Ole Nasty
Posts : 35 Join date : 2013-09-06 Location : Jacksonville, Fl
| Subject: Spacer ? Fri Sep 06, 2013 10:08 pm | |
| Are there supposed to be stock spacers on the front wheels? The PO had washers stacked up on only the right front wheel studs because without them the wheel was actually rubbing on the spindle. You can see where it was rubbing the tie rod end too. Any ideas? | |
| Subject: Re: Spacer ? Fri Sep 06, 2013 10:36 pm | |
| mine does not have them, have you changed the rims maybe the offset is wrong/off ? | |
| Subject: Re: Spacer ? Fri Sep 06, 2013 11:50 pm | |
| To best I can remember no spacers from the OEM on the front, just on the rear after the voluntary recall. The wheel off set must be wrong. | |
