Posts : 41 Join date : 2013-03-10 Age : 64 Location : Prince George BC
Subject: adjusting tps on 700 rhino Mon Nov 11, 2013 2:55 pm
Hi,I just watched James video on the 700 tps ,I n the video james said the numbers are 95 to 100 when the gas peddle is fully depressed,On my 700 the reading was 94,how do I adjust the tps to get the numbers where they should be.thank you.
Subject: Re: adjusting tps on 700 rhino Mon Nov 11, 2013 3:33 pm
yours is prolly the cable free play is to much
rhinopg
Subject: Re: adjusting tps on 700 rhino Mon Nov 11, 2013 9:19 pm
Thankyou James, what it the procedure to take out the slack in the throttle cable and what number between 95 and 100 should I set it at,thanks again.
RHINOMOON
Subject: Re: adjusting tps on 700 rhino Thu Nov 21, 2013 8:25 pm
