In total there are 11 users online :: 0 Registered, 0 Hidden and 11 Guests :: 1 Bot
 Lift or Mid-Travel?
Go to page : 1, 2  Next
PostSubject: Lift or Mid-Travel?   Sat Nov 16, 2013 12:41 am
Looking for input on which might be overall better investment. I ride mountain back trails that are mostly not maintained. Some mud-holes lots of rocky, loose material conditions. Downed trees and brush. I've had good luck with lifts in the past but wonder if a mid-travel might give me what a lift has plus a better ride. I've never ran a long or mid travel kit so, am I missing something?
08/700 SE;Stocker
Baxter Built Fabrications
PostSubject: Re: Lift or Mid-Travel?   Sat Nov 16, 2013 2:27 am
I personally would go mid travel because you end up with lift if that's what your after and less angle put to the CV's getting it.I love mine,more travel and clearance.I have 15.5" or belly clearance with 27.5 pittbulls.Lift is cheaper unless your talking big though.
08 Rhino with JBS sheave,LS MTS,27.5 Pittbull Growlers on HiPer beadlocks,4 seat cage,and a 40"E series RIGID LED.
baxters@embarqmail.com  419-953-8509
oldmustangjunkie
PostSubject: Re: Lift or Mid-Travel?   Sat Nov 16, 2013 2:06 pm
Baxter,
I've seen your fab skills on here and other sites.  Do you make a mid or long travel kit?
PostSubject: Re: Lift or Mid-Travel?   Sun Nov 17, 2013 12:14 am
Jason, So do you get the lift from shock placement on the A Arms from the mid travel? I have also read with the mid travel you can still run stock shocks, ball joints and steering and then upgrade your shocks ect... later? What make are you running? Anyone else running a mid travel?
08/700 SE;Stocker
PostSubject: Re: Lift or Mid-Travel?   Sun Nov 17, 2013 9:16 am
I've ran the 2" lift and 3" arched a arms on my rhino. Have no trouble with either and rode very nice with the rhino sport shocks. With the mid travel, you will push your tires 3" out but also you will push them slightly down as well. Resulting in a lift of ground clearance. It will ride better cause of the better travel in the a arms.
I've considered doing this to achieve 4-6" of lift without putting to much angle on the axles. But I sold my rhino before I went extremely overboard with the spending.
Bottom line is, if your going to go mid travel, then make sure your trails are wide enough for you to fit. Your rhino will be 6" wider. Also, invest in heavy duty aftermarket spindles. I've heard stories of breaking them with the extra travel. I think if u can fit, you will enjoy the ride.
And yes, stock shocks will work on the mid travel. I suggest sport shock or t-Rex shocks. Less expensive for a used set and you will get great ride quality. Good luck
2009 Rhino SE Red  SOLD SOLD
PostSubject: Re: Lift or Mid-Travel?   Sun Nov 17, 2013 11:16 am
If I keep my Rhino I will be looking really hard at some mid travel after the first of the year.
Banchee what are you getting now, T4.
27" EFX Motoclaws
JE 11:1 102mm
Warn Pro Vantage 3500lb.
Ricochet a-arm skids
PRM bash plate
Unisteer Rackzilla
PostSubject: Re: Lift or Mid-Travel?   Sun Nov 17, 2013 11:21 am
Still researching. Trying to take rides on different machines. Price tags make me wanna thro up but I know since this is my only means of entertainment and my daughter loves it, I'll probably go over board with my purchase. But I'm in no rush. March next year will be the time I pull the trigger.
Sorry about your thread. But I know if you can fit and you have the coin, you will like mid travel.
PostSubject: Re: Lift or Mid-Travel?   Sun Nov 17, 2013 5:08 pm
Check this out. Coukd be a route for you. I seen this and was going to order arms and then axle shafts, tie rods and brake lines later.
http://www.twistedlabs.net/index.php?target=categories&category_id=172
Mud Rat
PostSubject: Re: Lift or Mid-Travel?   Sun Nov 17, 2013 9:06 pm
I did the lsr mid travel on my rhino with stock sport shocks and lost ground clearance due to the extra leverage on the suspension or the springs where wore out not really sure  so I install teryx shocks but then had trouble with the rear axel sitting on the frame and I call my rhino a rabbit cause the way I ride 50% of the time in the air (lol) so I built a bracket to relocate the shock mount and bolted it to the shock mount on the a-arm (so it can be removed if I ever sell the kit) with the teryx sport shocks on all 4 corners mounted the right way even on the rear I gained about 3" of lift and the axel angles are about the same as stock best of all i'm still no wider then my buddies teryx
PostSubject: Re: Lift or Mid-Travel?   Sun Nov 17, 2013 9:08 pm
That sounds like the cheapest way to make it work, still about $2k.
27" EFX Motoclaws
JE 11:1 102mm
PRM bash plate
Unisteer Rackzilla
PostSubject: Re: Lift or Mid-Travel?   Sun Nov 17, 2013 9:47 pm
Don't see anything but LT's on the site. But the pricing for just the a-arms looked pretty good. Got nothing but time on my hands for the suspension on the 700. I've got it torn down re-caging, and waiting for performance parts to come in. She'll be in a slow mood over-haul through the winter. Maybe I'll find a good use mid-travel.
08/700 SE;Stocker
PostSubject: Re: Lift or Mid-Travel?   Sun Nov 17, 2013 10:36 pm
Hard to find 700 mid travel. I looked for 6 months. Ever thought of just doing a shock upgrade? I know Chris did walker evens on his stock arms and he was extremely impressed. You can adjust those for a little lift.
PostSubject: Re: Lift or Mid-Travel?   Sun Nov 17, 2013 11:19 pm
Thanks for your input Eric, those kit are some $$$ to throw down, and it's nice to get as much info as one can.
08/700 SE;Stocker
PostSubject: Re: Lift or Mid-Travel?   Mon Nov 18, 2013 3:09 am
just go LT, I'm only 64" with 13" travel...love it
skeeter9
PostSubject: Re: Lift or Mid-Travel?   Thu Nov 21, 2013 6:47 pm
I have the lsr mid travel and a cfm 2" lift with 26" bighorn 2.0s... can't comment to much on ride etc since I haven't finished putting it together... hehehe
08 700
jbs sheave 16s and a purple
muzzy duals
custom intake/snorkel
4 seat cage w/removable rear seat
beadlocks w/26'' bighorn 2.0
msd mapped by alba nate
lsr mid travel w/fabtech dirt logic 2.0 shocks
cfm 2'' lift
PostSubject: Re: Lift or Mid-Travel?   Wed Nov 27, 2013 3:38 pm
Scott, Are you going to use the CFM lift with the mid-travel for more body lift?
08/700 SE;Stocker
skeeter9
PostSubject: Re: Lift or Mid-Travel?   Sun Dec 01, 2013 1:09 am
yesI had planned on it to keep all the clearance I can... I'm the "I can make it" type lol
08 700
muzzy duals
cfm 2'' lift
PostSubject: Re: Lift or Mid-Travel?   Thu Dec 05, 2013 8:30 pm
With the LSR MTS do you need to get extensions for the brake lines, or did the kit come with them.
08/700 SE;Stocker
PostSubject: Re: Lift or Mid-Travel?   Thu Dec 05, 2013 10:52 pm
I am running a 2" cfm lift and offset wheels. I have no issue in the woods. I was wanting a LT kit real bad but I think its gonna give me more problems then its worth. eventually I will order a mid travel kit. I need to do something to hold the extra weight of the family cage , seat and kids. the stock shocks just aren't up for the challenge.
PostSubject: Re: Lift or Mid-Travel?   Thu Dec 05, 2013 11:08 pm
My 08/700 Special Edition have the 'Sport Shocks' which LS Racing says will work with there Mid-Travel, probably not as well as a $2600 set of shocks but I'm not doing the whoops out on the dunes. Want to get into the MTS as cheap as I can and still be happy with it.
08/700 SE;Stocker
PostSubject: Re: Lift or Mid-Travel?   Fri Dec 06, 2013 4:52 pm
Information for anyone thinking about a MTS. I'm just about to pull the trigger on a LSR MTS investment. Have thought about going w/CATVOS with 2" spacers, but can't get them to call me back and answer any questions. Anyway, know there are a couple guys on here thinking about the MTS and thought this was good info from someone that has tried both LTS & MTS. Cool
Hey Ken,
It will include everything you need to complete the installation and it is designed to work with the stock sport shocks.  Really a cool system.  I ran this myself on my Rhino before I sold it and I loved it.  I actually removed a +6" long Travel kit to install this and preferred it.  The car handled and cornered much better with the mid-travel opposed to LT.  There my not be as much travel, but the +6" turns the car into a square and square cars don't turn!  Additionally, the +6 was too much travel vs.
power and speed and made the car boring to drive.  The mid travel with the sport shocks is a great balance.
Darren McGarvie
Accelerated Future, LLC. (iShock)
Darren@ishock.com
760-366-3640
08/700 SE;Stocker
PostSubject: Re: Lift or Mid-Travel?   Fri Dec 06, 2013 5:36 pm
Mike , I don't remember if ur running sport , or base model shocks...but...James carries heavier springs for the sports.
Kenny ,  if ur doin a four-seater , or heavier cage...you will definitely need need heavier springs. My bike weighs around 1600 + or - ...depends how full the cooler is !!  I'm running 525 lb on the rear !
PostSubject: Re: Lift or Mid-Travel?   Fri Dec 06, 2013 6:23 pm
im running base model shocks. I really need to do something back there. i am probably going to get a set of sport shock and then call james for some help.
PostSubject: Re: Lift or Mid-Travel?   Fri Dec 06, 2013 7:07 pm
I'm refabbing the custom 2 seater cage off my 450 to put on the 700. Was looking at some heavier springs on CATVOS website but said they wouldn't work on the Rhino sport shock because of the res tank. I'm going to talk with iShock and see about dialing in the sport shocks, they said there able to make them work pretty well with LSR MT. I can feel the $$$ slipping out of my hand.
08/700 SE;Stocker
Mud Rat
PostSubject: Re: Lift or Mid-Travel?   Fri Dec 06, 2013 9:16 pm
if you have ever bottomed out you stock shocks you will even more with the mts
Lift or Mid-Travel?
