| JBS Sheave PROBLEM | |
+10Crusty Yotehunter66 banchee6 ASPENDELLROVER scottwv WV Hot Rod Rhino REDRHINO64 flimmy pageandbeth surfdoggins 14 posters |
surfdoggins
Posts : 7 Join date : 2013-09-07
| Subject: JBS Sheave PROBLEM Sat Sep 21, 2013 7:00 pm | |
| Installed my JBS hotrod sheave today but doesn't seem to be working. At about 32 to 33 MPH, my Rhino starts cutting out and at about 36 MPH its completely dead like its starving for fuel. Tried putting it in low and at about 26 to 27 MPH it does the same thing. Thought maybe I installed something wrong so I took everything apart and re-installed everything again. Just took it out again and it does the same thing. Seems to run okay under 32 MPH but I can't seem to notice any difference in performance. But when it hits about 32+ MPH it just cuts out and won't go any faster. I have a 2011 700 with 18g weights and 26" tires. Any suggestions? Tried calling James but his mailbox is full. | |
pageandbeth
Posts : 20 Join date : 2013-04-11 Age : 41 Location : Robeline, La
| Subject: Re: JBS Sheave PROBLEM Sat Sep 21, 2013 7:05 pm | |
| Take some pics of the sheave with weights and cam plates installed and removed. | |
| Subject: Re: JBS Sheave PROBLEM Sat Sep 21, 2013 7:20 pm | |
| Do you have the stock cdi box ? They have a rev limiter that may be your problem. I know  the 660's have them and that's what can happen | |
| Subject: Re: JBS Sheave PROBLEM Sat Sep 21, 2013 7:50 pm | |
| weights in wrong...these things run 42 stock. | |
| Subject: Re: JBS Sheave PROBLEM Sat Sep 21, 2013 8:12 pm | |
| Subject: Re: JBS Sheave PROBLEM Sat Sep 21, 2013 11:52 pm | |
| Need to keep technical questions here ! | |
| Subject: Re: JBS Sheave PROBLEM Sun Sep 22, 2013 2:20 am | |
| yep RF dont work for shit | |
| Subject: Re: JBS Sheave PROBLEM Sun Sep 22, 2013 11:52 am | |
| i got this forum for my customers and they still ask them over there | |
| Subject: Re: JBS Sheave PROBLEM Sun Sep 22, 2013 11:55 am | |
| Yeah, they start smothering out , whenever you don't answer ! Â Â | |
| Subject: Re: JBS Sheave PROBLEM Sun Sep 22, 2013 12:00 pm | |
| sounds like my issue, all weights were flipped.... | |
pageandbeth
| Subject: Re: JBS Sheave PROBLEM Sun Sep 22, 2013 1:03 pm | |
| Yea i ran into that the other day. There was a few weights that was flipped and slider bushings were upside down. | |
surfdoggins
| Subject: Re: JBS Sheave PROBLEM Mon Sep 23, 2013 2:18 am | |
| I know I got the bushings on correct. But not sure about the weights. I put the side with the couple grooves on the bottom facing the center. Is this correct? | |
| Subject: Re: JBS Sheave PROBLEM Mon Sep 23, 2013 2:26 am | |
Yotehunter66 Moderator
| Subject: Re: JBS Sheave PROBLEM Mon Sep 23, 2013 6:42 am | |
| Pull the cover and rev it up and see if your belt is riding to the top of your primary and secondary sheaves.
Last edited by Yotehunter66 on Mon Sep 23, 2013 6:43 am; edited 1 time in total (Reason for editing : Add to it.) | |
| Subject: Re: JBS Sheave PROBLEM Mon Sep 23, 2013 8:01 am | |
| - surfdoggins wrote:
- I know I got the bushings on correct. But not sure about the weights. I put the side with the couple grooves on the bottom facing the center. Is this correct?
If you have the sheave on the bench , the grooves you are referring to , should be on top ; and , against the center of the sheave. Â There should've been an illustration in the package the od's were in. | |
surfdoggins
| Subject: Re: JBS Sheave PROBLEM Mon Sep 23, 2013 8:28 am | |
| Anybody have a picture of how the weights should be installed? I don't recall seeing anything in the packaging. | |
Crusty
| Subject: Re: JBS Sheave PROBLEM Mon Sep 23, 2013 9:57 am | |
| Subject: Re: JBS Sheave PROBLEM Mon Sep 23, 2013 10:26 am | |
Crusty
| Subject: Re: JBS Sheave PROBLEM Mon Sep 23, 2013 10:44 am | |
Bayou Tiger
| Subject: Re: JBS Sheave PROBLEM Mon Sep 23, 2013 2:03 pm | |
| A liitle research on video's works wonders instead of going in blind, just saying... | |
Crusty
| Subject: Re: JBS Sheave PROBLEM Mon Sep 23, 2013 2:22 pm | |
| I actually watched James video while I did my install and would pause & rewind as needed and everything went into place perfectly, very informative videos. | |
jnalley_01
Posts : 48 Join date : 2013-09-10 Location : malaga ohio
| Subject: Re: JBS Sheave PROBLEM Mon Sep 23, 2013 2:37 pm | |
| X2 i did that same thing install went smooth | |
wagon1
Posts : 38 Join date : 2013-07-08 Age : 51 Location : King George, Va
| Subject: Re: JBS Sheave PROBLEM Mon Sep 23, 2013 4:27 pm | |
| I followed the video when I did mine and it was right on the money. | |
| Subject: Re: JBS Sheave PROBLEM Mon Sep 23, 2013 7:39 pm | |
| - jnalley_01 wrote:
- X2 i did that same thing install went smooth
x3 nothing helps more than some good videos | |
| Subject: Re: JBS Sheave PROBLEM Mon Sep 23, 2013 11:19 pm | |
| and some herbal insight...lol | |
| Subject: Re: JBS Sheave PROBLEM | |
