 what timing chain tensioner is better
PostSubject: what timing chain tensioner is better    Fri Sep 27, 2013 5:27 am
ive been told by a few of u guys to ditch the stock 660 timing chain tensioner so witch is better to get one from a 700 or a manual one thanks
CamoRhino660
PostSubject: Re: what timing chain tensioner is better    Fri Sep 27, 2013 6:37 am
From what I have been told and read the 700 is the one to have so that's what I put in when I did my motor. But was told by a good motor guy that the 660 one is just fine. So just all in what you want.
PostSubject: Re: what timing chain tensioner is better    Sun Sep 29, 2013 11:23 pm
The 660 tensioner is a screw type and has been known to back off, the 700 is a ratchet style and can't back off.
Why install something that has been known to fail???
Dirt flies when you're having fun!
PostSubject: Re: what timing chain tensioner is better    Sun Sep 29, 2013 11:29 pm
only 50.00
2009 Yamaha Rhino 787
jamesbodyshop@hotmail.com
PostSubject: Re: what timing chain tensioner is better    Mon Sep 30, 2013 12:38 am
im still waiting on my piston an gaskets to get here to do my 686 ill be calling u soon james to get a 700 tensioner thanks
PostSubject: Re: what timing chain tensioner is better    Mon Sep 30, 2013 8:51 am
in stock
PostSubject: Re: what timing chain tensioner is better    Mon Sep 30, 2013 9:19 am
good call , the 660 tensioner is what got my motor jumped timing broke valve put valve though piston , 700 is the way to go
PostSubject: Re: what timing chain tensioner is better    Mon Sep 30, 2013 11:31 pm
I was told by a few of u guys to ditch the 660 one an get a 700 one so ill be tearing down my rhino as soon as the piston shows up goin 10:1 je ported head stage 1 raptor cam so I figured I get the 700 tensioner while I was in there. thanks guys
» big bear timing
» ford explorer timing gear
» Honda shocks
» Chain in place of belt.
» Rigging up a rope and chain to grid
