimeFri Dec 13, 2013 7:47 am by chuddly
How to change or clean rear pads (with pics) Vote_lcapHow to change or clean rear pads (with pics) Voting_barHow to change or clean rear pads (with pics) Vote_rcap
rhinopolice
7 posters
rhinopolice
rhinopolice
How to change or clean rear pads (with pics) Empty
PostSubject: How to change or clean rear pads (with pics)   How to change or clean rear pads (with pics) Icon_minitimeSun Sep 01, 2013 11:03 am
Hey Guys,
This is my second post and my first "How To", so bear with me.
When I bought my used Rhino (2007 450). I noticed that the parking brake didn't work. I tried adjusting it like in the manual, but something just didnt seem right. With the brake pulled, I could still push the Rhino by hand. So, I began investigating.
So, this is a "How TO", on how to clean the back brake if your parking brake isnt functioning. Which is basically the same procedure as changing the rear pads.
Tools Needed:
8MM socket with 1/4 rachet (I used a cordless drill with a 1/4 inch attachment)
14MM socket with 3/8 rachet
Needle nose pliers
5MM Allen wrench
(these were needed to clean the brake calipers and pads)
some type of all purpose oil
small flatblade screw driver
a small wire brush
1) Remove the master cylinder cap from the reservoir
How to change or clean rear pads (with pics) Reservoir_zpsf5f9a33d
2) Get under the back of the vehicle. Look up between the rear tires. There is a skid plate. This has 7 bolts in it, that must be removed.
How to change or clean rear pads (with pics) Skid_zpse4d8e1f1
3) Grab your trusty needle nose pliers and squeeze the plastic holders of the brake line and parking brake line from the frame area:
How to change or clean rear pads (with pics) Brakeholder_zps7c48c23d
4) Get out from underneath the vehicle. Lift the tilt bed. Here is the Caliper!
How to change or clean rear pads (with pics) Caliper_zps32589c56
5) Here is the 14MM top bolt that needs to be removed. Remove it with either a 14MM wrench, or a 14mm socket.
How to change or clean rear pads (with pics) Topbolt_zps0dd5e91e
6) Go back underneath, grab your 14mm wrench or rachet. Remove bottom bolt
How to change or clean rear pads (with pics) Bottombolt_zps92ec9727
7)Caliper should be loose enouth to slice off of its bracket and rotor. Gently twist it so you can get your hands on the parking brake cable. Slide the parking cable out of its holder. (See Yellow Arrow)
How to change or clean rear pads (with pics) Brakecable1_zps5aa9a6c4
remove it, by rotating the cable around where it will fit through the slot.
How to change or clean rear pads (with pics) Brakecable2_zps61f08688
Cool Grab your 5mm allen wrench and remove these bolts/pins.
How to change or clean rear pads (with pics) Allenscrews_zpsef51ffce
9) As you can see my pins were pretty bad off.
How to change or clean rear pads (with pics) Pins_zpsaaeb3fd9
So I used some 1000 grit sandpaper (green arrow) and GENTLY sanded these back to a nice smooth shine. (using spit as lubricant), LOL! Yeah I know that sounded bad.
How to change or clean rear pads (with pics) Pincleaning_zps8cc92880
I think they came out pretty good
10) Remove the pads now. Mine were pretty bad as well. However I still had a lot of pad left. So, I used my flathead screwdriver and GENTLY scraped the mud out of the grooves. I also used a soft wire brush to gently brush the rest of the pad to remove any mud as well.
How to change or clean rear pads (with pics) Padcleaning_zps47a71564
Using the soft wire brush, I worked the pad surface a little to bring it back to a normal state
How to change or clean rear pads (with pics) Pinrefinishing_zpsc64dcd79
11) Remove the spring that gives the pads tension against the pins:
Seen here
How to change or clean rear pads (with pics) Spring_zpsbfe35bb6
12) Clean out this area where the spring sat
How to change or clean rear pads (with pics) Springarea_zps53621128
13) Here is the caliper piston. Mine was gummed up pretty good. So, I gently cleaned the outer surface with a soft wire brush
How to change or clean rear pads (with pics) Pistoncleaningarea_zpse7d271f1
14) I then used some all in one oil and put about 10 drops on the area where the piston met the caliper and let it sink in for a few seconds.
How to change or clean rear pads (with pics) Pistonoilingarea_zps06eb98e6
15) I then grabbed the needle nose pliers and turned the piston clockwise to compress the piston into the caliper.
How to change or clean rear pads (with pics) Pistonrotating_zpsa6ac878f
**** Make sure when you spin the piston that you put it in this orientation. It should have the tips of the cross to the sides. (Green Arrows), this is due to the pin in the pad (Yellow circle) needs to sit in the cross hair.
How to change or clean rear pads (with pics) Padseating_zps1909bd98
16) Put the spring back in if you removed it to clean
How to change or clean rear pads (with pics) Springbackin_zps94c0246a
17)I grabbed the pads (or in your case new pads) and reinstalled them in the caliper. The spring will give you some tension against them, so be prepared.
18) Install the pins now and tighten them down. (Make sure to add a tiny bit of grease on them, just to prevent any further rust ( Thanks Jeff )) The spring will make you press the pads down into the caliper to insert the pins
19) It should look like this
How to change or clean rear pads (with pics) Calipercompleted_zpsfb322521
20) grab some brake cleaner and wipe off the rotor.
21) reattach the parking brake cable to the caliper
22) put the caliper back on the rotor
23) put the bottom bolt in, but do NOT tighten it down yet.
24) Put top bolt in and tighten it down
25) Now Tighten up bottom bolt
26) Put the brake holders back in their places on the frame areas
27) Put the skid plate back on the bottom.
28) Put the brake reservoir cap back on.
Voila! now go enjoy your Rhino with a working parking brake.
Hope this helps some people that had trouble with the back pads.
PostSubject: Re: How to change or clean rear pads (with pics)   How to change or clean rear pads (with pics) Icon_minitimeSun Sep 01, 2013 12:06 pm
great writeup, joey! thanks for taking the time and sharing bounce
rhinopolice
rhinopolice
PostSubject: Re: How to change or clean rear pads (with pics)   How to change or clean rear pads (with pics) Icon_minitimeSun Sep 01, 2013 12:09 pm
You're welcome! I will be doing more as I mod the 450.
Once I receive the Sheave, I will try and do a How-to on that as well.
PostSubject: Re: How to change or clean rear pads (with pics)   How to change or clean rear pads (with pics) Icon_minitimeSun Sep 01, 2013 1:27 pm
nice job, prolly the most computer literate cop I've seen...lol
PostSubject: Re: How to change or clean rear pads (with pics)   How to change or clean rear pads (with pics) Icon_minitimeSun Sep 01, 2013 3:37 pm
Good write up..this will help a lot of people!!
PostSubject: Re: How to change or clean rear pads (with pics)   How to change or clean rear pads (with pics) Icon_minitimeSun Sep 01, 2013 7:06 pm
That's an awesome job, well done Joey.
PostSubject: Re: How to change or clean rear pads (with pics)   How to change or clean rear pads (with pics) Icon_minitimeSun Sep 01, 2013 8:31 pm
Nice. I just did this (also the fronts) and it stopped the squeaks and grinding. At least for a while. Thanks for sharing.
PostSubject: Re: How to change or clean rear pads (with pics)   How to change or clean rear pads (with pics) Icon_minitimeMon Sep 02, 2013 12:43 am
good job an great write-up , when I did mine the floater pins where froze-up , you should pull them an add a little grease while your in there.
rhinopolice
rhinopolice
PostSubject: Re: How to change or clean rear pads (with pics)   How to change or clean rear pads (with pics) Icon_minitimeMon Sep 02, 2013 12:51 am
Thanks guys!
Good Point Jeff!
Just added it!
» Brake pads
» How To CLean Your Carb
» Your Radiator: You Just Thought It was Clean
» how do you clean your ride on blanket?
» clean up your wiring.. Bitches
