In total there are 15 users online :: 0 Registered, 0 Hidden and 15 Guests :: 1 Bot
 Starter solinoid
Shrek Racing
PostSubject: Starter solinoid   Sun Sep 15, 2013 10:25 pm
I keep burning up solinoid s.  WTF?  I have replace the starter solinoid and grounded battery and engine to the frame.  Has anyone else had a problem with a issue like this?
2006 Special Edition
Sheave by JBS
HSR 45
I-Shocks
Head by JBS
Camshaw Spindles/steering rack/Cam
Ron Woods Exhaust
Black Rhino electric fuel pump
Not one fucking thing from UTV Shit
View user profile http://Sembra.org
PostSubject: Re: Starter solinoid   Sun Sep 15, 2013 11:03 pm
where is steveS when you need him?...lol
Shrek Racing
PostSubject: Re: Starter solinoid   Sun Sep 15, 2013 11:05 pm
I was hoping he would respond.  Where are you Steve?
Sheave by JBS
HSR 45
I-Shocks
Head by JBS
Ron Woods Exhaust
PostSubject: Re: Starter solinoid   Mon Sep 16, 2013 12:37 am
Hi fellas. I've been busy preparing for the rainy season, among various other sundry things. Starter relay? How many have you gone through?
Two roads diverged in a wood,
I took the one less traveled by....
Oh, Oh .
Shrek Racing
PostSubject: Re: Starter solinoid   Mon Sep 16, 2013 1:18 am
3 in the last 4-5 mos.  have not checked the relay.  I will try to locate it tomorrow and check it
Sheave by JBS
HSR 45
I-Shocks
Head by JBS
Ron Woods Exhaust
PostSubject: Re: Starter solinoid   Mon Sep 16, 2013 1:32 am
We might be talking about the same thing. This is a big relay in the battery box that sends power to the starter motor when you turn the key to start. The term solenoid is more used in the auto world where the device closes some large contacts to electrically connect while also shifting a gear into contact with the ring gear on the flywheel. Just a matter of what you want to call it, I suppose.
What is going wrong with them? Coils burning out, contacts burning up, or ??
Oh, Oh .
Shrek Racing
PostSubject: Re: Starter solinoid   Mon Sep 16, 2013 9:07 pm
Not sure on most of them I can arch the poles with a spark plug and it cranks.  This time arching does not work.  Something internal is bad.  When key is turned relay/ solinoid just clicks.
Sheave by JBS
HSR 45
I-Shocks
Head by JBS
Ron Woods Exhaust
TBOMB
PostSubject: Re: Starter solinoid   Mon Sep 16, 2013 9:53 pm
If you mean that you are jumping across the large current contacts of the starter relay in the battery box and nothing happens, then I would check the cables/connections from the battery to the relay, and the relay to the starter. Sounds like a bad/corroded cable. Just a place to start checking.
PostSubject: Re: Starter solinoid   Mon Sep 16, 2013 11:41 pm
X2 plus also check the ground cable from the battery negative terminal to the engine case. It gets loose down at the engine case sometimes. This often leads to a fried ground pigtail, unless you have the SteveS fix in.
Oh, Oh .
Shrek Racing
PostSubject: Re: Starter solinoid   Tue Sep 17, 2013 6:03 am
I have the Steve S fix and the cables are good from what I can see.
Sheave by JBS
HSR 45
I-Shocks
Head by JBS
Ron Woods Exhaust
PostSubject: Re: Starter solinoid   Tue Sep 17, 2013 11:44 am
I'm assuming the battery has a decent charge? Since jumpering across the starter relay contacts does not do the trick, try using a decent jumper cable from battery positive terminal to starter motor positive terminal. If that fails, it would likely be the starter motor itself.
Oh, Oh .
RhinoGT350
PostSubject: Re: Starter solinoid   Tue Sep 17, 2013 11:53 am
i had this problem with one of my quads while ago. i went through 2 coils in about 6 month peroid. i had some corrosion on a terminal (ground) if i recall. i cleaned it up really good and solved it.
Starter solinoid
