| Engine braking??? | |
Djbison
| Subject: Engine braking??? Tue Oct 15, 2013 1:35 am | |
| Took my Rhinonout for a turkey ride this weekend I was going down some hills an my engine brake wa working good then it would almost feel like it was going into neutral why is that? Is my wet clutch wore out? | |
| Subject: Re: Engine braking??? Tue Oct 15, 2013 2:19 am | |
| I think James said it is the one way bearing that does this. Mine has been acting up from time to time. Doesn't bother me a whole lot because I am used to driving a rzr. | |
| Subject: Re: Engine braking??? Tue Oct 15, 2013 7:25 am | |
| Subject: Re: Engine braking??? Tue Oct 15, 2013 8:23 am | |
| - Hump wrote:
- I think James said it is the one way bearing that does this. Mine has been acting up from time to time. Doesn't bother me a whole lot because I am used to driving a rzr.
x3 on ur oneway being shot . Dang Hump , yours doesn't have very many miles on it , to be doing that ?!? | |
Djbison
| Subject: Re: Engine braking??? Tue Oct 15, 2013 9:59 am | |
| Ok cool thanks guys I have a new one to out in when I change my wet clutch an slug it!!!! | |
| Subject: Re: Engine braking??? Tue Oct 15, 2013 10:23 am | |
| be sure to check the wet clutch drum also, that it doesn't have groves a little wear there goes a long way toward slipping just my 2 cents on it | |
| Subject: Re: Engine braking??? Tue Oct 15, 2013 11:18 am | |
| one way...seen a few on the newer ones going out quicker than they should | |
Djbison
| Subject: Re: Engine braking??? Tue Oct 15, 2013 12:03 pm | |
| I have a new drum an wet clutch to change it out just have to find the time to do it! Thanks guys!! | |
| Subject: Re: Engine braking??? Tue Oct 15, 2013 2:29 pm | |
| DJ sounds like you ready | |
| Subject: Re: Engine braking??? | |
