| Sheeve Service | |
+3123.bert0621 JBFIREMAN azzx 7 posters |
azzx
Posts : 27 Join date : 2013-06-20 Location : Arizona
| Subject: Sheeve Service Sat Oct 05, 2013 12:47 am | |
| Guys,
What are the signs for servicing the Sheeve?
I put James’ Sheeve, heavy duty spring, and new belt on about 2000 miles ago. I ride in AZ so there is allot of dust.
Lately when I get near upper 40s MPH (45 – 50) the engine struggles to get to 50. I have Dyantek FI so i am not hitting the rev limiter.
PS. I did valve adjustment last weekend. Can this be caused by bad valve adjustment?
Rhino starts and run perfect otherwise. It just does not have the same gitty up it used to have. I want to get some ideas before I start tearing in to things.
Another question, lately I can smell oil in the cab. I have no oil leaks. I saw James’ crank case breather mod video, I am going to do the mod. Is oil smell related to oil getting in to the air box?
thanks | |
JBFIREMAN
| Subject: Re: Sheeve Service Sat Oct 05, 2013 9:56 am | |
| I would do a full service on the rhino 2000 miles in the dirt is a lot no one is here they are riding in W.V. on the forum ride. | |
| Subject: Re: Sheeve Service Sat Oct 05, 2013 7:39 pm | |
| I would agree with John and measure the width of the belt to! | |
| Subject: Re: Sheeve Service Sat Oct 05, 2013 10:00 pm | |
| Time to service the primary and secondary for sure | |
azzx
| Subject: Re: Sheeve Service Mon Oct 07, 2013 12:06 am | |
| Anything special needed for the service? Do I need any new parts? | |
chalkminer
| Subject: Re: Sheeve Service Mon Oct 07, 2013 2:50 am | |
| Take a look once you are in there. Check the belt and sheave surfaces. You may not need any new parts, but check it out and make sure everything is still good. | |
| Subject: Re: Sheeve Service Mon Oct 07, 2013 4:53 pm | |
| Take a peek at Jame's youtube vids on servicing the clutches. They are worth watching and then you'll know to do it right! Good luck | |
azzx
| Subject: Re: Sheeve Service Mon Oct 07, 2013 6:11 pm | |
| I did oreder a new belt and all of the O rigns and gaskets. I think the smell of oil coming in to the cab I mentioned above is coming from the Sheave possibly. maybe blown seals. I will start the tear down next weekend. | |
| Subject: Re: Sheeve Service Mon Oct 07, 2013 9:21 pm | |
| If the seal is leaking behind the primary, might be a good time to inspect the wet clutch and if its good install some weigthts/slugs. Good luck . | |
| Subject: Re: Sheeve Service Mon Oct 07, 2013 9:27 pm | |
| Make sure you get some ultramatic grease !! | |
| Subject: Re: Sheeve Service Mon Oct 07, 2013 10:27 pm | |
| For sure you need the right lube in the primary | |
azzx
| Subject: Re: Sheeve Service Tue Oct 08, 2013 11:33 am | |
| any special process for cleanning the Sheaves? I have the JBS greasless setup | |
| Subject: Re: Sheeve Service Tue Oct 08, 2013 11:49 am | |
| clean it good then re grease and a new belt...take pics and post them here so we can see whats going on | |
azzx
| Subject: Re: Sheeve Service Tue Oct 08, 2013 12:43 pm | |
| - WV Hot Rod Rhino wrote:
- clean it good then re grease and a new belt...take pics and post them here so we can see whats going on
James, Should i leave it greasless or convert it to a greased setup? I saw in one of your videos that you used grease on the setup I have thanks
| Subject: Re: Sheeve Service Tue Oct 08, 2013 12:45 pm | |
| grease it with ultra matic grease and put the cover on | |
| Subject: Re: Sheeve Service Tue Oct 08, 2013 1:16 pm | |
| Brake cleaner is good, then after you have cleaned and lubed the primary with the o ring and cover, brake clean and scotch pad the sheave surface. | |
| Subject: Re: Sheeve Service | |
| Sheeve Service | |
