| siphon filter and tube... | |
+3ChrisH 123.bert0621 jnalley_01 7 posters |
jnalley_01
Posts : 48 Join date : 2013-09-10 Location : malaga ohio
| Subject: siphon filter and tube... Wed Sep 11, 2013 3:18 pm | |
| Just found out bout these i have a lil residue in there like lil dust maybe 1 or 2 drops oil pretty much looks brand new oil level is always spot on should i run one...next question does anyone run one and thoughts on one | |
| Subject: Re: siphon filter and tube... Wed Sep 11, 2013 5:54 pm | |
| Subject: Re: siphon filter and tube... Wed Sep 11, 2013 6:16 pm | |
| I had one on my Rhino 700, but took it off recently. I ride a lot of water and was too lazy to find a clean way to bring the siphon break filter up the roll cage. So it removed the setup and went back to the stock crankcase breather.
I have never seen any oil in my bottle when I did run it, but it does keep the hot crankcase gases out of the intake and off the IAS. I will probably reinstall it and get it set up to my liking later this winter. | |
| Subject: Re: siphon filter and tube... Sun Sep 15, 2013 8:12 am | |
| I run one it keeps the oil from getting on breather an lets the oil drain back in crankcase when you let off gas for a moment . with my stroker the higher rpms seemed to make the oil blow out the vent more which made the siphon brake more helpfull | |
| Subject: Re: siphon filter and tube... Mon Nov 11, 2013 12:22 am | |
| Couple questions. You guys running James air temp sensor mod how you like it and did you notice a difference in how it ran? And second where did you get you siphon break and filter and what did you use to plug hole where goes into intake on throttle body? | |
| Subject: Re: siphon filter and tube... Mon Nov 11, 2013 12:25 am | |
| Wish I could call James and order the parts..........wonder if I can? | |
| Subject: Re: siphon filter and tube... Mon Nov 11, 2013 7:43 am | |
| Subject: Re: siphon filter and tube... Mon Nov 11, 2013 9:40 am | |
| I made a patch-plug out of gum rubber and 100% silicone to seal hole up | |
| Subject: Re: siphon filter and tube... Mon Nov 11, 2013 11:10 am | |
| - T.Rhino wrote:
- Yes he carries them.
Thanks Teddy exactly what I was hoping for I will make the call today for the parts. | |
| Subject: Re: siphon filter and tube... Mon Nov 11, 2013 1:12 pm | |
| Welcome. And you can go to advance auto or any auto parts store I'm sure and buy a sorted pack of air line fittings the kind that cap off the ends and put it over the hole with a hose clamp works great. | |
| Subject: Re: siphon filter and tube... Mon Nov 11, 2013 1:17 pm | |
| i put pcv valves on breather hoses so the air only goes out, and not back into the crankcase. | |
| Subject: Re: siphon filter and tube... Mon Nov 18, 2013 1:45 pm | |
| Thanks James I got it in and got it on before me and Larry rode about 37miles this past weekend and she ran great! I ran her pretty hard at times but never had any oil up in the bottle but I could feel air coming out of filter when I placed my hand around it so I would say she is working perfectly and keeping the oil where its supposed to be.... [img] [/img] | |
| Subject: Re: siphon filter and tube... | |
