In total there are 8 users online :: 0 Registered, 0 Hidden and 8 Guests :: 2 Bots
 Replaced factory lights with LEDs
Go to page : 1, 2  Next
PostSubject: Replaced factory lights with LEDs   Sun Oct 20, 2013 5:03 pm
I picked up some round LED lights from Flimmy to put in place of the factory headlights.  Light bar was to bright to run out on the pavement and the factory headlights are a joke, not to mention down right dangerous.  Seen all the hid bulb replacements with one light always burned out and balasts always going bad.  So I got this "bright" idea.  Ran it by Flimmy at the group ride and he hooked me up.
Pictures coming soon.
Stage 2 cam
Black Rhino CDI
Bazzaz fuel controller
Hot Rod sheave with 16g ODs
Purple secondary
PostSubject: Re: Replaced factory lights with LEDs   Sun Oct 20, 2013 5:06 pm
Stage 2 cam
Black Rhino CDI
Purple secondary
JOHN DILLARD
PostSubject: Re: Replaced factory lights with LEDs   Sun Oct 20, 2013 5:43 pm
Hey hump they look good I done the same thing. They work out great don't know why someone hasn't marketed these.
PostSubject: Re: Replaced factory lights with LEDs   Sun Oct 20, 2013 5:46 pm
I took the bottom mounts off the lights.  The back of the lights have 4 #10 holes drilled and tapped.  So I made a plate to bolt up to them and bolt through the factory holes in the sides that held the old lights.  Had to do a hack job on the buckets, but I don't care.
Stage 2 cam
Black Rhino CDI
Purple secondary
PostSubject: Re: Replaced factory lights with LEDs   Sun Oct 20, 2013 5:50 pm
Great job Hump. cheers
I might have to order another set and try this myself
Owner of
www.trailbrightled.com
Moto Alliance dealer
Pro Armor dealer
Rocky Mountain ATV dealer
JOHN DILLARD
PostSubject: Re: Replaced factory lights with LEDs   Sun Oct 20, 2013 5:58 pm
I used HD style driving lights and clamps modded and original mounting holes no plastic mod.easy mod and still use factory switch.
PostSubject: Re: Replaced factory lights with LEDs   Sun Oct 20, 2013 7:35 pm
THat's great.  That's what I did with the wires.  They come on with low beam on the factory switch.  I had to do some cutting to clear the bottom of the light where the mount used to bolt up.  Could have cut that part off the light, but decided to cut the factory housing since it wouldn't matter if water/mud got in there anymore.
Stage 2 cam
Black Rhino CDI
Purple secondary
PostSubject: Re: Replaced factory lights with LEDs   Sun Oct 20, 2013 7:38 pm
These fit really tight.  Had to shove them in pretty hard.  I can't wait to try them out.  They have a wide flood pattern and that's what I was needing.  I have my light bar aimed a little high, so it has everything else covered for the most part.
Stage 2 cam
Black Rhino CDI
Purple secondary
PostSubject: Re: Replaced factory lights with LEDs   Sun Oct 20, 2013 8:03 pm
nice!!
2009 Yamaha Rhino 787
jamesbodyshop@hotmail.com
PostSubject: Re: Replaced factory lights with LEDs   Sun Oct 20, 2013 8:10 pm
Great job! those look nice and bright!Shocked
PostSubject: Re: Replaced factory lights with LEDs   Sun Oct 20, 2013 8:43 pm
Can't wait to here how they do sounds like a great idea my hid are acting up might be something I need to look into.
JBS built 787
JBS sheave
Ported head +2 valves
Power steering
Tilt wheel
Suspinsion seats
Muzzy dual exshaust
Stage 4 elka shocks
Pit bull 26.5 Rockers
Bored throttle body
PostSubject: Re: Replaced factory lights with LEDs   Sun Oct 20, 2013 10:03 pm
That's an awesome idea, something to really think about.
Crusty
PostSubject: Re: Replaced factory lights with LEDs   Sun Oct 20, 2013 10:12 pm
looks way good, might have to do that to mamma's Rhino since the guy I bought it from painted the Damn headlights lol
PostSubject: Re: Replaced factory lights with LEDs   Sun Oct 20, 2013 10:29 pm
Bad ass man !!! My dad swapped the ones out on his terx...his are oe ; but , they look just like those !!  What size are they ?!?
PostSubject: Re: Replaced factory lights with LEDs   Mon Oct 21, 2013 10:07 pm
They are 4 1/2".  They barely squeezed in the factory holes after I cut out the bottom to clear the housing where the pedistal mount bolts up.  There may be alot of diferent ways to mount them up in factory location if you get creative.
here's the link: http://www.trailbrightled.com/45-round-18w_p_50.html
Stage 2 cam
Black Rhino CDI
Purple secondary
Snorider
PostSubject: Re: Replaced factory lights with LEDs   Mon Oct 21, 2013 10:37 pm
I really like that. Great job. now I want to do it. lol.
flimmy how much are those?
no wait..... I don't want to know, well yea I do,
08 700 special-cam/muzzys/3d msd/sheave 16g grease-less greased weights/gold spring w/friction washers/slugged/wide spool viper/26" blackdiamond XTR's on stock alum rims Smile love it Dancing Banana
PostSubject: Re: Replaced factory lights with LEDs   Mon Oct 21, 2013 10:58 pm
They are $42 ea but if I do a group buy and people are willing to wait about 3 weeks I can do better.  I'll have some numbers tomorrow.  I would need about 12 lights. To bring the price down.
Owner of
Pro Armor dealer
Snorider
PostSubject: Re: Replaced factory lights with LEDs   Mon Oct 21, 2013 11:01 pm
I'm up for waiting. especially after going through my sled.
PostSubject: Re: Replaced factory lights with LEDs   Mon Oct 21, 2013 11:35 pm
I'm also interested
PostSubject: Re: Replaced factory lights with LEDs   Tue Oct 22, 2013 6:44 am
Would this work on a 04 model also ?
JBS built 787
JBS sheave
Power steering
Tilt wheel
Suspinsion seats
Muzzy dual exshaust
Stage 4 elka shocks
Bored throttle body
PostSubject: Re: Replaced factory lights with LEDs   Tue Oct 22, 2013 5:54 pm
I think they are all the same Teddy.  I'm not totally happy with the way I mounted them up, but I done a quick job.  If they stay aimed after a hard ride I will be ok.  Be very careful shoving them back in those holes because they fit really tight.  I thought they may have looked a little stupid compared to the factory lights, but I like it much better.
Stage 2 cam
Black Rhino CDI
Purple secondary
Crusty
PostSubject: Re: Replaced factory lights with LEDs   Tue Oct 22, 2013 6:24 pm
Gonna have to do this on Mamma's Pink Rhino since the guy had spray painted the headlights when he painted the rest of the machine lol
Luckily I happen to have 4 LED's like that already.
PostSubject: Re: Replaced factory lights with LEDs   Tue Oct 22, 2013 6:48 pm
well there's another mod I want , Steve  let us know how much brighter than stock they are , these are just on/off no high low right
PostSubject: Re: Replaced factory lights with LEDs   Tue Oct 22, 2013 7:04 pm
Jeff , just on and off , no hi/lo
Owner of
Pro Armor dealer
chalkminer
PostSubject: Re: Replaced factory lights with LEDs   Wed Oct 23, 2013 12:46 am
But wait...  What if we wired these to the low circuit and and added an LED light bar and wire that to the high circuit?  Hmmmmm....
