 Adjust carburetor slide on 04 660 rhino
04rhino
PostSubject: Adjust carburetor slide on 04 660 rhino   Fri Oct 18, 2013 7:38 pm
my rhino with JBS sheave &orange spring will only top out at 45 MPH..talked to James and checked  a few things and it looks like my carb slide isn,t opening up all the way ..so no top end..searched on here & you tube but didn,t find anything for the 660..so need help,lol..Danny
PostSubject: Re: Adjust carburetor slide on 04 660 rhino   Fri Oct 18, 2013 8:51 pm
not sure if they can be adjusted as its a vacuum slide have u pulled it out an cleaned it and the carb where it slides. I know they will get dirty an stick I clean mine with some wd-40 an wipe it down good.
PostSubject: Re: Adjust carburetor slide on 04 660 rhino   Fri Oct 18, 2013 9:20 pm
have you check the throttle cable adjustment may not let you open the butterfly wide open if its not adjusted correct
PostSubject: Re: Adjust carburetor slide on 04 660 rhino   Fri Oct 18, 2013 10:01 pm
good point, ive heard the throttle cables stretch over time on the rhinos not sure if its true but worth a look
PostSubject: Re: Adjust carburetor slide on 04 660 rhino   Fri Oct 18, 2013 10:06 pm
mine did , an dam what a difference  Dancing Banana
04rhino
PostSubject: Re: Adjust carburetor slide on 04 660 rhino   Sat Oct 19, 2013 12:18 am
.will check that out on the throttle cable stretching..will try to find a break down of the  carburetor assembly and clean it up or replace the vacum diaphragm..it never has really been fast..but when I first got it had it rejeted for running in the mtns and just has allways been a dog..again thanks guys for all the suggestions..Danny
PostSubject: Re: Adjust carburetor slide on 04 660 rhino   Sat Oct 19, 2013 9:59 am
have you looked at the plug see what color it is , better than that get /borrow a a/f gauge  make sure the jetting is correct , if its always been a dog may have been set-up wrong back then
04rhino
PostSubject: Re: Adjust carburetor slide on 04 660 rhino   Mon Oct 21, 2013 5:53 pm
well checked a few more things..throttle cable opens carb butter- fly all the way open..valve lash good..other than the top speed runs much better..any more suggestions ? Danny
