 Engine Oil Cooler
PostSubject: Engine Oil Cooler    Tue Sep 10, 2013 5:56 pm
Well , since my wet clutch sent crap all through the motor including the oil cooler which just could not be cleaned  I decided to put a bigger cooler in .
The cooler is a trans cooler from Advanced Auto. It's an  Imperial Maxi-Cool XL. Then I used the cooling fan from a 450 Grizzly that I had from when my step son had wreaked the quad.  It seems to work good so far. I left it run after shutting the rhino off and with in a min or 2 the cooler was cool to the touch. I plan on running it all the time while the motor is running just to make sure the oil stays cool. I'll have a switch hooked up so I can turn it off if I get into deep mud , water , or in the winter .
Owner of
www.trailbrightled.com
Moto Alliance dealer
Pro Armor dealer
Rocky Mountain ATV dealer
PostSubject: Re: Engine Oil Cooler    Tue Sep 10, 2013 5:59 pm
I like that setup.
What shocks are those.
27" EFX Motoclaws
JE 11:1 102mm
Warn Pro Vantage 3500lb.
Ricochet a-arm skids
PRM bash plate
Unisteer Rackzilla
PostSubject: Re: Engine Oil Cooler    Tue Sep 10, 2013 6:03 pm
I like the oil cooler up there. That's something I wouldn't mind doing to my Rhino so that I can clean all the mud out of the radiator.
I also like those Walker Evans Racing shocks... lol. Mine have a longer spring on the front, but otherwise those shocks look awfully familiar.
2011 Rhino 734 Sport
2014 Teryx4 800 LE
4500lb Warn
PostSubject: Re: Engine Oil Cooler    Tue Sep 10, 2013 6:18 pm
Nice looking job I would like to do something like that also.
JBS built 787
JBS sheave
Ported head +2 valves
Power steering
Tilt wheel
Suspinsion seats
Muzzy dual exshaust
Stage 4 elka shocks
Pit bull 26.5 Rockers
Bored throttle body
PostSubject: Re: Engine Oil Cooler    Tue Sep 10, 2013 6:24 pm
cheers
2009 Yamaha Rhino 787
jamesbodyshop@hotmail.com
PostSubject: Re: Engine Oil Cooler    Tue Sep 10, 2013 6:42 pm
I also have plans to install an oil temp gauge when I install a coolant temp and volt gauge.  If I wasn't in such a rush to get the rhino up and running before Thursday ( h&m trip ) I would have done a little cleaner job like painting the brackets black and cleaned everything.
Owner of
Pro Armor dealer
PostSubject: Re: Engine Oil Cooler    Tue Sep 10, 2013 7:20 pm
looks good. not a bad idea to mount it there
PostSubject: Re: Engine Oil Cooler    Tue Sep 10, 2013 7:34 pm
I like that set-up, looks good
PostSubject: Re: Engine Oil Cooler    Tue Sep 10, 2013 7:42 pm
Thanks and it will let cooler air to get to the rad mounted up where it is
Owner of
Pro Armor dealer
PostSubject: Re: Engine Oil Cooler    Thu Oct 10, 2013 11:11 pm
I pretty sure this mod saved my motor last weekend. I lost all the coolant when a rad hose came off the motor. The motor ran for a good 5 mins before I got to a place to shut it down and see why the temp light was on.
When I shut the motor off and started checking stuff I found the rad was cool to the touch. Telling me there was no coolant. After fixing the problem I started it up and it ran great the rest of that day and the next. No noises from the motor at all.
I had the fan from my old 450 grizzly so it only cost me about $65 for the cooler and you can find them cheaper if you look around.
Owner of
Pro Armor dealer
PostSubject: Re: Engine Oil Cooler    Thu Oct 10, 2013 11:29 pm
glad that you got lucky on that Like a Star @ heaven
PostSubject: Re: Engine Oil Cooler    Fri Oct 11, 2013 3:24 pm
damn you did get lucky ,you don't want to roach that new motor like that, how did the rad hose come off?
PostSubject: Re: Engine Oil Cooler    Fri Oct 11, 2013 7:49 pm
So you never have cooling issues? There was someone on here that said there's wouldn't cool in the hot part of the day. I couldn't understand why. Think it could be a difference between a 660 n 700 cooling? I really need to do something with mine soon or it will stuck up behind my head soon. I'm done cleaning it 24/7.
2009 Rhino SE Red  SOLD SOLD
PostSubject: Re: Engine Oil Cooler    Fri Oct 11, 2013 9:45 pm
On mine the rad fan would run a lot but after putting the oil cooler on it would only run one and a while if going slow and in the gas like running in rocks
Owner of
Pro Armor dealer
PostSubject: Re: Engine Oil Cooler    Fri Oct 11, 2013 9:50 pm
not to hijack scott, but hows that new motor run
PostSubject: Re: Engine Oil Cooler    Fri Oct 11, 2013 10:06 pm
Mick it runs great
Owner of
Pro Armor dealer
PostSubject: Re: Engine Oil Cooler    Mon Oct 14, 2013 11:27 pm
Quote :
That was me Banchee6.
Only difference with my setup compared to flimmy is I have my rad and oil cooler up on the frame rails. Flimmy's rad is still down in the stock position. Having two fans will make a huge difference in cooling the whole setup.
I am awaiting my hood scoop for installation.
Nice setup flimmy!
06-660
JBS sheave 14g
Purple Spring
PostSubject: Re: Engine Oil Cooler    Tue Oct 15, 2013 7:08 am
Thanks
Owner of
Pro Armor dealer
Engine Oil Cooler
» RCGF 45cc Petrol Engine
» Tecumseh engine
» How man cc is an 11hp engine?
» Poss. sale of 09 RZR "S" engine
» Please help me diagnose Engine trouble on a 18.5 hp v twin.
