In total there are 7 users online :: 0 Registered, 0 Hidden and 7 Guests :: 2 Bots
 ITP Blackwater Evolutions
Go to page : 1, 2  Next
jmp30
PostSubject: ITP Blackwater Evolutions    Mon Sep 30, 2013 2:08 pm
Anyone running these or know someone who is?
2013 Realtree Rhino
PostSubject: Re: ITP Blackwater Evolutions    Mon Sep 30, 2013 2:18 pm
i was going to buy em about a month ago. researched pretty good and couldent find much on em. what i did find was nothing negative about em. besides there weight but its a 8ply tire so weight is to be expected. i ended up buying mega mayhems casue i do tend to be in the mud a good bit and i found alot of reviews on them and they were all positive. i still may buy some blackwaters casue the mega mayhems are really aggressive and i dont need that aggressive of a tire all the time.  keep us posted if you get a set.
jmp30
PostSubject: Re: ITP Blackwater Evolutions    Wed Oct 02, 2013 4:36 pm
I ordered a set of 27s. Hopefully I will have them by this weekend. I also could not find anything negative about them. Should be perfect for how I ride. I wanted a radial that was more aggressive than a Bighorn, that was 8 ply and that was not as aggressive as say a 589. Mudlite or Zilla. We shall see.
2013 Realtree Rhino
TBONE21
PostSubject: Re: ITP Blackwater Evolutions    Wed Oct 02, 2013 6:24 pm
I plan to buy a set of these as well. Im sure its a pretty good tire. I want a GBC Kunati Mongrel tire but they wont hook up in the wet or mud
jmp30
PostSubject: Re: ITP Blackwater Evolutions    Wed Oct 02, 2013 11:09 pm
It looks like alot of the Can Am guys are buying these up. Thats what I have seen them on the most anyways. Im really anxious to try them out.
2013 Realtree Rhino
jmp30
PostSubject: Re: ITP Blackwater Evolutions    Fri Oct 04, 2013 5:17 pm
Wheels and tires and in. They are not as heavy as I anticipated. They measure 26 1/2 inches.
2013 Realtree Rhino
PostSubject: Re: ITP Blackwater Evolutions    Fri Oct 04, 2013 5:48 pm
jmp30 are you running a lift on your 2013 rhino or you stock height? I am curious how these work out for you they look a hell of alot better on a wheel and in person than the pics I saw on thier web page for sure man I may pick me up a set of them I like the fact that they make a 9" wide front and 11" wide rear I like that combo alot in a 14" tire.
jmp30
PostSubject: Re: ITP Blackwater Evolutions    Fri Oct 04, 2013 9:33 pm
No lift at all. The 9s and 11s thing was a big deal for me as well. After getting them mounted up, in really excited to try them out. They look like a Bighorn that will do a heck of a lot better in the mud. They ride really smooth and they took away some bottom end but ill take all the benefits of the tire of the performance loss. I'm not a racer anyways. Ill post up some pictures in a bit.
2013 Realtree Rhino
PostSubject: Re: ITP Blackwater Evolutions    Fri Oct 04, 2013 10:31 pm
Awesome I was curious if you would experience any rubbing on the front with that big of tire. I currently rub very seldom and its just the fronts when in some technical stuff usually with dips in trail that cause suspension to work and flex. I never feel the rubbing but I see I have by the marks on my inner fender aluminum guards.
jmp30
PostSubject: Re: ITP Blackwater Evolutions    Sat Oct 05, 2013 9:43 am
2013 Realtree Rhino
jmp30
PostSubject: Re: ITP Blackwater Evolutions    Sat Oct 05, 2013 9:44 am
Ill be posting up some better pictures under the members page in a few days.
2013 Realtree Rhino
PostSubject: Re: ITP Blackwater Evolutions    Sat Oct 05, 2013 9:53 am
Looks awesome man can't wait to see more I'm a camo fan myself as you've seen by mine.
PostSubject: Re: ITP Blackwater Evolutions    Sat Oct 05, 2013 1:59 pm
Time for some action pics.  I like those tires.
27" EFX Motoclaws
JE 11:1 102mm
Warn Pro Vantage 3500lb.
Ricochet a-arm skids
PRM bash plate
Unisteer Rackzilla
PostSubject: Re: ITP Blackwater Evolutions    Sat Oct 05, 2013 10:59 pm
looks cool , love the camo and I have the same wheels also
UnderDawg
PostSubject: Re: ITP Blackwater Evolutions    Sat Oct 05, 2013 11:15 pm
That's a really nice lookin setup ya got there. Those tire look kick azz.
09 camo 450
PostSubject: Re: ITP Blackwater Evolutions    Sun Oct 06, 2013 1:37 am
is that a Jeep Wrangler lurking in the background?
Dave
(Hailey on left and Molly)
jmp30
PostSubject: Re: ITP Blackwater Evolutions    Sun Oct 06, 2013 10:06 am
Yes sir it is, that's my 2012 JK. Good eye.
2013 Realtree Rhino
PostSubject: Re: ITP Blackwater Evolutions    Mon Oct 07, 2013 12:03 pm
they look real good.
PostSubject: Re: ITP Blackwater Evolutions    Mon Oct 07, 2013 12:23 pm
like your set-up , tires looks good let us know how it does in the mud
jmp30
PostSubject: Re: ITP Blackwater Evolutions    Mon Oct 14, 2013 9:25 am
Well I just got back from Ride Royal Blue. The tires did an excellent job at everything I threw at them I am please with my choice in tires. The only thing they did not see was mud holes that look like wet concrete (to much cleanup). These tires run really smooth of hard pack (road and trail). The mud holes I did hit I didn't feel like I needed a mud tire and they actually gripped and pulled a lot better than what I anticipated. They rode smooth on the rocks and I went most everywhere in 2WD. I used 4WD on a hill I wasn't sure about but that was it. I have zero grips about these tires thus far. Cant wait for snow.
2013 Realtree Rhino
PostSubject: Re: ITP Blackwater Evolutions    Wed Oct 30, 2013 8:08 pm
Well I order me a set of the Blackwater Evo today and they should be here tomorrow and hopefully mounted by Friday. I was able to get $250 out of my used OG Bighorns so it was too hard to pass up the difference I was going to have to pay. I also saw your pic above jmp30 made it on ITP's new website on the October picture contest so congrats man!cheers
PostSubject: Re: ITP Blackwater Evolutions    Wed Oct 30, 2013 8:18 pm
what size ya get?
PostSubject: Re: ITP Blackwater Evolutions    Wed Oct 30, 2013 8:34 pm
27x9x14 fronts and 27x11x14 rears same has jmp30 got no lift.
PostSubject: Re: ITP Blackwater Evolutions    Thu Oct 31, 2013 12:05 am
where u gettin that kinda cash Martin? for used bighorns?
PostSubject: Re: ITP Blackwater Evolutions    Thu Oct 31, 2013 12:25 am
Laying around under rocks! My used bighorns went to my local dealership to resale to a customer they have that needed a used set.
