| new to the forums and need advice | |
+9Crusty Jet 08Rhino450SE 123.bert0621 Kenny G rhino727 flimmy mike734 hondakiller 13 posters |
hondakiller
Posts : 2 Join date : 2013-09-19
| Subject: new to the forums and need advice Thu Sep 19, 2013 9:06 pm | |
| I just bought an 04 450 rhino and need a lil advice i want a lil more power to help me keep up with a 660. Any advice is helpful. I also need help with my belt getting wet in water not deep enough to get in pipes. Thanks | |
| Subject: Re: new to the forums and need advice Thu Sep 19, 2013 9:12 pm | |
| welcome! talk to james (jbs) about the power and then go to home depot and buy some pvc and make yourself some snorkles. | |
| Subject: Re: new to the forums and need advice Thu Sep 19, 2013 9:19 pm | |
| Check all the CVT vent hoses and make sure they have the clamps on them and that they are all connected right.
Like Mike said call James about getting more power. But a cdi box , sheave and new belt will help out a lot
and welcome to the board. | |
| Subject: Re: new to the forums and need advice Thu Sep 19, 2013 10:04 pm | |
| check your clutch cover gaskets one between the outer cover an inner cover , two between motor an inner cover, now call James about the clutch an hope the guy with the 660 had not
an welcome to the sight | |
| Subject: Re: new to the forums and need advice Thu Sep 19, 2013 10:06 pm | |
| Welcome Hondakiller, You can do a lot of investing on a 450, I know, and you'll still not keep up with a well performing 660 on the flats. Not to say it's not worth spending the $$$ on, I've spent a fair amount on my 450 and enjoy the hell out of it. It just doesn't have the horses under the hood. Decide on what kind of riding you're going to do the most and upgrade for that action. Have fun!!! | |
| Subject: Re: new to the forums and need advice Thu Sep 19, 2013 10:16 pm | |
| Welcome aboard, there are some guys that can sure help with the 450. | |
| Subject: Re: new to the forums and need advice Thu Sep 19, 2013 10:33 pm | |
| also make sure the drain plug is in | |
| Subject: Re: new to the forums and need advice Thu Sep 19, 2013 11:07 pm | |
| - hondakiller wrote:
- I just bought an 04 450 rhino and need a lil advice i want a lil more power to help me keep up with a 660. Any advice is helpful. I also need help with my belt getting wet in water not deep enough to get in pipes. Thanks
if you've been getting water in the pulleys and belt a lot you probably need to service them. James can help you with the hotrod sheave (sliding pulley) and a new belt. the 450s are geared about 15% lower than the 660s so top speed is kinda hard to improve. mine would go 42 when i first got it, and that was the top speed spec for a stock 660. when i first bought mine the cooling pipe running from the sheaves was unfastened and it took on water. i had to snug it up and re-tighten. oh, yeah: WELCOME TO THE FORUM | |
| Subject: Re: new to the forums and need advice Fri Sep 20, 2013 12:00 am | |
Crusty
| Subject: Re: new to the forums and need advice Fri Sep 20, 2013 12:44 am | |
| Welcome, I used to get water in my clutch housing in about 16" of water and when I installed my Sheave there was no drain plug at all so I just ended up putting a 1/4" bolt thru it with a lock nut and tightened it up and now it's water tight. Probably not the best cure but it worked. | |
Yotehunter66 Moderator
| Subject: Re: new to the forums and need advice Fri Sep 20, 2013 6:44 am | |
Bayou Tiger
| Subject: Re: new to the forums and need advice Fri Sep 20, 2013 2:31 pm | |
| Welcome to the obsession!!!! | |
| Subject: Re: new to the forums and need advice Fri Sep 20, 2013 11:39 pm | |
| Welcome. I'm a previous 450 owner. I had the JBS sheave and blue secondary spring only and that made a very nice improvement in power. If you really want it to run it's best, stay with 25" tires. I had 26" mudlites and it ran pretty good other than the long steep uphill roads. On the trail it done great. Sometimes I wish I still had it around to keep messing with. That 450 has got to be one of the toughest engines of all time. I rode mine with the pedal on the floor all day long for a very long time. Couldn't believe it took the abuse. | |
hondakiller
| Subject: Re: new to the forums and need advice Sat Sep 21, 2013 1:17 am | |
| When i bought it the front hose is gone and plugged off goin to the belt and i have retighted the hose comeing out of the back and with my cdi i can run 40 tops wich is fine i would just like a lil more power when i hit long hills on trails thanks for all the helpful advice i will try to get in touch with james about a sheave when i get a lil more saved up kinda a budget build toy right now. What does that jbs sheave usally run price wise?
| Subject: Re: new to the forums and need advice Sat Sep 21, 2013 8:15 am | |
| with out that hose your preventing air from passing through for cooling the belt/clutch . as far as the price I don't remember I was buying a lot of parts all at once what I do know is the JBS sheave is the best | |
| Subject: Re: new to the forums and need advice Sat Sep 21, 2013 2:17 pm | |
| I think the kit, sheave, OD weights, friction washers, secondary spring, cozy, and sticker were about $300.00-$325.00. And you will need Yamalube Ultramatic grease. And don't forget to call the Man for the correct price and shipping.304-673-2602,304-877-3419 | |
| Subject: Re: new to the forums and need advice Sat Sep 21, 2013 7:53 pm | |
| - 123.bert0621 wrote:
- I think the kit, sheave, OD weights, friction washers, secondary spring, cozy, and sticker were about $300.00-$325.00. And you will need Yamalube Ultramatic grease. And don't forget to call the Man for the correct price and shipping.304-673-2602,304-877-3419
x2 and welcome to the fun! | |
| Subject: Re: new to the forums and need advice | |
