In total there are 24 users online :: 0 Registered, 0 Hidden and 24 Guests :: 1 Bot
 big boring the 660
Go to page : Previous  1, 2, 3, 4  Next
PostSubject: Re: big boring the 660    Sun Dec 08, 2013 5:13 pm
Same here thats y i stroked it i also have a 4 seat cage an rear seat 2 kids an 28s lol
PostSubject: Re: big boring the 660    Sun Dec 08, 2013 5:17 pm
nice....not many people run the big tires. personally I love em even knowing they rob a good amount of power.
PostSubject: Re: big boring the 660    Sun Dec 08, 2013 5:19 pm
When i first got the rhino i was running 29.5 swamplites but i kept blowing the side walls out of them so i went to 28 zillas an so far no problems an i gained some power back
PostSubject: Re: big boring the 660    Sun Dec 08, 2013 5:57 pm
I was gonna go with zillas but I heard a lot of flat/sidewall flat stories that's why I went with mega mayhems.
PostSubject: Re: big boring the 660    Sun Dec 08, 2013 6:24 pm
ive read the same thing but figured id give them a try an so far they have held up nice no flats yet
PostSubject: Re: big boring the 660    Sun Dec 08, 2013 8:29 pm
So i pulled the valve cover off to check the decomp setup an the 2 small pins off the cam were not in the grooves in the fly weights so i fixed that an made sure it was all working correctly and it is now it starts alittle eaiser but still not like it used too so im assuming ill need a better battery
PostSubject: Re: big boring the 660    Sun Dec 08, 2013 11:27 pm
im going to be building my motor in the spring more than likely....dont know if i will stroke it or not but im REALLY looking forward the added power
2006 Rhino 660
HID conversion
Quick detach snow plow
extended roll cage
4 point harnesses
Hunterworks CDI
700 belt
JBS sheave
14g weights
Purple spring
Mods in progress -
PostSubject: Re: big boring the 660    Mon Dec 09, 2013 11:01 am
i did the 686 big bore with a stage 1 raptor cam an ported head a while back an it did add some decent power but i will say if ur going to tear it down id throw a stroker crank in it i havent drove mine much but i will say that the power diffrence with the stroker is night an day i couldnt belive how much tq is gained an just the feel of the power is awesome.
PostSubject: Re: big boring the 660    Mon Dec 09, 2013 11:12 am
I saw where you were having trouble getting it to turn over and you needed a new battery.  Im running a dual battery set up (second battery is a car battery) with a battery isolater that has the option to flip a switch and connect them for starting.  That might be something to look into.  Also if my accessories (winch and lights and so forth) draw to much it separates the 2 batteries so i can always keep the rhino running and drive out.
2006 Rhino 660
HID conversion
extended roll cage
4 point harnesses
Hunterworks CDI
700 belt
JBS sheave
14g weights
Purple spring
Mods in progress -
PostSubject: Re: big boring the 660    Mon Dec 09, 2013 11:34 am
yea it wont turn over at all unless i have the battery charger on high start the battery is just a cheap never start from walmart with the highest cranking amps i could find. so i think my best bet is do do what u said an put 2 batterys in it an see what happens i just didnt like the idea of more weight in the front but i have to do something to make it start
PostSubject: Re: big boring the 660    Mon Dec 09, 2013 2:21 pm
yeah i know what ya mean with the extra weight...but I look at it like insurance.  I this way i can ALWAYS make it home
2006 Rhino 660
HID conversion
extended roll cage
4 point harnesses
Hunterworks CDI
700 belt
JBS sheave
14g weights
Purple spring
Mods in progress -
PostSubject: Re: big boring the 660    Mon Dec 09, 2013 3:12 pm
vey true. im prob going to go that route with the dual battery setup.
PostSubject: Re: big boring the 660    Mon Dec 09, 2013 5:53 pm
Then you can choose the CCA you want,smart.
PostSubject: Re: big boring the 660    Mon Dec 09, 2013 6:28 pm
when I did mine I when with a Ford Taurus battery.  They are EASY to find anywhere and they are a top post battery (not those silly side post design).  The are also fairly small and fit REALLY well right between the front upper sub frame under the hood. Also you can get them in a high CCA if you need it.  I am running one that is like 600 cca and it seems to work well for me.  Also the battery is pretty cheap.  I got a new one last weekend because my other died (it was a used battery when I put it in) and it was only $50 for a brand new one.
2006 Rhino 660
HID conversion
extended roll cage
4 point harnesses
Hunterworks CDI
700 belt
JBS sheave
14g weights
Purple spring
Mods in progress -
PostSubject: Re: big boring the 660    Mon Dec 09, 2013 7:20 pm
$50.00 bucks is a smoking deal, here they are more than twice that +15 % tax, plus disposal.
PostSubject: Re: big boring the 660    Tue Dec 10, 2013 8:18 am
Rural King had a sale on them (they seem to have a sale on them every week honestly).  They are normally $60 but they were marked down to $49.99.  Like i said for the price and the size fitting perfect and  the availability you just cant beat it.
2006 Rhino 660
HID conversion
extended roll cage
4 point harnesses
Hunterworks CDI
700 belt
JBS sheave
14g weights
Purple spring
Mods in progress -
PostSubject: Re: big boring the 660    Wed Dec 11, 2013 6:42 am
sounds like I deal.. im going to keep messing with mine I found when its dead cold it wont turn over at all it took a car battery an the rhino battery an the charger to get it to turn the other morning so something is not right I would say. im thinking maybe timing is off I checked it when I fixed the decomp setup but I was mostly looking at that an just checked the timing quick going to take my time an make sure its dead on an go from there
PostSubject: Re: big boring the 660    Wed Dec 11, 2013 9:13 am
Ok so i pulled the rhino apart after work this morning an the cam timing is off a tooth ( the cam is rolled towards the exhaust 1 tooth ) now can i put the chain guide out an have enough slack in the chain to roll it a tooth?
PostSubject: Re: big boring the 660    Wed Dec 11, 2013 11:16 am
I did.mine like that attatched zip.ties to the timing chain so it wouldnt come off down below, its not fun but its possible.  mine is a 700 dont think that matters though....
Crusty
PostSubject: Re: big boring the 660    Wed Dec 11, 2013 3:01 pm
If I still have hard start issues when I get mine back I'm for sure checking this even tho he swears it's on. Thanks
PostSubject: Re: big boring the 660    Wed Dec 11, 2013 9:03 pm
yea I talked to the guy that did my motor an he said he checked it twice an he does good work but I knew something was up with the way it started an it was driving me nuts so I pulled it apart this morning an sure enough its off a tooth hopefully that will fix it im still going to buy a good battery just to be safe
CamoRhino660
PostSubject: Re: big boring the 660    Wed Dec 11, 2013 10:38 pm
I would triple check your decompression pins also if it starts hard. I need to pull mine apart and go threw the decomp setup cause mine starts hard also. And every now and again it sounds like it spins backwards for a second.
PostSubject: Re: big boring the 660    Wed Dec 11, 2013 10:51 pm
I checked them the last time I pulled it apart an it wasn't hooked up right so I fixed that its working correctly now but didn't help at all. this time I pulled it apart to check timing witch I should have done the first time an its off a tooth or so but decomp its lined up right an working
CamoRhino660
PostSubject: Re: big boring the 660    Wed Dec 11, 2013 11:02 pm
Well maybe that's my prb or maybe it's that I still have the ORIGINAL battery!! It's a 06. Lol!
PostSubject: Re: big boring the 660    Wed Dec 11, 2013 11:04 pm
wow id say u got your life out of that battery lol
big boring the 660
Page 3 of 4Go to page : Previous  1, 2, 3, 4  Next
» 05 Forum is very Boring
» Is Tennis Getting Boring?
» Boring heavyweights?
» Who are some wrestlers everyone seems to love but you find boring?
» Most Boring Olympic Sport So Far?
HOTRODRHINOFORUMS.COM :: Technical :: Rhino Builds-
