In total there are 34 users online :: 0 Registered, 0 Hidden and 34 Guests
Spacer ? Icon_minitimeWed Aug 16, 2023 1:17 pm by RADICAL RAM
Spacer ? Icon_minitimeThu Dec 14, 2017 4:54 pm by WV Hot Rod Rhino
Spacer ? Icon_minitimeThu Dec 14, 2017 1:28 am by WV Hot Rod Rhino
Spacer ? Icon_minitimeThu Dec 14, 2017 12:35 am by WV Hot Rod Rhino
Spacer ? Icon_minitimeFri Dec 13, 2013 11:01 am by WV Hot Rod Rhino
Spacer ? Icon_minitimeFri Dec 13, 2013 10:59 am by WV Hot Rod Rhino
Spacer ? Icon_minitimeFri Dec 13, 2013 9:33 am by Tacoclaw
Spacer ? Icon_minitimeFri Dec 13, 2013 7:50 am by chuddly
Spacer ? Icon_minitimeFri Dec 13, 2013 7:47 am by chuddly
Spacer ? Vote_lcapSpacer ? Voting_barSpacer ? Vote_rcap
 Spacer ?
3 posters
Ole Nasty
Ole Nasty
Spacer ? Empty
PostSubject: Spacer ?   Spacer ? Icon_minitimeFri Sep 06, 2013 10:08 pm
Are there supposed to be stock spacers on the front wheels? The PO had washers stacked up on only the right front wheel studs because without them the wheel was actually rubbing on the spindle. You can see where it was rubbing the tie rod end too. Any ideas?
Spacer ? Empty
PostSubject: Re: Spacer ?   Spacer ? Icon_minitimeFri Sep 06, 2013 10:36 pm
mine does not have them, have you changed the rims maybe the offset is wrong/off ?
Spacer ? Empty
PostSubject: Re: Spacer ?   Spacer ? Icon_minitimeFri Sep 06, 2013 11:50 pm
To best I can remember no spacers from the OEM on the front, just on the rear after the voluntary recall. The wheel off set must be wrong.
Spacer ? Empty
Spacer ?
» Throttle body spacer
» Broken Stud, Puzzled by Rear Hub no Spacer
» How to convert rhino rear hub spacer back to stock.
