| Bad wheel bearing? | |
deerhunter
Posts : 24 Join date : 2013-08-23 Location : Arkansas
| Subject: Bad wheel bearing? Thu Oct 10, 2013 2:48 pm | |
| Subject: Re: Bad wheel bearing? Thu Oct 10, 2013 3:20 pm | |
| yes bad wheel bearing holler at James an get um | |
| Subject: Re: Bad wheel bearing? Thu Oct 10, 2013 3:27 pm | |
| X2. And save yourself the trouble don't go buy aftermarket bearings you will just be replacing them again in a couple weeks. Like Jeff said call James he will have the OEM ones out to you faster then you could get them at your local shop & a better price to. | |
| Subject: Re: Bad wheel bearing? Thu Oct 10, 2013 7:52 pm | |
| There's more side to side play than up and down. Take a look at your knuckle bushings while your at it. | |
| Subject: Re: Bad wheel bearing? Thu Oct 10, 2013 8:22 pm | |
| i just replaced mine. get the whole knuckle assembly and have somebody with a press rebuild the one you take off if it looks o.k. | |
| Subject: Re: Bad wheel bearing? Thu Oct 10, 2013 8:52 pm | |
| - honda450sfm wrote:
- There's more side to side play than up and down. Take a look at your knuckle bushings while your at it.
i agree or at least grease them. | |
| Subject: Re: Bad wheel bearing? Thu Oct 10, 2013 9:00 pm | |
| yea good idea to have a spare | |
Wingman
| Subject: Re: Bad wheel bearing? Fri Oct 11, 2013 12:02 am | |
| Bearings arrived from James today and I changed them tonight. Blind bearing puller and a press ..... Makes the job a lot easier!! | |
| Subject: Re: Bad wheel bearing? Fri Oct 11, 2013 12:07 am | |
| yea nice to have the good tools when you doing jobs | |
| Subject: Re: Bad wheel bearing? | |
