 How to make a stock 660 live
Foxman92
PostSubject: How to make a stock 660 live   Sat Nov 02, 2013 12:51 pm
I hear there is a lot of flaws to the 660 engine like broken woodruff keys broken cases etc. what should be done to a stock 660 to be able to hold wide open throttle for long period of time with trouble free use. Mine has 1700 miles i really dont want to do a full rebuild anytime soon
chalkminer
chalkminer
PostSubject: Re: How to make a stock 660 live   Sat Nov 02, 2013 1:54 pm
change the oil.  I would wait until you have to open it up to do the upgrades.  A better piston, and if you split the cases the middle drive support should be on the list. some of the guys who are reporting problems have already been into the engines.
Foxman92
PostSubject: Re: How to make a stock 660 live   Sat Nov 02, 2013 2:20 pm
Ok so piston is one problem and the center drive brakes?
Foxman92
PostSubject: Re: How to make a stock 660 live   Sat Nov 02, 2013 2:37 pm
chalkminer
chalkminer
PostSubject: Re: How to make a stock 660 live   Sat Nov 02, 2013 11:48 pm
I think a lot of the center drive failures are a result from something coming loose inside.  I think some thread-loc could prevent a lot of middle drive failure, but one you are in there you might as well add the support.  When it comes time to replace my piston I won't go stock.
doughjk
doughjk
PostSubject: Re: How to make a stock 660 live   Sat Nov 09, 2013 2:15 pm
The middle drive is a ring/pinion inside engine that spins the driveshafts. There are 4 bolts that hold the middle drive plate in place. Yamaha did not use thread-loc of any type and these bolts. Over time these bolts work loose and most failures (including mine) had 1 bolt fell out. The factory plate isn't very strong and once loose breaks out at bolt holes. First good bind or accleration will cause break, when it breaks it breaks the engine case at it's anchor it's attached to. Also the oil pump relief gets knocked out causing loss of oil circulation. Next because you don't realize what happened you give it the gas and continue to break stuff until you realize your screwed or run out of beer.
While your rebuilding whole engine go ahead and get aftermarket middle plate, good connecting rod and piston and your good to go fast.
660 Bored/Stroked to 720, 11:1, Mudblaster Cam, MSD, AirDam/// Primary, 28 Zilla's
PostSubject: Re: How to make a stock 660 live   Sat Nov 09, 2013 6:42 pm
So the MORAL of the story is don't take so damn much beer with you. drunken
08/700 SE;Stocker
doughjk
doughjk
PostSubject: Re: How to make a stock 660 live   Sat Nov 09, 2013 6:52 pm
Hey Kenny, Think my wife hijacked your log in
PostSubject: Re: How to make a stock 660 live   Sat Nov 09, 2013 7:00 pm
Joe, that was a good write up on the middle drive, just had to lmao when you brought up running out of beer. Hell these Rhinos would probably run for ever if we never emptied the coolers. Good stuff!
08/700 SE;Stocker
doughjk
doughjk
PostSubject: Re: How to make a stock 660 live   Sat Nov 09, 2013 9:09 pm
Yea, got a bigger cooler now. Sucks to get that out of beer headache knee deep in mud dragging me or somebody home.
Not trying to jack this guys thread but I see you have a custom cage, that's my next project. What you got? Looking for ideas
doughjk
doughjk
PostSubject: Re: How to make a stock 660 live   Sat Nov 09, 2013 10:02 pm
Okay Foxman, we got sidetracked along the way. Rhino's are very dependable and the 660 is a great engine. The middle drive plate would be fine for stock engine and tires if factory would have used loc-tite.  Most people put bigger tires and other power adders, then it becomes weak link that can cost a ton to repair. Connecting rod and piston really need to be upgraded if you have aftermarket CDI that increases engine RPM's, again probably fine for stock engine.
PostSubject: Re: How to make a stock 660 live   Sat Nov 09, 2013 10:47 pm
Joe, some good pics of the cage over on 'Members Rides', page 1, Kenny G's 06/450 Bitchin Trail.
08/700 SE;Stocker
cammoup
cammoup
PostSubject: Re: How to make a stock 660 live   Wed Nov 13, 2013 11:32 pm
1700 miles is nothing. I believe mine has a little over 9000. Havent had any major issue other than rear axles and last summer the needle valve fell out of the carborator stranding me for a couple of hours while I followed my tracks and found it. Next time Im outside I will have to look at the OD again.
As long as you do preventive maint is should last a while.
JR
My Rhino;
05 660 Green
ITP Mudlites
ITP Wheels
3" Non Factory Wheel Custom Wheel Spacers
All the items needed for hunting
Double gun rack
VisionX Xmitter Prime Extreme Light Bar
Bow Rack
Upgraded Dash (06 OEM) soon need replacement
Warn 4.0 Ti 4000lb Winch/ Synthetic Cable
Twisted Stitch Seats
2" lift
Home made snorkel
Kolpin Roof
Kplpin 3" Over Fenders
Sport Rear Bumper
It's a money pitt but very useful:cheers:
Djbison
Djbison
PostSubject: Re: How to make a stock 660 live   Thu Nov 14, 2013 1:01 am
When the middle drive plate goes does it make a lot of noise? An when it goes is it still possible to drive it?
2005 660 with 27inch xtrs on Itp rims, JBS sheave kit ,big gun exhaust, k&n filter, carb kit, full skid plates, warn winch, stereo, custom aluminum roof and heater in cab!!!!!!!
cammoup
cammoup
PostSubject: Re: How to make a stock 660 live   Thu Nov 14, 2013 1:29 am
Exactly what I worry about with 9k on motor I am soon to get all of my goodies from James. Sheave, CDI and some other stuff.
 During hunting off season will probably invest in piston and Rod. Any recommendation for an otherwise stock 660
Thanks
JR
My Rhino;
05 660 Green
ITP Mudlites
ITP Wheels
Double gun rack
Bow Rack
2" lift
Home made snorkel
Kolpin Roof
Sport Rear Bumper
doughjk
doughjk
PostSubject: Re: How to make a stock 660 live   Fri Nov 15, 2013 9:56 am
The engine will run fine and it's possible the gears may keep enough teeth to move a very short distance ( mine went about 6 foot). if you hear a pop followed by grinding sound and jerky grinding to stop, it just broke. Caution about continuing to run engine is break probably took out oil pump. Going hunting but i'll try to post pics in a couple of days
doughjk
doughjk
PostSubject: Re: How to make a stock 660 live   Fri Nov 15, 2013 10:13 am
Thanks
JR
Lots of people on here smarter than me at going fast, I don't have mine set up to go fast. I have a CP piston (over kill) thing looks like a piece of jewelry. Then I have the Hotrods stoker crank and rod, some people like some don't (again i don't go fast) so it'd been great for me. A really good rod with install and shipping can easily get very expensive. You'll need to look at you're budget and get the best parts that fit your budget.
» Intrusion bars for your stock cages
» Polaris tires and rims
» what is the law on live bait in uk
» FCUM live streaming video
» How long do pike live?
