In total there are 9 users online :: 0 Registered, 0 Hidden and 9 Guests :: 2 Bots
 middle drive support
PostSubject: middle drive support    Thu Oct 24, 2013 2:51 am
im shopping for a billet middle drive gear support I see utv inc has them for 110 an weller has em for 250 is there a difference in them? I know wellers looks better but its twice the money are there any others out there that are any good? thanks
PostSubject: Re: middle drive support    Thu Oct 24, 2013 7:18 am
the difference is about $140 LOL.....sorry nothing useful to add here...just poking fun.
2006 Rhino 660
HID conversion
Quick detach snow plow
extended roll cage
4 point harnesses
Hunterworks CDI
700 belt
JBS sheave
14g weights
Purple spring
Mods in progress -
PostSubject: Re: middle drive support    Thu Oct 24, 2013 7:27 am
I would think if both are billet an made to specs they would be same as far as the part goes  sounds like $$$$$, maybe the ole thought that some just want all our  fun funds    scratch
PostSubject: Re: middle drive support    Thu Oct 24, 2013 7:41 am
Both are billet. wellers looks thicker but could be just me.. An its red maybe thats y i cost more lol but i just dont want to buy a junk one an have it break. Rhino727 do u know what support u have?
PostSubject: Re: middle drive support    Thu Oct 24, 2013 8:09 am
don't remember like I should may be to much  drunken drunken drunken    will  dig through old parts recites an get back to ya
PostSubject: Re: middle drive support    Thu Oct 24, 2013 9:04 am
utv  the one I got fit was great keep the same shims as stock
PostSubject: Re: middle drive support    Thu Oct 24, 2013 10:18 am
i get mine from alba
2009 Yamaha Rhino 787
jamesbodyshop@hotmail.com
PostSubject: Re: middle drive support    Thu Oct 24, 2013 7:30 pm
ok cool thanks for the info guys. james do u sell the supports? price?
CamoRhino660
PostSubject: Re: middle drive support    Thu Oct 24, 2013 10:05 pm
I got mine from unleashed utv. It was $99 and fit perfect.
PostSubject: Re: middle drive support    Thu Oct 24, 2013 10:55 pm
unleashed utv drive plate looks the same as utv inc so ill go with one of those thanks guys. one more question im ordering a stroker crank at the same time as the support I see hotrods cranks for a decent deal are there any other one out there that are better for a 660 I hear u should weld the pin in the hotrods crank? like to get one of those falicon cranks but haven't seen any for a 660
PostSubject: Re: middle drive support    Fri Oct 25, 2013 7:27 am
i have 1 falicon 660 crank in stock but they aint cheap...
PostSubject: Re: middle drive support    Fri Oct 25, 2013 8:10 am
Whats not cheap? I dont mind spending money for good parts.
