In total there are 8 users online :: 0 Registered, 0 Hidden and 8 Guests :: 2 Bots
 valve settings for raptor stage 1 cam on a 660
PostSubject: valve settings for raptor stage 1 cam on a 660    Sun Sep 15, 2013 6:01 am
my big bore piston should be here Monday so I will be tearing the rhino apart to install 10:1 je 102mm piston having the head ported an adding a stage 1 raptor cam an springs what is everyone setting the valves to
 thanks
I will also be selling a stage 1 hot cam drop in cam that will have less than 100 miles on it when it comes out if anyone is interested it added a good bit of low end power
PostSubject: Re: valve settings for raptor stage 1 cam on a 660    Sun Sep 15, 2013 6:38 am
I 'm curious whats the difference in the stage 1 hot cam an the stage 1 raptor cam Question
PostSubject: Re: valve settings for raptor stage 1 cam on a 660    Sun Sep 15, 2013 7:39 pm
from what ive been reading the raptor stage 1 hot cam is the same as the rhino stage 2 cam offers a little more mid an top end power the stage 1 I have in there now is more for low end
PostSubject: Re: valve settings for raptor stage 1 cam on a 660    Sun Sep 15, 2013 11:58 pm
anyone have valve specs for the stage 1 raptor cam?
