In total there are 10 users online :: 0 Registered, 0 Hidden and 10 Guests :: 1 Bot
 Radiator Fan
Go to page : 1, 2  Next
PostSubject: Radiator Fan   Fri Oct 11, 2013 9:23 pm
First of all, I need to eat a little crow. On another thread about doing the radiator fan over-ride switch I said it didn't seem to make much difference on my Rhino if I had the fan forced on or it just ran auto like stock. It turns out my stock radiator fan was only turning about 50rpm.
In other words, the dang fan was bad! Today, the fan just finally up and died all together. No wonder the ol 734cc motor wanted to heat up on me when I was tearing it up at WOT!
So I need a new fan for my Rhino 700.
Any suggestions?
I'm looking at the TCP radiator fan, I think it's a spal fan on an aluminum shroud. Is this my best option?
The stock Rhino 700 has a shroud from the factory, and the fan is integrated into the plastic shroud. If I go down to the local parts house and just get a universal fan, I'll lose the shroud.
Any advice?
2011 Rhino 734 Sport
2014 Teryx4 800 LE
4500lb Warn
PostSubject: Re: Radiator Fan   Sat Oct 12, 2013 1:36 am
And here is reason enough to get a good gauge.
I saw the water temp was much higher than normal, although the stock overheat light has not yet tripped. I believe the stock overheat light comes on around 240F. I have noticed that when my MSD is connected the temp read by the ECU is always 20F or so lower than my gauge. I guess the ECU reads temp there on the head and the inline splice on the driver side radiator hose is much hotter than the cylinder head.
I'm just throwing this data out there.
2014 Teryx4 800 LE
4500lb Warn
PostSubject: Re: Radiator Fan   Sat Oct 12, 2013 1:50 am
wow
PostSubject: Re: Radiator Fan   Sat Oct 12, 2013 9:55 am
The mud "ate" mine factory fan too.  I went with a factory replacement ,  I picked up from James.  It's been on there for over 2 yrs now without any problems.
And yeah ,  a temp gauge should be the FIRST mod anyone should do !!!
PostSubject: Re: Radiator Fan   Sat Oct 12, 2013 11:12 am
im gonna get the tcp rad and fan
2009 Yamaha Rhino 787
jamesbodyshop@hotmail.com
txgrown1404
PostSubject: Re: Radiator Fan   Sat Oct 12, 2013 11:30 am
I just put the tcp radiator with fan shroud and let me tell you I live in texas where we see 100 degree weather most days in the summer and I was running hot like chris,  I install the tcp rad and it brought my running temps down to around 180 on hot days and now I have been running around 170-165.  second best upgrade I have done ( JBS sheave)  GET IT  cheers
06 686
JBS sheave 14g
purple spring
dual two brother exhaust
rackzilla steering rack
6.5 long travel suspension
Gorilla axles
26" Terra Cross tires on 14" ITP ss rims
temp volt oil pressure a/f gauges
Stereo system
HID headlights & bajas
Carbon fiber dash
billet everywhere
beard custom seats
PostSubject: Re: Radiator Fan   Sat Oct 12, 2013 11:34 am
get me a price James  no reason to stop now. oh yeah  I'm  going broke. lol.
Dave
(Hailey on left and Molly)
PostSubject: Re: Radiator Fan   Sat Oct 12, 2013 12:48 pm
Dave, your gonna have to switch to Early Times at the rate your spending...lol
PostSubject: Re: Radiator Fan   Sat Oct 12, 2013 1:14 pm
good point during the HRR ride mine was running hot due to the dust and I noticed my light wasn't kicking on at 240 I was shutting it down at 230 every time and cleaning it but I did let it get to 240 once we got home and no light scared the shit out of me. I took the radiator out like you talked before and cleaned it real good and straightened all the fins out. James noticed several of them folded over huge difference in cooling after but still thanking about relocating to keep from getting loaded up with dust.
JBS built 787
JBS sheave
Ported head +2 valves
Power steering
Tilt wheel
Suspinsion seats
Muzzy dual exshaust
Stage 4 elka shocks
Pit bull 26.5 Rockers
Bored throttle body
Snorhino
PostSubject: Re: Radiator Fan   Sat Oct 12, 2013 8:42 pm
Did the TCP upgrade a year and a half ago, it is the way to go in my opinion
09 700 fi
14" ITP's with 26" Terracross skins
TJD Track system
ProRhino Doors
JBS Sheave kit
PostSubject: Re: Radiator Fan   Sat Oct 12, 2013 10:17 pm
I looked a little online ...over 5 bills , for the rad...not counting the fan !!!  Is that what they run...or...did I not dig deep enough ?!?
PostSubject: Re: Radiator Fan   Sat Oct 12, 2013 10:47 pm
ebay has some nice looking 3 pass alum. radiators for around 150-180
PostSubject: Re: Radiator Fan   Sat Oct 12, 2013 10:54 pm
All the 3core ones I seen for that $$ , where for a 660...the ones for a 700 in that prce range , were only 2 core ??
PostSubject: Re: Radiator Fan   Sat Oct 12, 2013 11:03 pm
oh sorry didn't didn't know u have a 700 that seems like a big price jump form a 660 to a 700 is there a big difference in rads.
PostSubject: Re: Radiator Fan   Sun Oct 13, 2013 9:44 am
I dunno if there's a difference in size , or not.  The 700 doesn't have a place for thr sensor...wonder how close they are ??  Anyone ???
PostSubject: Re: Radiator Fan   Sun Oct 13, 2013 11:01 am
I just seen a waterproof fan in Jegs
part # 259-16110        10" for  $101
part# 259-16112         12" for $137
could be an option
2009 Rhino SE Red  SOLD SOLD
txgrown1404
PostSubject: Re: Radiator Fan   Sun Oct 13, 2013 11:23 am
the TCP rad is 479.95 on TCP's website  that's where I got mine.  free shipping and ordered it on a Monday and had it buy Friday..
06 686
JBS sheave 14g
purple spring
Gorilla axles
Stereo system
Carbon fiber dash
billet everywhere
beard custom seats
tjt603
PostSubject: Re: Radiator Fan   Sun Oct 13, 2013 9:27 pm
How well did it work ? How much did it lower your temps?
DHILL
PostSubject: Re: Radiator Fan   Sun Oct 13, 2013 10:17 pm
If you are looking to go the less expensive route you might consider doing what I did. I cut the center out of my stock fan shroud and installed a fan from Oreillys. The fan was $50. Have been on two rides since the install and no problems so far.
https://2img.net/h/i1282.photobucket.com/albums/a527/dhillr6/IMAG0162_zps7398e882.jpg
https://2img.net/h/i1282.photobucket.com/albums/a527/dhillr6/IMAG0167_zpsf9c55c2a.jpg
txgrown1404
PostSubject: Re: Radiator Fan   Sun Oct 13, 2013 10:49 pm
its not the fan that is the problem with the cooling system.  its the radiator, single pass radiator that has the inlet and outlet hoses parallel.  TCP's radiator is a triple pass radiator, with inlet & outlet ports offset.  and it holds holds about a half gallon more fluid.
06 686
JBS sheave 14g
purple spring
Gorilla axles
Stereo system
Carbon fiber dash
billet everywhere
beard custom seats
PostSubject: Re: Radiator Fan   Sun Oct 13, 2013 10:57 pm
More coolant and more square inches of cooling surface that's a good investment. But OEM or TCP you have wash them out thorouly
PostSubject: Re: Radiator Fan   Sun Oct 13, 2013 11:39 pm
Ive never really had a problem with running hot, even the hell of a south Texas summer! LoL
I went ahead and ordered the TCP shroud and SPAL fan. And in other news, I found that my fan was froze up. The fan was trying to switch on but was stalled out. It would quickly trip the circuit breaker. You could also tell it was pulling major amps because the battery voltage would drop when the fan would try to start. I was able to free the fan motor with a little "persuasion," haha!
And it actually works! But I don't trust it out in the field.
2014 Teryx4 800 LE
4500lb Warn
PostSubject: Re: Radiator Fan   Sun Oct 13, 2013 11:44 pm
big money dogg...sling'in the poo...lol...when u gettin PS?...Dancing Banana
PostSubject: Re: Radiator Fan   Mon Oct 14, 2013 2:35 pm
I went with the $30 solution when my fan stopped working.
http://hotrodrhinoforums.forumotion.com/t533-radiator-fan
txgrown1404
PostSubject: Re: Radiator Fan   Mon Oct 14, 2013 8:11 pm
whenever I found out if it will work with my steering rack.  my brother sent me a package Label Just Said...... Breakfast......  let me tell u it is delicious.  Tang Tang X Coffee Kush.  best breakfast ive had..  cheers
06 686
JBS sheave 14g
purple spring
Gorilla axles
Stereo system
Carbon fiber dash
billet everywhere
beard custom seats
Radiator Fan
