 Camshaft question on a 660
Go to page : Previous  1, 2
PostSubject: Re: Camshaft question on a 660   Sun Oct 20, 2013 12:44 pm
let me know if i can help
2009 Yamaha Rhino 787
jamesbodyshop@hotmail.com
Crusty
Crusty
PostSubject: Re: Camshaft question on a 660   Sun Oct 20, 2013 12:49 pm
Thanks James
PostSubject: Re: Camshaft question on a 660   Sun Oct 20, 2013 2:03 pm
that head an piston brought back memory's of mine , mine cracked the head so look at that close if you plan to run it, also check the rod good that it did not bend , I would go ahead an check out the bottom  end at this point for assurance, an all so I cleaned out a lot of piston peace's  out of the bottom end an you can check the middle support also while you got it open
» Pulley Question
» grip strength advice..ask david horne any question on grip training....
» Level Adjust Question
» Boston Qualifying Question
» Boston 2013 Qualifying Question
