 stage 1 and 2 cam
jaydog13
PostSubject: stage 1 and 2 cam   Fri Oct 18, 2013 3:09 pm
what are the differences in the raptor stage 1 and raptor stage 2 cams
PostSubject: Re: stage 1 and 2 cam   Fri Oct 18, 2013 4:50 pm
stage 1 is a good all around cam,stage 2 is more upper midrange and top end.
PostSubject: Re: stage 1 and 2 cam   Fri Oct 18, 2013 7:17 pm
there is less overlap on the stage 1 cam; it has a longer intake duration and shorter exhaust duration which results in more bottom end torque
from the hotcams catalog:
JBS
jaydog13
PostSubject: Re: stage 1 and 2 cam   Sat Oct 19, 2013 9:56 am
if I switch to a stage 1 raptor can I still use the spring kit that I installed for the stage 2
PostSubject: Re: stage 1 and 2 cam   Sat Oct 19, 2013 12:31 pm
no
JBS
PostSubject: Re: stage 1 and 2 cam   Sat Oct 19, 2013 1:40 pm
Yes..i still run the kibble white springs with my stage 1 raptor cam...it will be fine.cheers
PostSubject: Re: stage 1 and 2 cam   Sat Oct 19, 2013 2:15 pm
yes I also run kibble springs an I run the mud buster stage one no problem  cheers
PostSubject: Re: stage 1 and 2 cam   Mon Oct 21, 2013 12:01 am
same here kibble springs stage 1 raptor cam
PostSubject: Re: stage 1 and 2 cam   Mon Oct 21, 2013 10:17 am
Before you spend $180+ on a Stage1 or Stage2 Cam you might purchase yourself a factory raptor cam for $20 and try it "thekevin" runs one on his after taking out his Stage3 cam and loves the bottom end,midrange, and topend since the curve is a more smooth curve and less of a radical spike in between might be what your looking for. I run a Stage2 Hot cam and I like it alot more topend HP but there is some tuning for sure involved with fuel controller to get it to run as it should and out of the stock raptor, stage2, or stage3 cams the stock raptor was the only one that didnt have a lull on take off even though the stage2 and stage3 lull can be tuned to get alot of it out but not all of it. Just my 2 cents for ya!
Bayou Tiger
PostSubject: Re: stage 1 and 2 cam   Mon Oct 21, 2013 11:34 am
I just purchased a stock Raptor cam, can't wait to get it in...
2012 700SE
stage 1 and 2 cam
