 What's wrong with my Rhino
Go to page : 1, 2  Next
cruiserheads
PostSubject: What's wrong with my Rhino   Tue Nov 12, 2013 12:36 pm
I was out hunting yesterday and after going after a Deer I came back to my Rhino(still running) I hopped in and it sputtered and had no power. I left it there while I gutted the deer. After about a half an hour it started and ran fine. I headed back towards my truck and half hour later it did the same thing. No power and sputtering. Let it cool again and drove back to my truck with it starting to sputter when almost back. It seems as if electrical. Is it possibly a bad coil as it works good when I let it cool down. My engine temps are about 160 when this happens. Carb was cleaned recently and I have a Dynatech CDI so that rules out the rev limiter. New Alba fuel pump was installed a couple of months ago as well. Exhaust smells rich when it happens as well.
Neil.
06 Rhino 660, JBS sheave, Dynatec CDI, 27" Mud Lite XTR, and some other crap.
PostSubject: Re: What's wrong with my Rhino   Tue Nov 12, 2013 1:12 pm
Spark plug fouling out? Pull the plug and take a look at it.
08/700 SE;Stocker
cruiserheads
PostSubject: Re: What's wrong with my Rhino   Tue Nov 12, 2013 7:19 pm
Pulled the plug. Looks fine. Could the coil be bad. After it cools for maybe half an hour it runs fine for a while.
PostSubject: Re: What's wrong with my Rhino   Tue Nov 12, 2013 10:25 pm
coil,cdi,stator
2009 Yamaha Rhino 787
jamesbodyshop@hotmail.com
chalkminer
PostSubject: Re: What's wrong with my Rhino   Wed Nov 13, 2013 12:02 am
Do you still have the stock CDI around somewhere?  If yes, I'd try swapping that first.  It is easy and won't cost anything.  If you have a multi-tester you can check the stator too.
PostSubject: Re: What's wrong with my Rhino   Wed Nov 13, 2013 12:19 am
I had a coil do the same to me on a wolverine , glad u got back to truck an good luck with it
    .......I hate electrical crap
cruiserheads
PostSubject: Re: What's wrong with my Rhino   Wed Nov 13, 2013 12:29 am
I do not have a stock CDI. I tried to duplicate the problem tonight with no luck. I did change the sparkplug. Maybe it was bad. I hate diagnosing when you can't duplicate the problem. It will probably happen in the bush this weekend again. Hopefully I will be able to limp it back again.
cruiserheads
PostSubject: Re: What's wrong with my Rhino   Wed Nov 13, 2013 12:31 am
I am pretty sure it is one of the three things James listed.
PostSubject: Re: What's wrong with my Rhino   Wed Nov 13, 2013 9:22 am
i seen plugs do it too
PostSubject: Re: What's wrong with my Rhino   Wed Nov 13, 2013 1:10 pm
I 'd have a spare coil with u this week end just in case
cruiserheads
PostSubject: Re: What's wrong with my Rhino   Wed Nov 13, 2013 2:20 pm
I would but no one stocks anything here. City of 1.2 million and they never stock anything.
Neil.
PostSubject: Re: What's wrong with my Rhino   Wed Nov 13, 2013 5:00 pm
that's unreal   lots of folks    an  no parts    Mad
PostSubject: Re: What's wrong with my Rhino   Sat Nov 16, 2013 1:33 pm
Hey cruiserheads, I feel your pain. Calgary might have the population but everything comes from the States with regards to parts. Best bet is to order from James. Super fast service!
I've had problems with my Copperhead CDI doing the same thing. Put the stock CDI in, no problems.
06-660
JBS sheave 14g
Purple Spring
The author of this message was banned from the forum - See the message
PostSubject: Re: What's wrong with my Rhino   Sat Nov 16, 2013 7:03 pm
if you have a service manual it covers how to check the resistance of the plug cap, coil and coil wire
JBS
cruiserheads
PostSubject: Re: What's wrong with my Rhino   Sat Nov 16, 2013 7:25 pm
I have a service manual. I think it would need to be acting up to show up in a test. Unfortunately I can't duplicate the symptoms at home.
wagon1
PostSubject: Re: What's wrong with my Rhino   Sat Nov 16, 2013 8:20 pm
just a thought... u dont have anything blocking the intake to your airbox do u? i sat my gloves on the console blocking mine once and had the same problem.
2007 Rhino 660 JBS Sheave, Orange Spring, Hunterworks Tri-Fire CDI, Air box mod, Muzzy Exhaust, Dyno Jet Carb kit, 700 Belt, Viper 5000 winch, LED Light bar, 14" ITP Rims w Pro Comp tires, Siezmik full enclosure and center console.
View user profile http://www.sawdy.com
cruiserheads
PostSubject: Re: What's wrong with my Rhino   Sat Nov 16, 2013 9:18 pm
You might be right. I did have my gloves and hat sitting there. Exhaust smelled really rich when it was happening. I hope it is that simple. I think I will test my coil though.
cruiserheads
PostSubject: Re: What's wrong with my Rhino   Sun Nov 17, 2013 1:09 am
Sometimes you have to laugh at yourself. I went out to the garage tonight and was able to duplicate the symptoms. With my damn gloves.
chalkminer
PostSubject: Re: What's wrong with my Rhino   Sun Nov 17, 2013 1:19 am
Good call David!  I never would have to thought to ask where the gloves were sitting.  Hope that really is it.
wagon1
PostSubject: Re: What's wrong with my Rhino   Sun Nov 17, 2013 8:57 am
sh!t happens. i know its simple but i.dont mind telling on myself.  Very Happy
PostSubject: Re: What's wrong with my Rhino   Sun Nov 17, 2013 9:34 am
I had a pack of cigarettes get sucked in. you are right   shit happens.
Dave
(Hailey on left and Molly)
PostSubject: Re: What's wrong with my Rhino   Sun Nov 17, 2013 5:49 pm
happened to me before going o4 style with a sweat shirt, affraid
