In total there are 42 users online :: 0 Registered, 0 Hidden and 42 Guests
660 rear differential and chassis rebuild Icon_minitimeWed Aug 16, 2023 1:17 pm by RADICAL RAM
660 rear differential and chassis rebuild Icon_minitimeThu Dec 14, 2017 4:54 pm by WV Hot Rod Rhino
660 rear differential and chassis rebuild Icon_minitimeThu Dec 14, 2017 1:28 am by WV Hot Rod Rhino
660 rear differential and chassis rebuild Icon_minitimeThu Dec 14, 2017 12:35 am by WV Hot Rod Rhino
660 rear differential and chassis rebuild Icon_minitimeFri Dec 13, 2013 11:01 am by WV Hot Rod Rhino
660 rear differential and chassis rebuild Icon_minitimeFri Dec 13, 2013 10:59 am by WV Hot Rod Rhino
660 rear differential and chassis rebuild Icon_minitimeFri Dec 13, 2013 9:33 am by Tacoclaw
660 rear differential and chassis rebuild Icon_minitimeFri Dec 13, 2013 7:50 am by chuddly
660 rear differential and chassis rebuild Icon_minitimeFri Dec 13, 2013 7:47 am by chuddly
660 rear differential and chassis rebuild Vote_lcap660 rear differential and chassis rebuild Voting_bar660 rear differential and chassis rebuild Vote_rcap
Baxter Built Fabrications
11 posters
Go to page : 1, 2  Next
660 rear differential and chassis rebuild Empty
PostSubject: 660 rear differential and chassis rebuild   660 rear differential and chassis rebuild Icon_minitimeFri Oct 25, 2013 1:55 pm
This is the second 660 chassis I've had to read mount the diff in.This one is bad.I'll post pics as I get stuff ready for surgery.Yamaha would replace these chassis for this problem.When I'm done that diff won't move.If you own a 660 and have repeating axle breaking in the back it's caused from chassis deflection.A diff saver would fix the problem but this one is way beyond that.
660 rear differential and chassis rebuild Null_zps239e7b9d Pics to come.
PostSubject: Re: 660 rear differential and chassis rebuild   660 rear differential and chassis rebuild Icon_minitimeFri Oct 25, 2013 8:27 pm
Really sounds interesting I will watching your pictures, for sure.
PostSubject: Re: 660 rear differential and chassis rebuild   660 rear differential and chassis rebuild Icon_minitimeFri Oct 25, 2013 11:12 pm
I got it stripped down earlier today.It's been welder a few times it looks to me.But it's bad news either way. 660 rear differential and chassis rebuild Null_zps6c018d50 I started getting it repositioned before I quit today.I'll get pics up of that tomorrow.
PostSubject: Re: 660 rear differential and chassis rebuild   660 rear differential and chassis rebuild Icon_minitimeFri Oct 25, 2013 11:15 pm
660 rear differential and chassis rebuild Null_zpse05c22b8 The back tube running horizontal has been but welded together.I'll be removing it too.prob bump the size up to 1 1/4 .120 wall DOM to help stiffen it up.
PostSubject: Re: 660 rear differential and chassis rebuild   660 rear differential and chassis rebuild Icon_minitimeSat Oct 26, 2013 12:48 am
looks like the 2nd one to let go recently on here ,  hate to see such carnage   good luck on the repair
PostSubject: Re: 660 rear differential and chassis rebuild   660 rear differential and chassis rebuild Icon_minitimeSat Oct 26, 2013 3:06 am
I just did one last winter.That guy had the engine cradle pushed up over an 1 1/2 ".It would even shift anymore.The diff tabs didn't look this bad but they still needed replaced.I cut the hole bottom out of it and started over.They just need to be properly jigged before you cut everything loose.
PostSubject: Re: 660 rear differential and chassis rebuild   660 rear differential and chassis rebuild Icon_minitimeSat Oct 26, 2013 4:18 am
geterdun
PostSubject: Re: 660 rear differential and chassis rebuild   660 rear differential and chassis rebuild Icon_minitimeSat Oct 26, 2013 12:07 pm
You have your work cut out for you, but I bet you enjoy a challenge, want to see more as you go.
PostSubject: Re: 660 rear differential and chassis rebuild   660 rear differential and chassis rebuild Icon_minitimeSat Oct 26, 2013 12:15 pm
nothing like some good fabricating making  some thing better than it was to start with   Dancing Banana Dancing Banana Dancing Banana
PostSubject: Re: 660 rear differential and chassis rebuild   660 rear differential and chassis rebuild Icon_minitimeSat Oct 26, 2013 12:30 pm
I am putting on my diff reinforcement bracket today I hope this is not common on 2008's to.
PostSubject: Re: 660 rear differential and chassis rebuild   660 rear differential and chassis rebuild Icon_minitimeSun Oct 27, 2013 1:57 am
That's what I have is a 08 700 and it's not built anything like the 660 in the back. they changed some things for the good in the 700 chassis but a diff brace is still not a bad idea.
PostSubject: Re: 660 rear differential and chassis rebuild   660 rear differential and chassis rebuild Icon_minitimeSun Oct 27, 2013 2:15 am
One side of the diff jig is welded.to the chassis. The other side is clamp in to get all if the pieces to fit right.Bear with me as I get the pics in order.660 rear differential and chassis rebuild Null_zpsa2de7314
PostSubject: Re: 660 rear differential and chassis rebuild   660 rear differential and chassis rebuild Icon_minitimeSun Oct 27, 2013 2:18 am
Both of these tabs were file fit to the frame rails with a caliper to insure that it's level to the frame rails.660 rear differential and chassis rebuild Null_zpsc34fcdb7
PostSubject: Re: 660 rear differential and chassis rebuild   660 rear differential and chassis rebuild Icon_minitimeSun Oct 27, 2013 2:22 am
On this pic you will see a short piece of tube slid over the smaller tube. this insure that once everything is in place that the diff is exactly where it was left and right in the chassis from the factory.660 rear differential and chassis rebuild Null_zpsbdc22a42
PostSubject: Re: 660 rear differential and chassis rebuild   660 rear differential and chassis rebuild Icon_minitimeSun Oct 27, 2013 2:24 am
This is what it looks like from over head all put onto place.660 rear differential and chassis rebuild Null_zps3a22f1ef
PostSubject: Re: 660 rear differential and chassis rebuild   660 rear differential and chassis rebuild Icon_minitimeSun Oct 27, 2013 2:33 am
In this pic you can see the hole in the diff has been egg shaped.This is a custom bolt that Yamaha makes in this size.So it's not common to find one one this long or longer in stock anywhere.What I plan to do is bore the hole in the diff to 7/16 so that I can take the slop out of the hole.If you give it an inch it will take a mile sorta thing.it's no big deal to bore the holes in a different diff if this one should fail and it only helps to go slightly larger. there is plenty of beef in the boss on that diff.660 rear differential and chassis rebuild Null_zpsbafebf94 the gold bolt is the 7/16 replacement before I bored the hole so as you can see it's already there on this end.
PostSubject: Re: 660 rear differential and chassis rebuild   660 rear differential and chassis rebuild Icon_minitimeSun Oct 27, 2013 2:34 am
660 rear differential and chassis rebuild Null_zps5577737d
PostSubject: Re: 660 rear differential and chassis rebuild   660 rear differential and chassis rebuild Icon_minitimeSun Oct 27, 2013 2:49 am
On this pic I show the mach up of the new diff tab before I cut everything loose.It fits perfectly into position. I may rewrite the program to put the diff support on the diff tabs for less crap going on in the back of this thing.In my line of work with my business this is not a challenge.This is what I do on Heavy Equipment so this little Rhino is in good hands. Lol Why buy a new chassis that is problematic for more money when you can have it redesigned for less.660 rear differential and chassis rebuild Null_zps61262565
Disclaimer: All products have their faults but this is no Polaris so we're golden everywhere else. Lol It will prob be Mon. before I'm back on this project.Any questions feel free to call any time at 419-953-8509.If I don't answer I'll only be sleeping for a few hrs. Lol
PostSubject: Re: 660 rear differential and chassis rebuild   660 rear differential and chassis rebuild Icon_minitimeSun Oct 27, 2013 6:14 am
looks like your ready to go in the production of rear mounts , that mount is sweet cheers   did u use a cnc plasma to cut out , very nice set-up on diff to keep in place ,   on the mount tab hole your boring out   would there be enough area to install hardin bushing might hold up longer than the aluminum housing
PostSubject: Re: 660 rear differential and chassis rebuild   660 rear differential and chassis rebuild Icon_minitimeSun Oct 27, 2013 10:01 am
That's some nice work,looks great and should last forever!!
PostSubject: Re: 660 rear differential and chassis rebuild   660 rear differential and chassis rebuild Icon_minitimeSun Oct 27, 2013 10:34 am
very nice!!
PostSubject: Re: 660 rear differential and chassis rebuild   660 rear differential and chassis rebuild Icon_minitimeSun Oct 27, 2013 11:24 am
WOW!!!!!!!!!!!!!!!!!!!!! nice, nice, very nice workmanship. cheers
PostSubject: Re: 660 rear differential and chassis rebuild   660 rear differential and chassis rebuild Icon_minitimeSun Oct 27, 2013 3:40 pm
Thanks for the props fellas.I'm on my way back out to work on this thing.I'm bored and I can't start my project till I get the lift back.Finally going to pull my 08 out and start the demolition on it.I'll start that thread on here.Project "Rhino Resurrected"! Fuel tank relocated,6" seat drop,6"boat side,bed delete and crab cut.I have a guy coming over after I get the shell done and we are doing some carbon fiber parts for it.Make it look mean then buy a JBS motor and make it mean.lol
PostSubject: Re: 660 rear differential and chassis rebuild   660 rear differential and chassis rebuild Icon_minitimeSun Oct 27, 2013 10:48 pm
Jason I can start to see the thought process, that jig to align the rear diff and that the support over the top is cool.
PostSubject: Re: 660 rear differential and chassis rebuild   660 rear differential and chassis rebuild Icon_minitimeMon Oct 28, 2013 1:17 am
ive always wanted to do that...you da man
» fu2 chassis
» Differential and 4x4 wont disengage
» 660 differential mount/support
» 450 top end rebuild .020 over with 11:1 by Stuntmanmike
» Engine Top-end Rebuild
HOTRODRHINOFORUMS.COM :: Sponsor Forums :: Baxter Built Fabrications-
