 middle drive gear
mr sandman
PostSubject: middle drive gear   Fri Sep 13, 2013 12:51 pm
just curious as to what the middle drive gear or middle drive support actually is. ive never been into the bottom end of my rhino. just wanted to get a little more insight on the weak link.
734bbk, stage 2 cam, msd charge, duel looney tuned exhaust, 6inch catvos lift, 30inch s/w silverbacks, HIDs, 4 JL audio 6 1/2s, memphis 4ch
--coming soon!!--jbs sheave, 46mm throttle body
PostSubject: Re: middle drive gear   Sun Sep 15, 2013 7:57 am
the middle drive support is a weak link , if you ever open up the case's that is a must upgrade. the middle drive gear is sending power to the through shaft which the front an back drive shafts hook too . the middle support will bust under the load , the oem is pot aluminum just a bad set-up replace with a billet piece no more worries of braking . also when one lets go it can take out most of the trans gears , through shaft & gears , middle drive gear , bust the case maybe even the crank, very $$$$$ repair
mr sandman
PostSubject: Re: middle drive gear   Mon Sep 16, 2013 11:27 am
wow definately would be a costly repair. ive heard about it before just never actually known what it was. thanks for the insite. is this a problem for both the 660 and 700??
PostSubject: Re: middle drive gear   Mon Sep 16, 2013 11:58 am
Yes I believe it is if you do it do the reverse gear upgrade also.
JBS built 787
JBS sheave
Ported head +2 valves
Power steering
Tilt wheel
Suspinsion seats
Muzzy dual exshaust
Stage 4 elka shocks
Pit bull 26.5 Rockers
Bored throttle body
middle drive gear
