In total there are 16 users online :: 0 Registered, 0 Hidden and 16 Guests :: 2 Bots
 Front diff will not unlock
slomo
PostSubject: Front diff will not unlock   Sat Sep 28, 2013 9:03 pm
My front diff feels like it is in diff lock in 2wd electrically it's good do I have to pull the diff to check it out or is this normal never noticed until I was on the road to the next area today
PostSubject: Re: Front diff will not unlock   Sun Sep 29, 2013 7:32 am
not norm sure the servo is working to disengage ? should be able to hear it engage / disengage
chalkminer
PostSubject: Re: Front diff will not unlock   Sun Sep 29, 2013 1:45 pm
Try putting it up on jack stands and check to see if it is actually locked or 4wd or both.  Have you driven it much on the road before?  The rear axle alone will make it feel kind of locked on the pavement. Does the indicator show that it is always locked?
slomo
PostSubject: Re: Front diff will not unlock   Sun Sep 29, 2013 3:04 pm
No I don't drive on pavement was the first time and the indicator on the dash is not on, I get the rear feeling like that it was the front seemed to push like it was locked in but I am on my way out to jack it up and investigate further I gather the front wheels should spin free of each other when unlocked
chalkminer
PostSubject: Re: Front diff will not unlock   Sun Sep 29, 2013 6:35 pm
Yes, you should be able to jack one wheel up and turn it.
slomo
PostSubject: Re: Front diff will not unlock   Sun Sep 29, 2013 10:07 pm
Nothing all seems good jacked it up checked everything found my front left bearing getting loose but other than that must have been the pavement as like I stated never driven on it with it before lol thanks  everyone and I'm sure the mud tires don't help lol thanks all
chalkminer
PostSubject: Re: Front diff will not unlock   Mon Sep 30, 2013 1:02 am
Yep, the rear axle is always locked.  Add a set of grippy mud tires, and it will fight you when you try to turn.  You have to get one of the tires to break traction.
PostSubject: Re: Front diff will not unlock   Mon Sep 30, 2013 2:43 pm
glade to here it's nothing serious, they can act squirlly on asphalt
» rzr front diff. rebuild
» Rzr front diff parts
» Honda Foreman Front Diff
» front diff is leaking.
» rhino front diff parts
