 who is running 27" tires????????????
PostSubject: who is running 27" tires????????????   Tue Oct 15, 2013 8:51 pm
A few months ago I bought four new ITP rims ( don't ask why). anyways I am running 26" Interco Reptiles on ITP beadlocks currently on the Rhinojet. I figured I would try a different brand on the new rims. Today I went to order ITP Terracross tires for the new rims in 27" and low and behold...................they don't come in 27". The new rims are 12" like the beadlocks so if I'm gonna run 26" tires I'll just use the Reptiles on these new rims but I would like to try a 27" tire.....................who has 27"'s and what are they? Thanks.
Dave
(Hailey on left and Molly)
PostSubject: Re: who is running 27" tires????????????   Tue Oct 15, 2013 9:03 pm
Mine had 27's on it when I bought it. It only took one trip on the hill , and them babies came off !!!  IMO , for the way you and I ride, the extra rubber  , is not worth the loss in/of power. I'm sure I'll get a lot of flack for saying that ; but , I know you like to go fast (so do I ) , that big rubber is gonna slow ya down , in speed as well as power. Now , after saying all of that...I have two sets of se wheels...thinkn pretty hard , on doing 26-9's on all front wheels next go around.
PostSubject: Re: who is running 27" tires????????????   Tue Oct 15, 2013 9:14 pm
yeh, your'e right, mabe i'll just throw the 26" reptiles on the new ITP rims.
Dave
PostSubject: Re: who is running 27" tires????????????   Tue Oct 15, 2013 9:32 pm
not 27s but 28s here. there is a noticeable loss in power and greater strain on all the parts. but for my style of riding bigger is better. I ride very rocky terrain and im also in a lot of mud. the taller tires are nice for extra ground clearance and great looks that's about it. perfect example is on the hhr ride tony was stuck in a hole high centered needed a winch out. I then drove in , out and across the same hole with no problems. (sorry tony)....
Schargedtaco
PostSubject: Re: who is running 27" tires????????????   Tue Oct 15, 2013 11:05 pm
My bike came with ITP 27 inch mud lights, with the jbs sheave its got more getup than the stock tires without sheeve but not by alot. I can spin the tires loose alot more torque  though and top speed around 50 which should be about 53 speed corrected. If I where to do it over again I'd go 26,s for sure for look and performance less wear. I have to admit though the 27s have a way cushy ride over everything its like adding a suspension!
PostSubject: Re: who is running 27" tires????????????   Tue Oct 15, 2013 11:25 pm
Well, James is still under the weather. Looks like he got a infection from the dental work. I'll wait and see what he says. He has done the sheave, throttle body, cam, springs etc to the rhinojet. It's down there now for ported polished head, piston and alba exhaust.  I don't think power will be an issue turning 27's.
Dave
PostSubject: Re: who is running 27" tires????????????   Tue Oct 15, 2013 11:30 pm
Did he get Hunteritis? Heard its a bad deal, and real hard on your parts...lmao...get well bro!
PostSubject: Re: who is running 27" tires????????????   Wed Oct 16, 2013 12:28 am
Dave, I've ran 27X14 on my 450 for about a year a 1 1/2. I can still hit 43 mph on the flats and make it over some pretty good sized down timber on the back trails. I think anything over sized on a 450 hurts it's power but she'll spin pretty good in the mud. With what you're doing to the Jet you shouldn't have much problem spinning 27's. Just my thought. Happy Trails......w/Jack. drunken
08/700 SE;Stocker
PostSubject: Re: who is running 27" tires????????????   Wed Oct 16, 2013 12:49 am
I have put about 250 miles on my 27's and I did lose a little bit of power but with my mods it still handles them fine.  I still haven't got my front end or steering stuff all fixed from my wreck but I have still hit 61 a few times with them.  Now I finally get to use low sometimes.
27" EFX Motoclaws
JE 11:1 102mm
Warn Pro Vantage 3500lb.
Ricochet a-arm skids
PRM bash plate
Unisteer Rackzilla
PostSubject: Re: who is running 27" tires????????????   Wed Oct 16, 2013 7:48 am
He'll tell ya to run 25" Bighorns...cheers
PostSubject: Re: who is running 27" tires????????????   Wed Oct 16, 2013 7:54 am
I'll tell him "ok" and sneak 26's in on him.....lol.
Dave
wolverine34
wolverine34
PostSubject: Re: who is running 27" tires????????????   Wed Oct 16, 2013 8:21 pm
i'm running 27" STI Roctanes with 14" STI rims
Skinny Pedal Club
2008-700-Rhino
JBS Sheave
JBS Rear Skid Plate
Power Steering
STI Roctane
STI HD3
MSD
Teryx Shocks
meats
meats
PostSubject: Re: who is running 27" tires????????????   Wed Oct 16, 2013 8:33 pm
i run 27" mudlite xtr's seems to do about right
04, 660 msd cdi, jbs sheave, orange spring, 14g weights, 26" big horns
PostSubject: Re: who is running 27" tires????????????   Wed Oct 16, 2013 8:46 pm
I'm gonna go with the 26X12 ITP Terracross..................well, that what jack and I just agreed too.  lol. ITP doesn't make them in 27's.
Dave
Bayou Tiger
Bayou Tiger
PostSubject: Re: who is running 27" tires????????????   Wed Oct 16, 2013 9:34 pm
No problem Mike. Who knew 2" can make such difference!!!  LOL
2012 700SE
PostSubject: Re: who is running 27" tires????????????   Wed Oct 16, 2013 10:10 pm
you should see teddy try to get in one with 28s...lmao
2009 Yamaha Rhino 787
jamesbodyshop@hotmail.com
Wingman
PostSubject: Re: who is running 27" tires????????????   Wed Oct 16, 2013 10:20 pm
I have been running 27" tires for 5 years. I noticed a loss of low end in the beginning. Gained a little back with the shim and then a whole lot with the JBS sheave!!
PostSubject: Re: who is running 27" tires????????????   Wed Oct 16, 2013 10:24 pm
Who me? Get 28's for the rhinojet?
Dave
PostSubject: Re: who is running 27" tires????????????   Wed Oct 16, 2013 10:33 pm
Interco swamp lite's come in 27 and 28's.     Wooooooo hoooo. What yah say ?????
Dave
UnderDawg
UnderDawg
PostSubject: Re: who is running 27" tires????????????   Wed Oct 16, 2013 11:04 pm
I've been running nothing but mud tires on my rides for the last couple of years... but been thinking real hard on a set of 27''Black Diamond XTR's on black 108's
09 camo 450
» 26"x9"x12" Tires All the way around?
» Anyone running a Super swamper truck tire?
» Polaris tires and rims
» IOC reject cross country running for winter games
» Bigger tires on your lawnmower
HOTRODRHINOFORUMS.COM :: Other Off-Road, UTV, and Watersports Discussion :: Trucks, Tow Rigs, RV's and Camping-
