In total there are 16 users online :: 0 Registered, 0 Hidden and 16 Guests :: 2 Bots
 Rais tube
Go to page : Previous  1, 2
PostSubject: Re: Rais tube   Sat Oct 19, 2013 12:39 pm
04rhino wrote:
rhino 727..didn,t think of the cable not opening all the way..it has all-ways been a dog sense I got it..esp up in the mtns..had it rejeted by the same place that did the sheave install..surprized it works at all,lol..thanks to this site it runs 100% better..now just looking for the "wow"..Danny
Dancing Banana Dancing Banana Dancing Banana
JBS
Schargedtaco
PostSubject: Re: Rais tube   Sat Oct 19, 2013 2:37 pm
Good work tearing into it! I would check your gas lines, fuel filter and spark plugs, jetting as for your top end issue. Are you hitting the limiter or is it just topped out? Should be hitting at least 50 with the sheave. You mentioned lining up the cam plate? I just threw mine on without adjusting it but seems to be running fine.
PostSubject: Re: Rais tube   Sat Oct 19, 2013 2:44 pm
if you can get a/f gauge to fine tune the carb will get it dead on the money   Dancing Banana
04rhino
PostSubject: Re: Rais tube   Sun Oct 20, 2013 4:29 pm
HI schargedtaco, new fuel filter , spark plug, lines good.. bought the Daynateck cdi when I got the JBS sheave..it just tops out at 45 mph..on the the cam plate , they did not line it up with the splines right..it was a S O B  getting it off with breaking anything or doing more damage...
  Rhino 727: once  I get my top end ~ 55 ish..I will start looking at using a A/F guage..trying to find a good book  for this carburetor/ or source on line..haven,t found what I need yet..biggest problem is tuning at my alt range looking at between 5600 ft- to hopefully 10 K, thats a big range to over come..first high mtn trip after 1st rejet  @ 9200'  it wouldn,t go any more..would idle but thats all..up until I found this site, it was just parked, didn,t have any faith in it..as I said it was a dog..Danny
Schargedtaco
PostSubject: Re: Rais tube   Tue Oct 22, 2013 12:57 am
Pull the main and pilot out and go back to stock for starters I'd check the needle clip and pull off that snorkel intake setup and go back to stock! Unless of course it ran like crap before you did that mod. One last thing to consider is a valve job. I had a 2005 Honda fourtrax 450 I just could not get to run right. Felt like a dog compared to my yamaha 450, mainly top end was crap and just never felt jetted right although it was. Ended up needing valves adjusted. The fact its topping out at 45 mph with a dynatec downhill is concerning. That or maybe you have poor compression or need a carb rebuild. Stock jets should run pretty consistantly anywhere from 4000 to 10k. Rejetting shouldn't be required when going high altitude although it can help though.
04rhino
PostSubject: Re: Rais tube   Tue Oct 22, 2013 1:42 am
Hi Schargedtaco..when it was stock ( no jet changes) at high alt, it was very rich..so the jet change..then on my next trip to marysvale, it wouldn,t go past 9200 elev..so had to have it rejeted again but by then lost faith in it & didn,t use it much..when i found this site thought I would try it again, with the JBS sheave  dynatek 16 gr wts ( year before had orange sec spring installed, helped but still not there) ..need to do a compression test next ( you have  one ?) also was suggested to check ? change the fuel pump ?...checked the throttle cable/ its opens the butterfly all the way..do you know much about  mikuni's ? not having much luck on finding info on them..Danny
PostSubject: Re: Rais tube   Tue Oct 22, 2013 8:12 am
have you checked the valves setting, the carb will act up with a snorkel because of the vacuum pulse that controls the slide ,  have you drilled out  the brass plug  on bottom of carb so you can adjust the mixture screw ?
Schargedtaco
PostSubject: Re: Rais tube   Tue Oct 22, 2013 1:14 pm
Sorry no compression checker, there inexpensive though. I can take a carb apart and clean it/change jets/needle but haven't needed to do a rebuild yet. I would say based on the machine running crappy at high altitude with proper jets you either have a carb rebuild issue, need valve adjust or there's something going on with your intake setup, leak etc. I would start with removing the snorkel setup like Jeff mentioned. Anytime your modifying that extensively and changing things that much and are having running issues that would be my focus.
04rhino
PostSubject: Re: Rais tube   Wed Oct 23, 2013 7:26 pm
Hi Schargedtaco, when I removed the snorkle & Benz exhaust..only made a 0.7mph difference on snorkle / 0.5mph on the Benz. I tested each one seperately ..then put them back together..only lost about 1 mph total.runs strong low & mid-range..it just tops out at 45 on the flats now (by the house in about 1/3 of a mile).... Rhino727..I haven,t heard anything about by running a snorkle it would screw up the vacum signal as I said it only lost about 0.7 mph with snorkle removed..from what I have read for every 2000k elev drop 1 # in jet size...I just wish there was someone local ( greater SLC area.. 100 miles or so ) that truly knows these 660  sxs..it would be worth it to me..to finaly give me the the top end now..James said by getting my top-end it would help my lower end even more..Danny
Schargedtaco
PostSubject: Re: Rais tube   Thu Oct 24, 2013 12:45 am
There are quite a few shops locally that do know the 660 well. Lindsey machine and others can dynotune it. I'd be leaning toward compression or valves if you've made every attempt to check jetting, intake, fuel system, clutch etc. if your topping out and you've eliminated the chance the clutch isn't the issue you may Need valves adjusted or a rebuild. A quick compression check would be the next step! If you say it's running much better from idle to 45 and is getting to speed reasonably quick I would say your sheeve, belt is the issue and its not riding all the way up.
PostSubject: Re: Rais tube   Thu Oct 24, 2013 7:53 am
Danny  glad you had no trouble , but I personally did an if u look it up there's a few wright ups on this stuntman mike spoke of it also . normally on the carbed with vacuum controlled slide if your running any length of tube as in back an up shoulder high the motor will never get to top end because the vacuum that controls the slide gets off      had to drill the holes in bottom of slide so it takes less vacuum to open slide       from what I remember
04rhino
PostSubject: Re: Rais tube   Thu Oct 24, 2013 12:04 pm
Rhino727, thanks for the info ..I will try to find that thread on the vacum signal...my snorkle goes from the intake to just behind the front grill , about 10' reouted it with 2 1/2" industrail duct..Danny
brewis
PostSubject: Re: Rais tube   Thu Oct 24, 2013 1:33 pm
What I have noticed is when I gets colder out my rhino runs leaner.  I operate at 6200" to 9500'. I tried something crazy and took the airbox out and stuck a uni straight to the carb (FCR).  By only changing the air filter I went from 13.5 to 14.5 on the af guage.  I then went from a 140 main jet to a 145 and got a top speed of 54.  This was at 6200' and the af guage was at 12.8.  For me the high twelves on the af is the best running.  I went down to a 142 since I'll be at over 9000' this weekend.
2007 660 Camo, NEW JBS Sheave, 15gr OD weights,Orange spring with anti friction washers, Slugs, Tri Fire CDI, fuel pump relocation kit,  Uni mounterd straight to the carb, siphon break, Alba exhaust, 41 FCR Carb, JBS Radiator Shields, Viper Winch, Power Steering, Diamond Plate A-arm covers and Skid plates, ATV Guard Shop Floor Protectors, RZR seats, Ryde-On Dust Protector, 2" lift, sport shocks, Rhino Horns, Gun Rack, Beer Holders, Mud Lites, Hiper Wheels, Trail Bright Led lights
04rhino
PostSubject: Re: Rais tube   Fri Oct 25, 2013 12:12 pm
Brewis  (Scott).thank you for the info..after I get this rhino running right  I will be doing some tuning for  the various elev  (5600-10k), will keep what you said in mind..James offered for me to use his A/F guage !  Ps I hunt in wyo..looking at cashing in my elk pts next year...Danny
brewis
PostSubject: Re: Rais tube   Fri Oct 25, 2013 5:05 pm
I'd take him up on it, makes tuning a breeze.
Schargedtaco
PostSubject: Re: Rais tube   Mon Oct 28, 2013 7:24 pm
I was able to hit 54 today on a downhill section at grantsville before I chickened out with my 2 kids in the backseat! Need 4 point harnesses for sure at that speed. Felt like it didnt have much more if anything and kinda blipped like it hit a limiter although it has the msd cdi. I noticed though on a long uphill section floored it blipped and momentarily cut out and then ran fine.  Its done that several times at full throttle. Think its due to running rich.
04rhino
PostSubject: Re: Rais tube   Mon Oct 28, 2013 9:17 pm
Schargedtaco..Dam I thought i was done at 48 mph,lol.. would like to get with you sometime, and see what we can come up with on my speed.. how long of a run did it take you for that 54 mph ?..Danny
Schargedtaco
PostSubject: Re: Rais tube   Tue Oct 29, 2013 2:22 am
For sure! We should meet up and see what's going in with it. You should be hitting 48 on a bone stock bike with just a ignition at least on stock tires. I'm thinking if I drop in a 155 should be perfect for winter
What size jets are you running again?
That run took maybe a 100-200 yards guessing it climbed up to 54 real quick. On a flat it takes awhile longer to get there
04rhino
PostSubject: Re: Rais tube   Tue Oct 29, 2013 12:05 pm
mine was running on the flat about  a 1/3 of a mile total  ( 48mph)including shut  down..not sure what the jets were changed to, it was done by the dealer that did my installs  orange spring  & JBS sheave..wouldn,t suprize me if they just adjusted  the A/F mixture and called it good.. now it has great low & mid range just slow on the top-end...lets see what we can come up with , I want to do 54 mph too like you & crusty,lol..Danny
Schargedtaco
PostSubject: Re: Rais tube   Tue Oct 29, 2013 12:29 pm
There's actually a small riding area over by the staker parsons gravel pit. It's the same road that runs from stansbury highschool up to the foothills. There's a cow gate there to get in. Either we could go there or out by grantsville. That place is allitle more open for top end. I'm off today, tomorrow and Thursday until 2pm but am on call.
04rhino
PostSubject: Re: Rais tube   Tue Oct 29, 2013 12:37 pm
just got a call from a friend, going to help him winterize his trailer this morning.. shouldn,t take too long..we could meat up at a easy to find place..let me know..what works for you..Danny ...should be back in a couple hours or so ..Danny
Crusty
PostSubject: Re: Rais tube   Tue Oct 29, 2013 12:38 pm
I work at Staker Parson lol
04rhino
PostSubject: Re: Rais tube   Tue Oct 29, 2013 3:01 pm
Crusty small world, my friends bother works for staker parson..he is a mech/foreman..Grant  W..lives here in Tooele
Crusty
PostSubject: Re: Rais tube   Tue Oct 29, 2013 3:28 pm
Yup I know Mister Grant Walker, Travis Hagar, Paul Proctor, Clay Campbell I could go on forever with the guys that work here that live in Tooele and Grantsville
04rhino
PostSubject: Re: Rais tube   Tue Oct 29, 2013 4:01 pm
They are a big outfit..one of the guys I used to work with drove part time for staker..not sure if he does any more..Rex  Sheilds..if staker gives if us any problems driving thru the gravel pit,  schargeredtaco & I will refur them to you,lol..( just teasing)..Danny
Rais tube
» 2" RAIS intake tube for Rhino
» What modifications have you done to your ride? List here
» Our Sponsors of the Float Tube Fishing Forum
» Kennebec TU float tube
» Float Tube Forum’s First Gathering and Contest
