Subject: oxidized plastics Thu Nov 07, 2013 2:20 am
I saw a trick on youtube to shine up oxidized plastics using paint thinner and boiled linseed oil. Looked like it worked pretty well. Has anyone tried it?
UnderDawg
Subject: Re: oxidized plastics Thu Nov 07, 2013 2:48 am
Nope, but I have used a heat gun and steel-wool.
Subject: Re: oxidized plastics Thu Nov 07, 2013 8:46 am
Wow that looks great. If I would have seen that before I painted mine I would have tried it
Subject: Re: oxidized plastics Thu Nov 07, 2013 10:08 am
Wow what a great result, real nice.
meats
Subject: Re: oxidized plastics Thu Nov 07, 2013 10:16 am
what was the process in doing that i need to try that out on mine
Subject: Re: oxidized plastics Thu Nov 07, 2013 11:17 am
I 've used the 4-0 steel wool with good results , but what's the heat gun for it looks like u got beter results forsure
Subject: Re: oxidized plastics Thu Nov 07, 2013 12:06 pm
the guy who had my rhino before me tried something similar to this. DONT DO IT!!!! Just makes it greasy and it holds more dirt. It doesn't actually fix the problem...its like spraying it down with WD-40 or Armor-all. you can buff them and get them to come back also but there is some technique to it also.
Subject: Re: oxidized plastics Thu Nov 07, 2013 12:41 pm
This process looks good just a little elbow grease, if you do this make sure the linseed oil soaked rags are stored outside in a metal container, linseed oil can spontaneous combust.
UnderDawg
Subject: Re: oxidized plastics Thu Nov 07, 2013 3:17 pm
The heat gun re-melts the plastic and bring back the color. the steel wool will even out any blotching. I also wet sanded with 1000 grit to finish it up.
I suspect the linseed oil would only dry back out after ya let a little mud set on it.
chalkminer
Subject: Re: oxidized plastics Sat Nov 09, 2013 9:43 pm
I decided to give it a try. I have my reservations, but my plastic is looking pretty bad. I bought it surplus from the local power company it had always been outside and they had company logo stickers and ID numbers on it. When they were removed the shiney plastic under them made the exposed plastic look even worse. I have my reservations, but it can't hurt.
Subject: Re: oxidized plastics Sat Nov 09, 2013 9:53 pm
Did a king quad I had...3m compound and a buffer. Don't know how it lasted tho...sold the bike.
Subject: Re: oxidized plastics Sat Nov 09, 2013 11:16 pm
I did my 06/450 with rubbing compound and fine steel wool a couple years ago, and it was similar in condition to the red rhino. The color turned out well, just not glossy like fresh paint. The next year I slapped some good graphics on it and they have held up like new through their second season. [url=][/url]
chalkminer
Subject: Re: oxidized plastics Sat Nov 09, 2013 11:19 pm
Well, it sure looks better, although Chuddly and UnderDawg might still be right. Could I have gotten the same result by wiping it down with Vasoline? Who knows I have never tried.
UnderDawg
Subject: Re: oxidized plastics Sun Nov 10, 2013 12:39 am
..Ya never know till ya try...be sure to let us know how it holds up.
Subject: Re: oxidized plastics Sun Nov 10, 2013 10:39 pm
Scott, that turned out nice. What did you end up using, besides a lot of elbow grease and beer..lol....
chalkminer
Subject: Re: oxidized plastics Sun Nov 10, 2013 11:11 pm
I used the 60% paint thinner 40% linseed oil mixture with a scotch bright pad. As you can see in the pictures it worked and did not take what I would consider a lot of elbow grease and beer. Pretty easy actually, but it does seem a little oily. As you can see I need to get a little more work to get the rest if the stickers off. I'll let you know if it gets sticky and attracts dust or if the result don't last.
Subject: Re: oxidized plastics Mon Nov 11, 2013 8:05 am
I have a body shop and have done this to MANY quads for friends. If you take wax and grease remover and go over the whole thing (Chalkminer esp. because you just put oil on it LOL) then sand it with 1000 grit then with 2000 grit paper. Then buff it with a buffer it will come out looking great. It is about 3 or so hours work depending on how bad your ride it....but what it does is take the top layers of plastic off (dont worry it doesnt take much off) and then buffing it brings the shine back. Low RPM on the buffter and keep it flat and cool. If you bear down and get the plastic real hot it still start to move under you pad. But you really gotta try to do that.
meats
Subject: Re: oxidized plastics Sat Nov 30, 2013 12:03 pm
here we go guys i tried the heat gun trick and it works pretty good. little left to do but have to share the garage with the wife so the rhino doesnt make it inside very often during winter.
Subject: Re: oxidized plastics Sat Nov 30, 2013 12:13 pm
do your grill and headlamp bezels too...lookin good
meats
Subject: Re: oxidized plastics Sat Nov 30, 2013 12:19 pm
yeah i'm going to take them out to do those. i have 4hrs into that much but i was having a few beverages. hopefully get it in tomorrow and finish her up
Subject: Re: oxidized plastics Sat Nov 30, 2013 12:46 pm
It's looking good Eric. Well worth the effort, plus you get to have a few beverages while doing it.
meats
Subject: Re: oxidized plastics Sat Nov 30, 2013 1:22 pm
thanks. yeah its worth the time. and its always good to have an extra excuse to have a few, other than being married and having two kids.
Subject: Re: oxidized plastics Sun Dec 01, 2013 10:31 am
That's a great job Erik what a difference,elbow grease and a few beverages good work.
UnderDawg
Subject: Re: oxidized plastics Sun Dec 01, 2013 11:13 pm
Nice!! be sure to post up more pics when your done
Subject: Re: oxidized plastics Mon Dec 02, 2013 8:25 am
