 what fuel controller?
tripper
PostSubject: what fuel controller?    Fri Nov 01, 2013 7:04 pm
I am in the process of building my big bore stroker motor (details in sig).
One thing I need yet is a fuel controller. I only have the stock stuff for now so I am pretty open minded on the different systems.  My plan is to go with one that has an auto tune setup with a wideband o2 sensor.
I see that  Bazzaz, Yoshimura and Dynojet all have a setup for that.
I realize I have to buy the controller and then the wideband kit. But do I need another computer for rev and timing or is there one of these that does that too? I am not too concerned about changing the timing or rev limit for now so can I run without if I needed anther computer?
Thoughts?
Thanks.
2009 Rhino 700. Crankworks modified +5 crank with carillo rod keyed and welded, cp 10.75-1 piston, 105.5mm cylinder, stage 1 raptor cam, JBS sheave 16g weights purple spring, two brothers dual exhaust, 27in kenda executioners.
PostSubject: Re: what fuel controller?    Fri Nov 01, 2013 10:25 pm
Call the Hot Rod at JBS, was chatting with him this morning about a fuel controller, and he has something for your every need; that actually performs.
08/700 SE;Stocker
tripper
PostSubject: Re: what fuel controller?    Sat Nov 02, 2013 4:25 pm
Yes I think I will give him a call this week.
I did find out that they make the dynojet pcv for the 700 that does the fuel and also does timing and rev limit. Then just get the autotune and should have everything I need.
It sounds like the simplest setup to me but would like to hear anyones opinion on it that maybe has it.
Just trying to do my own research so when I talk to James I know what I am talkong about. Dont want to waste too much of his time as he sounds pretty busy.
» EFI Fuel Tuners
» The 411 on the MSD Charge FI Controller for the Kawasaki Teryx
» Fuel for glow engines
» 2006 450 rhino fuel guage
» New Fuel Seat Beard Seats
